LT28 Window rubbers
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=93468
Printed Date: 16 Apr 24 at 06:51
Topic: LT28 Window rubbers
Posted By: Flipflop75
Subject: LT28 Window rubbers
Date Posted: 15 May 18 at 14:19
Hi!
I've recently acquired an LT28 2.0 Petrol 1977 and...it needs some work!
It currently doesn't have an MOT and has been kept in a poor state.
Of the many things that need replacing are the side window rubbers. Wheres the best place for that?
Thanks in advance.
http://s988.photobucket.com/user/flipfloppp/media/VW%20LT%20MK1%20Petrol%2020%201977/IMG_3265_zpsbofx8qhd.jpg.html" rel="nofollow">
http://s988.photobucket.com/user/flipfloppp/media/VW%20LT%20MK1%20Petrol%2020%201977/IMG_3243_zpsikpxr6qg.jpg.html" rel="nofollow">
http://s988.photobucket.com/user/flipfloppp/media/VW%20LT%20MK1%20Petrol%2020%201977/IMG_3242_zpseeynasj7.jpg.html" rel="nofollow">
VW LT 2.0 1975
VW Beetle 1.2 1971
Posted By: nooberdoober
Date Posted: 16 May 18 at 01:06
well, you could try here for starters:
http://www.brick-yard.co.uk/forum/some-useful-links-parts-etc_topic29314.html" rel="nofollow - http://www.brick-yard.co.uk/forum/some-useful-links-parts-etc_topic29314.html
I got me a 2.4 straight Six......and it's a soundin JUICY!
1984 LT40 2.4 petrol Coachbuilt Autotrail Motorhome
Posted By: Serge
Date Posted: 16 May 18 at 09:21
Try on here:
http://www.facebook.com/groups/voltswapmeet/?ref=gs&fref=gs&dti=24899769420&hc_location=group" rel="nofollow - http://www.facebook.com/groups/voltswapmeet/?ref=gs&fref=gs&dti=24899769420&hc_location=group
1990 LT28 Westfalia Florida 2.4TD + Reliant Scimitar GTC + Mk 4 Mondeo + Triumph Trident Sprint 900 + Honda 550/4
http://www.sergeantsmess.co.uk/" rel="nofollow - http://www.sergeantsmess.co.uk/
Date Posted: 16 May 18 at 12:23
COH Baines, and probably others, do a vast array of weatherstrip, one of which will be suitable for the side windows.
The front door window scrapers are all available through Brickwerks; cut down versions of the t3 parts.
Date Posted: 17 May 18 at 13:18
Thanks for the info.
Yes I did checkout the useful parts link first and there is rubber/ trim supplier first. Was just hoping have a one-stop-shop were I could just order a set.
Its what I did with my 1971 beetle.Smile
Wanted to have a set standing by, ready to fit, but I guess I need to remove a window to check out the cross section.
VW LT 2.0 1975
VW Beetle 1.2 1971
Date Posted: 18 May 18 at 12:15
If you can measure the glass, metal thickness and overall width you will not be far away.
There is not an industry based around LTs like there is for all the other VWs.
Owning one requires an amount of work but the support network is worth it.
Posted By: Buss Marius
Date Posted: 18 May 18 at 12:53
Sinse Your van is a converted panelvan i think some thing like this is the right part for your van. https://www.justkampers.com/vw-T3-parts/T3-seals-trims-accessories/window-seals/insert-seal-5m-length-for-use-with-j11378.html" rel="nofollow - https://www.justkampers.com/vw-T3-parts/T3-seals-trims-accessories/window-seals/insert-seal-5m-length-for-use-with-j11378.html
87 Karmann LT L 2,4D. 89 T3 Syncro Reimo 1,9TD. 2000 T4 Caravelle TDI
