Hi, I am newbie here. My van is Transporter T5 2008. One week ago it's got an issue. When I turn on right turn or left turn switch, there is no any indication on display and on any switching sound. But fortunately turn lights on the car body works. Also there is no display lighting, but many lamps works. I have scanned by VAG-COM and got this: Chassis Type: 7H - VW Transporter Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56 57 6E 76 77 78 7D VIN: WV2ZZZ7HZ8H13xxx5 ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No SW: 038 906 016 M HW: 028 101 185 6 Component: R4 1,9L EDC G000SG 6278 Revision: 12345678 Serial number: VWZ7Z0H629xx08 Coding: 0151031 Shop #: WSC 02756 790 00000 1 Fault Found: 18045 - Powertrain Data Bus: Missing Message from Electric Load Controller P1637 - 000 - - Freeze Frame: RPM: 1953 /min Torque: 80.0 Nm Speed: 63.0 km/h Load: 33.3 % Voltage: 14.74 V Bin. Bits: 00101000 Bin. Bits: 00000000 (no units): 0.0 Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 7H0-907-37x-ESP.lbl Part No SW: 7H0 907 379 R HW: 7H0 907 379 R Component: ESP MK25E1 0104 Revision: 00H31001 Coding: 0000555 Shop #: WSC 02756 790 00000 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl Part No: 1C0 909 605 A Component: 3C AIRBAG VW51 0010 Coding: 13123 Shop #: WSC 02756 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl Part No: 7H0 920 852 A Component: KOMBI+WEGFAHRSP VDO V03 Coding: 00103 Shop #: WSC 00136 WV2ZZZ7HZ8H130785 VWZ7Z0H6295508 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: Redir Fail! Part No: 7H0 815 071 F Component: Standheizung 0209 Shop #: WSC 00000 000 00000 1 Fault Found: 00457 - Control Module for Network (J519) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 02756 1 Fault Found: 01322 - Control Module for Multi-Function Unit (MFA) (J501) 49-00 - No Communications ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: Redir Fail! Part No: 7H0 951 171 B Component: Innenraumueberw. 2920 Coding: 0000021 Shop #: WSC 02757 790 00000 No Faults Found or DTCs not supported by controller or a communication error occurred End --------------------------------------------------------------------- Also there is no access to:Address 09: Cent. Elect. Address 46: Central Conv. Need your help!
------------- T5 2018
