89 caravelle 2 tone blue colour codes |
michael rodent
Groupie Joined: 28 Dec 06 Location: New Zealand Status: Offline Points: 88 |
Posted: 20 Mar 10 at 19:43 |
Hi, I have a 89 Caravelle that is 2 tone blue.
The roof and mid section are a darkish blue, the lower and upper body, are a lighter blue.
Does anyone know the colour codes for these standard VW colours?
m.rodent
timmythedog
Vanorak westy fetishist Joined: 29 May 08 Location: Nr Grenoble Status: Offline Points: 3415 |
Is the paper label not present around the lower steering colum area? Sounds like a non standard colour format though. Might be an original with a diferent colour over the top?
Syncro doka td
T4 Multivan Generation, 151 89 Caravelle Exclusive 2.1 Caravelle GL AFN tdi 53 plate T4 Panel.888 special x factor. 88 DG Panel(uncut) calypso Atlantic pop. |
DaveyP2004
Yardie Joined: 07 Nov 06 Location: Liverpool Status: Offline Points: 456 |
I think you will see codes here:
Cheers,
Dave
michael rodent
No label that I can find.
The colours and colour scheme are original.
Suspect they are Capri Blue and Mid Blue but want it confirmed.
m.rodent
michael rodent
Thanks Dave, from your chart it looks like Marine blue and Capri blue are the colours.
m.rodent
Grantus
Vanorak Joined: 06 Feb 07 Location: ACT, Australia Status: Offline Points: 1272 |
I'm guessing you have a Caravelle GL then Michael?
They had 4 bands of the two colours...... the CL was only two bands - dark blue below the windows, and paler blue above the windows & the roof. |
Blue 88 MV Caravelle CL Manual
Was White, now Blue 91 MV Single cab Manual (Pritsche) |
michael rodent
Yes, it is a GL.
Colurs all sorted now, thanks to DaveyP2004.
m.rodent
DaveyP2004
Not sure if you worked it out for yourself but if you shorten the URL you will see the whole brochure ie:
Cheers,
Dave
Edited by DaveyP2004 - 22 Mar 10 at 18:35 |
Grantus
Got any pics here on the Yard? |
