Syncro with ABS
Forum Name: Syncro
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=94460
Printed Date: 16 Apr 24 at 23:47
Topic: Syncro with ABS
Posted By: Andrew
Subject: Syncro with ABS
Date Posted: 13 May 20 at 20:57
Is my van really rare or are there so few syncros with ABS out there?  Looking to fit new brake discs but need the reluctor ring for the ABS sensor if the old one breaks or can't be transferred.  Anyone know where these can be obtained?  1989 T3 syncro ambulance .  Yes, you've seen it at Vanfest some years ago!!
Andrew in Norway
+4790198654
andrew@domkantor.no
Posted By: KrisG
Date Posted: 14 May 20 at 09:24
Is it different from a 2WD with ABS ? not that I have one for you, but just wondering
I even think ABS on a T3 is rare.
Regards,
Kris
Posted By: Andrew
Date Posted: 14 May 20 at 10:54
Yes, on a 2WD the bearing sits in the brake disc which is also the hub.  On a syncro the bearing sits in its own hub and a disc is then mounted on to that.  How on earth the sensor ring is mounted on to the back of the disc afterwards is anybody's guess.  Probably the whole bearing and arm has to come off.  Considering fitting normal discs and coupling out the ABS system.  It works beautifully, but totally unnecessary.
Andrew in Norway
+4790198654
andrew@domkantor.no
