RPM fast idle setting 1.9DG
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=94239
Printed Date: 25 May 20 at 15:20
Topic: RPM fast idle setting 1.9DG
Posted By: FreebirdJussy
Subject: RPM fast idle setting 1.9DG
Date Posted: 18 Sep 19 at 21:55
Hi Guys, can anyone tell me the RPM for the fast idle setting please? 1984 1.9DG water-cooled.
1984 VW T3 1.9DG Petrol Water-cooled
Date Posted: 19 Sep 19 at 00:30
There's the normal idle setting at front of carb and fast idle setting at back of carb???
"Fast idle should also be adjusted hand in hand with the choke pull-down diaphragm but when the engine is warm and at normal operating temperature.
    https://s0.wp.com/wp-content/themes/pub/vigilance/images/list-star.gif"" rel="nofollow - https://s0.wp.com/wp-content/themes/pub/vigilance/images/list-star.gif" ;); background-position: 0px 0.3em; background-repeat: no-repeat no-repeat;">Position the fast idle cam screw by turning it in or out to the second step of the fast idle cam and check that the fast idle speed is between the specified 2000 +/- 200 rpm for fast idle. Adjust as neccessary"
I'm getting a bit lost here. My engine is idling at around 900RPM in normal circumstances. What is fast idle???
Date Posted: 19 Sep 19 at 14:56
Got it now Clap
