brake regulator on LT1
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=94721
Printed Date: 08 Aug 22 at 23:02
Topic: brake regulator on LT1
Posted By: derekW
Subject: brake regulator on LT1
Date Posted: 19 Jan 22 at 17:16
Hi everyone does anybody know about the Mercedes Unimog brake regulator. There is an "extra" spring which is adjustable on the lever I am presuming that to use this reg on an LT1 you remove this spring and just use the original VW spring and longer lever as presumably the pressure is higher on the Unimog and therefore the extra spring is needed.
Any help or suggestions would be appreciated.
Best regards,
Derek Wilson.
Posted By: Monster LT
Date Posted: 21 Jan 22 at 22:14
Hi Derek, The data from Wabco suggests the regualtors are almost the same. I would just use the old LT lever arm and spring but delete the extra unimog spring. It'll help to mark the position of the spring nut attached to the axle so it's replaced in same position. There is a guide on how to set the spring position correctly in one of the manuals if you want to be sure. Hope that helps.
Posted By: derekW
Date Posted: 05 Feb 22 at 00:45
Hi,
Thanks for your response I figured that might be the story but just wanted to hear it from someone else.
I have tried to get a reply from Wabco USA without any luck so far where did you get info from them?
Many thanks,
Best regards Derek.
Date Posted: 18 Apr 22 at 17:37
I think that it is one of the threaded fittings which is different.
http://www.lt-forum.de/dokuwiki/doku.php?id=start:reparaturtips:bremskraftregler_wabco_hinterachse" rel="nofollow - http://www.lt-forum.de/dokuwiki/doku.php?id=start:reparaturtips:bremskraftregler_wabco_hinterachse
There are a couple of people supplying kits for DIY refurbishment  or a chap on ebay.de who does an exchange. LT Doctor, I think.
