Independant VAG Specialist
Category: The Brickyard
Forum Name: The Brickie's Arms
Forum Description: THE online pub for the discerning Transporter owner, Come in, Kick back and settle with a pint and talk cobblers.
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=93643
Printed Date: 16 Apr 24 at 07:19
Topic: Independant VAG Specialist
Subject: Independant VAG Specialist
Date Posted: 09 Aug 18 at 18:34
Hi Guys,
Can you recommend anyone in South Wales, my Audi A6 2.5tdi won't rev over 3k.
I'm changing the cheaper sensors myself, coolant temp etc, but will probably need an expert diagnosis.
Have VCDS and it only shows 1 error code - 00575 Intake manifold pressure, 11-10 Control limit not reached.
Andy
LT28 1979 2.0 Pampas Nevada Camper LPG 93K, 1980 T3 A/C Camper 98K,1994 RRC 3.9 LPG 120k , 1998 Audi A6 Est 2.5 V6 diesel 127k
Posted By: ob1
Date Posted: 09 Aug 18 at 20:35
That’s in limp mode due to intake boost leaks / intercooler failure I’d guess?
Date Posted: 09 Aug 18 at 22:07
Not happy for sure, have vac tubing on the way, will change every bit I can find, also have coolant and oil sensors ordered.
Don't want someone who changes very expensive parts until it's fixed or not, you just get the bills.
Haven't dismantled the turbo, but the VNT mechanism moves fine by hand.
Posted By: doug
Date Posted: 09 Aug 18 at 22:41
That failure code should originating from your map sensor
Manifold absolute pressure
It will be situated on your turbo to intake run
As suggested could be the pipes are leaking thus no pressure reading or variable vane turbo is sticky thus over boosting
Both will trigger limp mode
The sensor it self could be at fault
Good luck
http://www.facebook.com/home.php#!/group.php?gid=111314692238141&ref=ts
Posted By: randolph57
Date Posted: 11 Aug 18 at 10:27
That code certainly indicates not enough boost achieved when related to boost expected. Could be vacuum lines as stated boost hoses to inlet manifold split/leaking /leaking intercooler or possibly failed Vnt vacuum can on turbo. Does the vnt arm move approx 15mm to its 'stop'when engine started?
Other possibilities could be a defective N75 valve meaning your turbo would be basically doing not a lot with no control over turbo nozzle ring. Plenty of them in local scrapyards .
Date Posted: 13 Aug 18 at 20:21
Thanks for the replies guys, got sent the wrong size vac tubing so not much progress so far.
Hopefully tomorrow will have VCDS & Elsawin running on an old laptop, and will be doing some graphs which might narrow things down a bit.
I've identified some of the sensors and valves but there are shed loads of em.
