Flushing power steering fluid
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=94298
Printed Date: 23 Sep 20 at 08:23
Topic: Flushing power steering fluid
Posted By: Smithysmoo
Subject: Flushing power steering fluid
Date Posted: 23 Nov 19 at 13:32
Seems like my fluid is contaminated its a grey colour...Before I get a new pump I wandered if it was worth giving it a flush through and see if it lasts.
Any idea on best method for this and what to undo to drain it....
I've got bumper of as I was look at coupling to see if I could do them myself.
Van is a 2.5tdi bnz engine 4 motion.
Date Posted: 23 Nov 19 at 13:39
Sounds like the common leaking seals in the p/s pump problem allowing engine oil in.  If so, you need to fix that first (new pump ?), then flush afterwards.
I haven't done this job myself, but there may be some instructions somewhere in this forum (try a search).
Date Posted: 23 Nov 19 at 13:43
Yeah mate I've been searching all morning...Hence I was wandering if it was worth a flush through and monitoring before shelling out on a pump. Oil is only greyish and not completely black at all and not filling the reservoir as I've heard it can do.
Date Posted: 23 Nov 19 at 14:01
Also is this the correct fluid...Seems to be
https://www.gsfcarparts.com/980vg0140" rel="nofollow - https://www.gsfcarparts.com/980vg0140
Posted By: Charlie Dog
Date Posted: 28 Nov 19 at 12:48
The GSF one appears to be wrong,
See below.
Comma Oil say to use
https://www.commaoil.com/passenger-vehicles/products/view/221" rel="nofollow - Power steering: MVCHF - Central Hydraulic Fluid
https://www.commaoil.com/passenger-vehicles/products/view/221" rel="nofollow - https://www.commaoil.com/passenger-vehicles/products/view/221
in a 2005 Caravelle 2.5 TDI.
I daresay any fluid labelled
CHF11S and CHF202 will do nicely
Until someone corrects me,
I suggest you use a
pump up garden sprayer
to flush your system.
Under 9 quid from Screwfix
https://www.screwfix.com/p/sx-cs5-white-black-pressure-sprayer-5ltr/7490X?kpid=7490X&ds_kid=92700048793290406&ds_rl=1249410&gclid=CjwKCAiA_f3uBRAmEiwAzPuaM6X7G2D9OdTKoxDg9RhJuBuuHdZy9wVAvGT8JbLYFYdbPU4DkcW-8hoCF5sQAvD_BwE&gclsrc=aw.ds" rel="nofollow - https://www.screwfix.com/p/sx-cs5-white-black-pressure-sprayer-5ltr/7490X?kpid=7490X&ds_kid=92700048793290406&ds_rl=1249410&gclid=CjwKCAiA_f3uBRAmEiwAzPuaM6X7G2D9OdTKoxDg9RhJuBuuHdZy9wVAvGT8JbLYFYdbPU4DkcW-8hoCF5sQAvD_BwE&gclsrc=aw.ds
Date Posted: 28 Nov 19 at 12:52
Hi are you sure the GSF stuff is incorrect (I've just ordered a couple of bottles) only it matches spec G-002-000 which is what it specified to use in these vans ???
Date Posted: 28 Nov 19 at 12:55
The one you posted is synthetic based and I'm pretty sure its mineral based that is needed.
Date Posted: 28 Nov 19 at 13:10
Just looked it up on Etka and its showing this code... https://nemigaparts.com/cat_spares/etka/part/G--004000M2/" rel="nofollow - G  004 000 M2   which seems to supersede the other VW code...The Febi stuff from GSF seems to list that its equivalent to both codes. What made you think it was incorrect mate?
Date Posted: 28 Nov 19 at 14:46
I am not sure the GSF stuff is incorrect.
I went by what Comma said for my Reg No.
I've always found them reliable.
I couldn't find anything on the van
on in the manual.
Date Posted: 28 Nov 19 at 14:54
Because Comma fluid is synthetic,
and the GSF is not synthetic.
Perhaps synthetic fluid is better than dino fluid
in the same way that synthetic is better than dino oil.
Comma reckon to be a performance brand.
Date Posted: 28 Nov 19 at 15:04
Some discussion on synthetic v dino here
https://www.google.com/search?q=difference+between+synthetic+and+regular+power+steering+fluid&rlz=1C1GCEA_enGB768GB768&oq=difference+between+synthetic+and+normal+power+&aqs=chrome.1.69i57j0.21989j0j7&sourceid=chrome&ie=UTF-8" rel="nofollow - https://www.google.com/search?q=difference+between+synthetic+and+regular+power+steering+fluid&rlz=1C1GCEA_enGB768GB768&oq=difference+between+synthetic+and+normal+power+&aqs=chrome.1.69i57j0.21989j0j7&sourceid=chrome&ie=UTF-8
Looks like the stuff you ordered is Ok.
While Comma's is either
Catchpenny
or
Kinder to seals / pumps / systems.
Date Posted: 28 Nov 19 at 20:44
On the early vans the 002 spec is actually stamped on the reservoir.  I've stuck with that because when I looked into it, the up-spec was across many vehicles (some were performance petrol engines) and it looked to me that the new spec mostly coped with higher temperatures where parts of the PAS ran close to hot turbos etc.  Personally, I'm taking the risk.
2004 2.5 174
Date Posted: 28 Nov 19 at 21:23
Originally posted by T5 TDI T5 TDI wrote:
On the early vans the 002 spec is stamped on the reservoir.  I've stuck with that because when I looked into it, the up-spec was across many vehicles (some were performance petrol engines) and it looked to me that the new spec mostly coped with higher temperatures where parts of the PAS ran close to hot turbos etc.  Personally, I'm taking the risk.
Where is it stamped on your reservoir please?
Date Posted: 28 Nov 19 at 21:26
Here's the Technical Data Sheet for the Comma fluid.
I couldn't find one for the Febi-Bilstein fluid, sorry.
Date Posted: 29 Nov 19 at 10:08
If yours has it, it is on the reservoir just below the neck, facing you as you open the bonnet I think.
2004 2.5 174
Date Posted: 29 Nov 19 at 10:19
You can just see it if you zoom in on this second hand reservoir.
https://www.ebay.co.uk/itm/VW-TRANSPORTER-T5-T30-2003-2009-POWER-STEERING-RESERVOIR-BOTTLE-P-N-7H0422371A/153666889432?fits=Car+Make%3AVW%7CCars+Year%3A2004&epid=1717056959&hash=item23c742a6d8:g:it0AAOSwQLZdk0sf
Can't believe he wants £19 for that crappy old thing! LOL
2004 2.5 174
Date Posted: 29 Nov 19 at 10:31
Thanks T5.
Yeah, he's way out with that price isn't he?
One here, new, for less.
https://www.vwheritage.com/7h0422371a-power-steering-fluid-reservior-tank-vw-spare" rel="nofollow - https://www.vwheritage.com/7h0422371a-power-steering-fluid-reservior-tank-vw-spare
Date Posted: 02 Dec 19 at 08:19
Got a bit of techie guff from Febi.
Their power steering fluid
is about as runny as Comma's at 40C.
Looks like Febi aren't strong on technical :-(
I find that weird in a German company.
I don't know about you,
but it would put me off 'em.
Here's their technical data sheet.
https://partsfinder.bilsteingroup.com/en/article/febi/06162" rel="nofollow - https://partsfinder.bilsteingroup.com/en/article/febi/06162
