Headlight adjuster switch
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=94720
Printed Date: 27 Jun 22 at 15:43
Topic: Headlight adjuster switch
Posted By: Dosey37
Subject: Headlight adjuster switch
Date Posted: 17 Jan 22 at 22:31
Hello all. Lt35 failed mot on headlight adjuster switch in cab. Not been connected since I’ve had it. Does anyone know if the gubbins in the headlight need lubricating or any other tips to get them going? The one pipe in the cab was blocked with a screw and when screw is out it’s sucking air in. The other one dies nothing. Cheers.
