Clutch problem...
Forum Name: Syncro
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=93637
Printed Date: 19 Apr 24 at 10:34 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Clutch problem...
Posted By: Rotabat2
Subject: Clutch problem...
Date Posted: 06 Aug 18 at 12:13
Hi all. The clutch on my syncro is 'drawing in' air, or something similar. There are no leaks from the master or slave cylinder. I'm fine driving about town, all works great. But after a long period on the open road, it's really difficult to change down the gears. I pull into the services, crack the bleed nipple, there's a pause, then a few bubbles, then we're good to go. Clutch works fine. Until it happens again!
Is this more likely to be the master cylinder or slave cylinder causing the problem,and which should I change first?
Also, as far as other hardware is concerned, do I just need the metal banjo seals?
Posted By: ob1
Date Posted: 06 Aug 18 at 15:18
Change the slave cylinder. Seals have failed and it’s drawing air as it get warm.
Mine did the same for a year or so and then suddenly failed completely. I’d bite the bullet and change it before then.
Posted By: Rotabat2
Date Posted: 06 Aug 18 at 15:50
Thanks for that! It's what I wanted to hear... Looks like a simple enough job. Any pitfalls?
Posted By: ob1
Date Posted: 07 Aug 18 at 11:59
You end up replacing the clutch pipe further and further up the van as the old unions snap and round off!
Date Posted: 07 Aug 18 at 14:49
yup, and then try and find the odd diameter copper/cunifer pipe!!
Posted By: Rotabat2
Date Posted: 08 Aug 18 at 09:14
Yes. I can see what might go wrong... Whilst waiting for the hardware, I'm liberally soaking all the components that need disconnecting, in release fluid. The pipe unions themselves don't look too old.... but time will tell!!
