JX alternative turbo
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=72870
Printed Date: 27 Feb 24 at 10:10
Topic: JX alternative turbo
Posted By: WIGANBARGEE
Subject: JX alternative turbo
Date Posted: 06 Apr 12 at 08:50
Hello all,
I have a van here that's been mothballed for a few years and a good JX 1.6 TD engine to go in it.
Problem is there's one thing missing-the original turbo.
Should be a KKK part number 068 145 701 QX if anyone has one.
I do have a Garrett turbo from a 1990 Audi 80 1.6TD.
Will this fit and if so how would I need to modify it?
I have the JX manifolds and also the Audi ones.Sleepy
All the best,
Mike.
Posted By: VW Nerd
Date Posted: 06 Apr 12 at 15:05
Does the Audi turbo have the same 4 bolt fitting pattern as the JX exhaust or does the turbo have a 3 bolt pattern?
Developing parts for the VW T3 TDI market Inc flipped audi gearbox install parts.
Tim Shettle
www.ultimate-engineering.co.uk
Bristol
Tel/txt 07810 320 464
AFN TDI Panel Van
Date Posted: 06 Apr 12 at 16:42
Turbo will bolt straight on. 4 bolts.Ouch
Posted By: VW Nerd
Date Posted: 06 Apr 12 at 19:06
Just check the position of the oil feed/return. Reindex if necessary and away you go.
Tim Shettle
Bristol
AFN TDI Panel Van
Date Posted: 07 Apr 12 at 10:31
Thanks for the info.
By re-index do you mean dismantle the turbo and reset it so it's level say with the floor and not likely to feed the engine its own oil?
Also when it was fitted to the Audi engine there was a water pipe that connected to the engine block to a nozzle in one of the 3 "caps"and another oil pipe.
What do I do with these?
All the best,
Mike.
Posted By: VW Nerd
Date Posted: 07 Apr 12 at 11:41
You dont need to attach the water pipes. just leave them off.
Reindex the turbo so that the oil return is at the bottom of the turbo. You can check this by putting the turbo on to the exhaust manifold which I guess is still fitted to the engine.
Tim Shettle
Bristol
AFN TDI Panel Van
Date Posted: 07 Apr 12 at 12:40
OK thanks again.
I'll have a look and make sure it all lines up.
I suppose a JX oil feed pipe will go straight to it?
And would the turbo not catch fire without water?
Mike.Ermm
Posted By: VW Nerd
Date Posted: 07 Apr 12 at 19:51
No turbo won't catch on fire. It will b fine without water. You can plumb into water if you want 2 and have the fittings for the turbo.
Tim Shettle
Bristol
AFN TDI Panel Van
Date Posted: 08 Apr 12 at 15:13
One more thing.
The Audi 80 setup had an oil feed pipe and another running alongside it that was disconnected.
What is this for?
Something to do with the intercooler maybe?
And do I block it off when using on the JX?
Flying blind at the mo with limited know-how and awaiting a "Bentley" manual.
Thanks again,
Mike.
Posted By: Syncropaddy
Date Posted: 08 Apr 12 at 15:51
If its a water cooled turbo it will be worth while taking the pump and injectors off the Audi engine as its the 80bhp unit - if you still have access to it.
syncropaddy
I blame Tesco for the obesity issues we have in Ireland. I will be proved right.
1991 LHD Syncro Multivan TD
1993 RHD Syncro Van TD ..... the last RHD made
Date Posted: 08 Apr 12 at 16:12
Yes I have both the JX which is almost ready to drop in, and when this one dies I have the old Audi lump to fall back on.
My original plan was to send the van to a specialist and have them put a recon JX in.
Trouble was my van had a CS non-turbo waste of time in it so I thought hmm what do I do now.
Dust off the old socket set!
Anyway I bought a decent used JX but a few bits lets say had been used to do an AAZ conversion.
And these bits took a bit of tracking down(eBay Germany etc).
And they started adding up(lots of £20s £30s and £40s.
So when I saw the Audi engine I thought hmm might as well buy this even if I use a few bits and keep it as a spare.
Must say though glad it happened like this as it's proving to be quite enjoyable especially as it's all coming together.
Van is a 1987 Syncro crewcab by the way,
Mike.
Posted By: pothole dodger
Date Posted: 09 Apr 12 at 16:58
I`ve got one of them audi 80 engines here with pump if any parts are any good to anyone?  Is the pump as it looks the same as a VW GTD?
Date Posted: 09 Apr 12 at 18:37
Do you have the injectors?
syncropaddy
Posted By: James Golding
Date Posted: 26 Dec 20 at 23:26
I am too curious about this.
After my JX engine died I replaced it with an AAZ engine but used all the ancillaries and manifolds from the JX engine when fitting it. The JX turbo is on its way out and I need to replace it. I find this feed interesting as I would believe that a Audi 80 turbo (1Z) has the same 4 bolt pattern as the JX exhaust manifold and therefore should be a easy fit, does this turbo offer any benefits to just replacing with another JX turbo? I am assuming it would as it designed for a larger capacity engine.
Will my JX oil feed connect straight to an Audi 80 turbo? Or will I need to manufacture my own oil feed and drain pipes? Is this turbo conversion swap worth doing as the turbo needs replacing anyway?
Regards,
James
Posted By: dave.arthur
Date Posted: 24 Aug 22 at 13:01
Since we are on the topic of turbos...
I have a stock JX in a T3/T3 with a K14 turbo.
Is there an adapter available that would allow me to mount a VW VNT15 on the JX manifold? It would adapt the four bolt trapezoidal pattern to the triangular three bolt pattern.
Date Posted: 24 Aug 23 at 11:25
Just to close this thread... I was able to find an adapter that would fit a T15 turbo or VNT to a JX manifold with the trapezoidal mount. Tim Shettle was able to provide me with the adapters. They worked without issue, quality kit!
Tim Shettle
http://www.ultimate-engineering.co.uk" rel="nofollow - www.ultimate-engineering.co.uk
Bristol
