vw lt28
Category: Auto Jumble
Forum Name: For Sale
Forum Description: Got stuff that's been clogging up your shed for the last 7 years. Offer it to the needy here.
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=93652
Printed Date: 18 Apr 24 at 06:02 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: vw lt28
Posted By: slyman 1
Subject: vw lt28
Date Posted: 12 Aug 18 at 22:44
my old vw 28 was vandelised, they smashed the windscreen and some side panel glass, it was starting to rot around scree window, it has working lights front and back, an out of Africa roof rack, and ladder on short barn doors(under the hightop).a 2.4 4speed petrol 6pott engine, which im confident will start with fresh jusice a 12 volt.s some of the wheel nuts are seiezed, its in cornwall just outside Plymouth on private land. im basically thinking if there is anything on it anyone wants befoer a take an angle grinder to it, to cut it up and scrap, just get in touch the seats are not original, but the dash is complete, I posted pics along time ago but could not find my old posts guessing website rebuild since then. I joined when dave started doing lpg conversions kits in vw's. it was blue and yellow, with custom fairies air brushed on rear panels, the roof rack is good 25mil box steel fixed through the hightiop to the inside steel above gutters. ill take pics later this week, if theres anything I mean anything, people may want let me know. if someone wants to come collect it on recovery vehicle quite welcome to do that for no cost. had repolaced the passenger door, brakelines and welded some of the lower panels. and battery box one side around wheel arches, replaced stearing box, had weber twin chike befurbished, and the dizzy refurbished too. I also have the mirriors and stuff too somewhere in my lock up gutted they did it was going to amkle itto a non traveling caravan its got the 240 hoot up although the wires have been snipped to get quick acess to the welding on rear floor as mentioned. im quite happy to see it go even if donor for doors and roof rack and weheel hubs and engine ect the engine is sweet I used to not be able to hear it idle which is something when you think its right next to the drivers seat 6 pott that's why.
simon 0745640012
Posted By: slyman 1
Date Posted: 12 Aug 18 at 22:47
also to go with IT OR SEPERATE,a full LPG tank spare wheel shapeD going for free to collector post code PL101NZ NOT ATTACHED TO VAN
Posted By: 1994LT35MINIBUSCAMP
Date Posted: 02 Oct 18 at 14:12
Hi don't suppose you have the accelerator pedal assembly mines is shot
------------- Michael
Posted By: lorryloader
Date Posted: 06 Dec 18 at 17:29
Hi do you still have your LT ?
------------- LT-45 HIGH TOP + LT-55-BEVERTAIL.Mercedes Atego tilt n slide with lorry loader crane.
