Cylinder numbering 6cyl diesel
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=93889
Printed Date: 24 Jun 19 at 23:35
Topic: Cylinder numbering 6cyl diesel
Posted By: Highland_exile
Subject: Cylinder numbering 6cyl diesel
Date Posted: 10 Jan 19 at 14:24
Hi all
Just taken onwership of a LT31 distance wide with a few 'issues'
First thing I need to sort out is the leaking fuel pump. I have done plenty reading up on setting the timing, but one query, which is 1 cyl? Timing belt end or flywheel end?
Ta
Pete
91 LT31 Karmann Distance Wide camper
Posted By: clift_d
Date Posted: 10 Jan 19 at 15:51
Cylinder 1 is the one nearest the cam belt - check the engine manual at this link:
https://www.mediafire.com/folder/d90hbt7ndxl54/LT_Manuals" rel="nofollow - https://www.mediafire.com/folder/d90hbt7ndxl54/LT_Manuals
1988 1.6TD Westfalia Club Joker syncro
Date Posted: 10 Jan 19 at 23:53
Ta, just want
Date Posted: 10 Jan 19 at 23:58
^^ sorry slight cock up there^^
Thank you, confusion came on due to my background in marine engineering, as virtually all ships engines are numbered from the drive/flywheel end.
