2006 LT35 AVR - Fuel Injection Quantity
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=94624
Printed Date: 01 Dec 21 at 16:18
Topic: 2006 LT35 AVR - Fuel Injection Quantity
Posted By: mojo
Subject: 2006 LT35 AVR - Fuel Injection Quantity
Date Posted: 15 Dec 20 at 21:44
Hi all,
Was wondering if anyone with the AVR engine could post their fuel injection quantity at idle on a cold start and when warm. (vcds display group 1 section 2).
I've been having a bit of a rough idle on cold and severe engine shudder if I come off the gas and then lightly get back on it. It also cut out on me twice when cold and pulling away.
It threw up two codes:
17970 - Quantity Adjuster (N146): Upper Limit Reached
            P1562 - 35-00 -  -
17971 - Quantity Adjuster (N146): Lower Limit Reached
            P1563 - 35-00 -  -
I've checked out the fuel quantity adjuster and all associated  wiring according to elsawin specs and everything checks out fine.
I've increased the fuel injection quantity with vcds and it's solved the problems, but just wanted to compare with others FIQ to see if I'm just masking a problem with the higher FIQ.
Thanks in advance.
mojo
2006 LT35 TDI 109 AVR
Posted By: tellytubby
Date Posted: 16 Dec 20 at 19:47
Can't do it till weekend but I'll have a look then.  Mine runs fine cold or warm.
Any other info you think you might want let me know.
Posted By: mojo
Date Posted: 16 Dec 20 at 22:34
Thanks mate.....you're on my Christmas card list!
Would it be to much to ask for screen shots of all your measuring blocks, I'd be really interested to compare idle speed, air flow, boost pressure, smooth running control etc. I can post mine if you're interested.
Thanks again appreciate it.
Date Posted: 19 Dec 20 at 16:28
From Cold
Saturday,19,December,2020,15:11:07:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.0.2
Data version: 20150820
http://www.Ross-Tech.com" rel="nofollow - www.Ross-Tech.com
                Address 01: Engine  (074 906 018 BK)
15:11:49 Group 000
  038
  100
  000
  031
  095
  198
  169
  109
  114
  149
15:11:49 Group 001
  775 /min  RPM
  6.4 mg/str  Inj. Quantity
  1.580 V  Voltage
  18.9°C  Temperature
15:11:49 Group 002
  775 /min  RPM
  0.0 %  Load
   0  1  0  Bin. Bits
  18.9°C  Temperature
15:12:00 Group 003
  775 /min  RPM
  600.0 mg/str  Mass Air / Rev.
  465.0 mg/str  Mass Air / Rev.
  4.8 %  Duty Cycle
15:12:00 Group 004
  755 /min  RPM
  5.1 °BTDC  Ign. Timing
  6.2 °BTDC  Ign. Timing
  80.5 %  Duty Cycle
15:12:00 Group 005
  775 /min  RPM
  30.8 mg/str  Inj. Quantity
  19.8°C  Temperature
15:12:10 Group 006
  0.0 km/h  Speed
   0  0  0  Bin. Bits
  00000000  Bin. Bits
  255.0  (no units)
15:12:10 Group 007
  12.6°C  Temperature
  8.1°C  Temperature
  20.7°C  Temperature
15:12:10 Group 008
  775 /min  RPM
  0.0 mg/str  Inj. Quantity
  26.4 mg/str  Inj. Quantity
  26.6 mg/str  Inj. Quantity
15:12:20 Group 009
  775 /min  RPM
  51.0 mg/str  Inj. Quantity
15:12:20 Group 011
  775 /min  RPM
  1142.4 mbar  Absolute Pres.
  969.0 mbar  Absolute Pres.
  27.1 %  Duty Cycle
15:12:20 Group 011
  775 /min  RPM
  1152.6 mbar  Absolute Pres.
  27.1 %  Duty Cycle
15:12:33 Group 012
  11111111  Bin. Bits
  3.42  (no units)
  14.14 V  Voltage
  20.7°C  Temperature
15:12:33 Group 013
  -0.14 mg/str  Inj. Quantity
  0.02 mg/str  Inj. Quantity
  0.12 mg/str  Inj. Quantity
15:12:33 Group 014
  -0.05 mg/str  Inj. Quantity
15:12:44 Group 015
  775 /min  RPM
  6.0 mg/str  Inj. Quantity
  0.80 l/h  Fuel Consump.
15:12:44 Group 016
  99.6 %  Load
  00000000  Bin. Bits
        00  Bin. Bits
  14.14 V  Voltage
15:12:44 Group 017
15:12:53 Group 018
  0.0 km/h  Speed
        01  Bin. Bits
  0.0 km/h  Speed
  0.0 km/h  Speed
15:12:53 Group 019
  0.740 V  Voltage
  0.000 V  Voltage
15:12:53 Group 020
  755 /min  RPM
  1.580 V  Voltage
  0.0 %  Load
15:12:54 Group 018
  0.0 km/h  Speed
        01  Bin. Bits
  0.0 km/h  Speed
  0.0 km/h  Speed
15:12:54 Group 019
  0.740 V  Voltage
  0.000 V  Voltage
15:12:54 Group 020
  755 /min  RPM
  1.580 V  Voltage
  0.0 %  Load
15:13:04 Group 021
  495.0 mg/str  Mass Air / Rev.
  4.8 %  Duty Cycle
   010 000  Bin. Bits
15:13:04 Group 022
  4.8 °BTDC  Ign. Timing
  80.1 %  Duty Cycle
  0.0 km/h  Speed
15:13:04 Group 020
  775 /min  RPM
  5.8 mg/str  Inj. Quantity
  1.560 V  Voltage
  0.0 %  Load
15:13:30 Group 023
  27.1 %  Duty Cycle
  979.2 mbar  Absolute Pres.
15:13:30 Group 024
  13.5°C  Temperature
  8.1°C  Temperature
  20.7°C  Temperature
  255.0  (no units)
15:13:30 Group 025
And from warmish (it's currently parked up so difficult to get up to temperature.)
15:35:01 Group 000
  038
  108
  000
  026
  096
  198
  123
  114
  119
  137
15:35:01 Group 001
  775 /min  RPM
  5.4 mg/str  Inj. Quantity
  1.500 V  Voltage
  51.3°C  Temperature
15:35:01 Group 002
  796 /min  RPM
  0.0 %  Load
   0  1  0  Bin. Bits
  51.3°C  Temperature
15:35:08 Group 002
  775 /min  RPM
  0.0 %  Load
   0  1  0  Bin. Bits
  51.3°C  Temperature
15:35:08 Group 003
  775 /min  RPM
  660.0 mg/str  Mass Air / Rev.
  445.0 mg/str  Mass Air / Rev.
  24.7 %  Duty Cycle
15:35:08 Group 004
  775 /min  RPM
  5.3 °BTDC  Ign. Timing
  75.7 %  Duty Cycle
15:35:17 Group 005
  775 /min  RPM
  51.3°C  Temperature
15:35:17 Group 006
  0.0 km/h  Speed
   0  0  0  Bin. Bits
  00000000  Bin. Bits
  255.0  (no units)
15:35:17 Group 007
  17.1°C  Temperature
  12.6°C  Temperature
  51.3°C  Temperature
15:35:26 Group 008
  755 /min  RPM
  25.0 mg/str  Inj. Quantity
15:35:26 Group 009
  775 /min  RPM
15:35:26 Group 010
  0.0 %  Load
15:35:33 Group 011
  775 /min  RPM
  25.5 %  Duty Cycle
15:35:33 Group 012
  11111111  Bin. Bits
  3.42  (no units)
  13.91 V  Voltage
  50.4°C  Temperature
15:35:33 Group 013
  -0.19 mg/str  Inj. Quantity
  -0.24 mg/str  Inj. Quantity
15:35:43 Group 014
15:35:43 Group 015
  775 /min  RPM
  0.70 l/h  Fuel Consump.
15:35:43 Group 016
  99.6 %  Load
  00000000  Bin. Bits
        00  Bin. Bits
  13.91 V  Voltage
15:35:53 Group 017
15:35:53 Group 018
  0.0 km/h  Speed
        01  Bin. Bits
  0.0 km/h  Speed
  0.0 km/h  Speed
15:35:53 Group 019
  0.740 V  Voltage
  0.000 V  Voltage
15:36:04 Group 020
  775 /min  RPM
  5.2 mg/str  Inj. Quantity
  1.520 V  Voltage
  0.0 %  Load
15:36:04 Group 021
  655.0 mg/str  Mass Air / Rev.
  24.7 %  Duty Cycle
   010 000  Bin. Bits
15:36:04 Group 022
  77.3 %  Duty Cycle
  0.0 km/h  Speed
15:36:14 Group 023
  25.1 %  Duty Cycle
15:36:14 Group 024
  17.1°C  Temperature
  12.6°C  Temperature
  48.6°C  Temperature
  255.0  (no units)
15:36:14 Group 025
Hope this is what you were after.
Posted By: mojo
Date Posted: 27 Dec 20 at 21:00
Thank you so much for that, really appreciate it.
My fuel injection quantity is pretty much the same as yours now for hot and cold.
A quick look through some old (rough running) logs shows it @ idling around the 4.0 mg/str hot and cold.
I'll get some fresh logs when I get a minute and post them up.
Thanks again mate.
Date Posted: 28 Dec 20 at 16:35
Yes it will be interesting to compare.  I am wondering why your engine should suddenly start running lean without an obvious cause.
Posted By: mojo
Date Posted: 24 Feb 21 at 22:19
Sorry it's took so long, just not had a minute lately and also decided to pour a cup of tea over my laptop which killed it.
I think the fuel quantity adjuster is playing up even though it checks out going by the specs.
The only other way I think the fuel qauntity could change is if the top case of the diesel pump moved which is the 'hammer mod' method of adjusting fuel quantity, but the top is solid with no movement.
When I get time I'll properly investigate it.
COLDISH:
08:17:09 Group 000
  038
  105
  000
  039
  095
  198
  172
  110
  115
  146
08:17:09 Group 001
  775 /min  RPM
  7.6 mg/str  Inj. Quantity
  1.560 V  Voltage
  17.1°C  Temperature
08:17:09 Group 002
  775 /min  RPM
  0.0 %  Load
   0  1  0  Bin. Bits
  17.1°C  Temperature
08:17:27 Group 003
  775 /min  RPM
  475.0 mg/str  Mass Air / Rev.
  4.8 %  Duty Cycle
08:17:27 Group 004
  775 /min  RPM
  78.9 %  Duty Cycle
08:17:27 Group 005
  775 /min  RPM
  30.0 mg/str  Inj. Quantity
  5.5 °BTDC  Ign. Timing
  18.0°C  Temperature
08:17:37 Group 006
  0.0 km/h  Speed
   0  0  0  Bin. Bits
  00000000  Bin. Bits
  255.0  (no units)
08:17:37 Group 007
  14.4°C  Temperature
  9.0°C  Temperature
  18.0°C  Temperature
08:17:37 Group 008
  775 /min  RPM
  26.0 mg/str  Inj. Quantity
08:17:47 Group 009
  775 /min  RPM
08:17:47 Group 010
  470.0 mg/str  Mass Air / Rev.
  0.0 %  Load
08:17:47 Group 011
  755 /min  RPM
  1173.0 mbar  Absolute Pres.
  25.9 %  Duty Cycle
08:17:56 Group 012
  11111111  Bin. Bits
  2.95  (no units)
  14.44 V  Voltage
  18.9°C  Temperature
08:17:56 Group 013
  0.54 mg/str  Inj. Quantity
  -0.40 mg/str  Inj. Quantity
08:17:56 Group 014
  -0.02 mg/str  Inj. Quantity
08:18:09 Group 015
  755 /min  RPM
  7.8 mg/str  Inj. Quantity
  1.10 l/h  Fuel Consump.
08:18:09 Group 016
  99.6 %  Load
  00000000  Bin. Bits
        00  Bin. Bits
  14.44 V  Voltage
08:18:09 Group 017
08:18:20 Group 018
  0.0 km/h  Speed
        01  Bin. Bits
  0.0 km/h  Speed
  0.0 km/h  Speed
08:18:20 Group 019
  0.720 V  Voltage
  4.460 V  Voltage
08:18:20 Group 020
  775 /min  RPM
  1.580 V  Voltage
  0.0 %  Load
08:18:31 Group 021
  485.0 mg/str  Mass Air / Rev.
  4.8 %  Duty Cycle
   010 000  Bin. Bits
08:18:31 Group 022
  79.3 %  Duty Cycle
  0.0 km/h  Speed
08:18:31 Group 023
  1162.8 mbar  Absolute Pres.
  25.9 %  Duty Cycle
08:18:41 Group 024
  14.4°C  Temperature
  9.9°C  Temperature
  19.8°C  Temperature
  255.0  (no units)
WARMISH:
19:38:48 Group 000
  038
  099
  000
  031
  096
  197
  121
  115
  132
  141
19:39:08 Group 001
  775 /min  RPM
  1.540 V  Voltage
  52.2°C  Temperature
19:39:13 Group 002
  775 /min  RPM
  0.0 %  Load
   0  1  0  Bin. Bits
  52.2°C  Temperature
19:39:15 Group 003
  775 /min  RPM
  705.0 mg/str  Mass Air / Rev.
  24.7 %  Duty Cycle
19:39:19 Group 004
  775 /min  RPM
  71.3 %  Duty Cycle
19:39:22 Group 005
  775 /min  RPM
  53.1°C  Temperature
19:39:26 Group 006
  0.0 km/h  Speed
   0  0  0  Bin. Bits
  00000000  Bin. Bits
  255.0  (no units)
19:39:29 Group 007
  28.8°C  Temperature
  13.5°C  Temperature
  53.1°C  Temperature
19:39:32 Group 008
  775 /min  RPM
  25.4 mg/str  Inj. Quantity
19:39:36 Group 009
  775 /min  RPM
19:39:38 Group 010
  0.0 %  Load
19:39:41 Group 011
  775 /min  RPM
  25.1 %  Duty Cycle
19:39:44 Group 012
  11111111  Bin. Bits
  0.00  (no units)
  14.14 V  Voltage
  54.0°C  Temperature
19:39:47 Group 013
  -0.26 mg/str  Inj. Quantity
  0.52 mg/str  Inj. Quantity
  -0.12 mg/str  Inj. Quantity
  0.09 mg/str  Inj. Quantity
19:39:51 Group 014
19:39:55 Group 015
  775 /min  RPM
  6.2 mg/str  Inj. Quantity
  0.90 l/h  Fuel Consump.
19:39:58 Group 016
  99.6 %  Load
  00000000  Bin. Bits
        00  Bin. Bits
  14.14 V  Voltage
19:40:00 Group 017
19:40:05 Group 018
  0.0 km/h  Speed
        01  Bin. Bits
  0.0 km/h  Speed
  0.0 km/h  Speed
19:40:08 Group 019
  0.720 V  Voltage
  4.460 V  Voltage
19:40:13 Group 020
  775 /min  RPM
  1.500 V  Voltage
  0.0 %  Load
19:40:17 Group 021
  700.0 mg/str  Mass Air / Rev.
  455.0 mg/str  Mass Air / Rev.
  24.7 %  Duty Cycle
   010 000  Bin. Bits
19:40:21 Group 022
  73.7 %  Duty Cycle
  0.0 km/h  Speed
19:40:24 Group 023
  25.1 %  Duty Cycle
19:40:28 Group 024
  29.7°C  Temperature
  13.5°C  Temperature
  54.9°C  Temperature
  255.0  (no units)
19:40:34 Group 026
  0387F5C1
