JX hairline crack on piston
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=93380
Printed Date: 23 Jan 19 at 00:16
Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: JX hairline crack on piston
Posted By: akw
Subject: JX hairline crack on piston
Date Posted: 03 Apr 18 at 14:46
Hiya,
While I was close I pulled the cylinder head off my engine.  The head was badly cracked and is scrap so got a new one.  While cleaning the block/pistons I noticed what looks like a small crack on no2 piston:
https://photos.app.goo.gl/WfR0AEPLQcM2OVRT2" rel="nofollow - https://photos.app.goo.gl/WfR0AEPLQcM2OVRT2
Is this something that can be ignored or am I in for a bottom end rebuild now too?
The other pistons look fine and the block seems in good shape.  The honing marks still visible but I've not measured the bores properly yet.
Thanks!
'90 T3 Bluestar
Date Posted: 04 Apr 18 at 08:45
you need to ascertain wether it is cracked or not chap - engineers blue??
if it is you need to replace
Posted By: akw
Date Posted: 04 Apr 18 at 12:12
Thanks.  I'll clean it up a bit more and try doing a dye penetrant inspection to be sure.
Unfortunately I'm in a bit of a pickle here because I'm due a trip to Portugal at the beginning of May.  This realistically leaves me 3 weekends to put this engine back together (and I'm just a backyard 'mechanic').   I may have to slap the new head on, do the trip and pull the engine out afterwards to rebuild it properly.  A lot of extra work unfortunately.  I just hope it won't disintegrate on me.
'90 T3 Bluestar
Date Posted: 04 Apr 18 at 12:24
I really wouldnt be heading to portugal with a cracked piston
I have some JX pistons here (still in the lump)
If you want I can remove and send you one?
Posted By: akw
Date Posted: 04 Apr 18 at 12:44
That would be amazing if you could.
I'm not sure what size piston it is though.  The markings on it are:
810
E
0701
Don't seem to correspond to any of the sizes in the manual as far as I can see.
I can get the bore measured on Friday (waiting for tools to arrive) and get a correct size piston + rings from BW if necessary.
Other than the piston + rings, what else do I need to replace?  Can the old bearings be re-used? (given it's more or less a temporary measure).
'90 T3 Bluestar
Date Posted: 04 Apr 18 at 16:48
before you do fuck all else, verify you actually have a problem chap...
https://en.wikipedia.org/wiki/Dye_penetrant_inspection" rel="nofollow - https://en.wikipedia.org/wiki/Dye_penetrant_inspection
^^ should be possible to do en-situ
Posted By: akw
Date Posted: 04 Apr 18 at 17:42
Yeah, definitely.  Ordered the DPI kit this morning, should be here on Friday so will give that a go before touching anything else.
Looking at a zoomed pic it doesn't look great though:
https://photos.app.goo.gl/FHJPO0H7JV3ifta53" rel="nofollow - https://photos.app.goo.gl/FHJPO0H7JV3ifta53
'90 T3 Bluestar
Posted By: akw
Date Posted: 06 Apr 18 at 17:52
Just did the crack test and it doesn't look great:
After a bit more clean up, piston no1 has cracks too:
cracked piston no1
I think I'm going to pull the engine out of the van and take the block to my machine shop.  With a bit of luck they may be able to rebuild it for me on time.
'90 T3 Bluestar
Date Posted: 06 Apr 18 at 18:38
wise move.
Posted By: Pete Westy
Date Posted: 06 Apr 18 at 18:59
You could drop the sump and change the pistons with the engine in situ. You've done most of the work getting the head off. Almost certainly quicker than taking out and sending to your local machinist. You can check the bearing shells at the same time.
Pete
I've spent so much time under the Atlantic I'm changing my name to Titanic.
Posted By: akw
Date Posted: 08 Apr 18 at 22:17
Yeah, I have considered it, but decided to do it properly even if that means delaying trip a little  (hopefully not).  Once it's done it should be good for some years.
I don't know the history of that engine.  The PO put it in when the original got tired.  I have no idea how many miles it clocked.  It run alright after the usual tappets/timing treatment so I left it alone.
I dropped it out and stripped this weekend.  Was surprised how small the block looks without all the auxiliaries.  Here it is sitting in my conservatory:
No real issues getting it out so far which is unusual Big smile Getting the injection pump sprocket off without a puller was the hardest bit but managed to pop it off using the two chisel method.  All went smooth after that.  Used up all the biscuit tins in the house for parts...
'90 T3 Bluestar
Posted By: akw
Date Posted: 12 Apr 18 at 23:51
In the end I got a rebuilt block from AW Engineering as it was the fastest option and comes with a good rep.  Arrived today on a pallet, nice and black:
With a bit of luck it'll be running again this weekend
'90 T3 Bluestar
Posted By: clift_d
Date Posted: 16 Apr 18 at 09:52
A good decision I think.
1988 1.6TD Westfalia Club Joker syncro
Posted By: akw
Date Posted: 18 Apr 18 at 00:51
Engine back in the van with new cylinder head and rebuilt injectors (GTD nozzles from BW, set to 155 bar)
Still few bits to go but I'm getting there.  So far on target time wise.  Spent a bit too much time dicking around cleaning and painting rusty bits and pieces...
'90 T3 Bluestar
Posted By: dave friday
Date Posted: 18 Apr 18 at 10:23
Just so your prepared; you might have to drop the gearbox down a long way because the head( and other bits ) snag on the support bars...ask me how I know!!
1992 1.6td syncro
Posted By: akw
Date Posted: 18 Apr 18 at 13:29
I don't think I understand, drop the gearbox?
I have the engine supported from the bottom on a jack while one of the support bars is out, but yeah it is twisted a bit at the moment.  I'm hoping it'll be straight once I put the other support bar in.
'90 T3 Bluestar
Date Posted: 18 Apr 18 at 18:11
I meant drop the back of the gearbox,as you've got the engine your ok.
1992 1.6td syncro
Posted By: akw
Date Posted: 25 Apr 18 at 00:18
Put it all back together this weekend.  All the little bits took the most time.
Went to get it started, pressed on the clutch and snap!  The release bearing has slipped of the forks... Must have cocked it up when mating the engine with the box.
Anyway, got it fired up after some hoofing and poofing and off it went.  Sounded like shit the first time, but I guess that's normal for fresh rebuild.  Rings not seated in yet, air in the fuel lines etc.  I must say I was shitting my pants while I was cranking it.
Warmed it up, nipped up the head bolts 1/4 turn.  Changed oil + filter.
Gearbox out, new release bearing in (had a spare knocking around luckily), gearbox back in, exhausted, sleep Ouch
Lots of little jobs next day before I fired it up again.  It started easier, lumpy when cold but sorted itself out a bit after a while.  Took it for a quick spin around the block.  Some oil leaking from the sump, nothing tragic.  Nipped up the sump bolts a notch and left it.
Today test drive #2.  Took it for an hour around county roads, some carriage way, varied conditions.  No more leaks!  The engine seems to have sorted itself out, smoother, quieter (for a jx).  Took it very easy but it definitely feels like it has more guts.  Removing the old cat converter must have helped too Big smile
As an added bonus my breaks now work properly after replacing the vacuum pump. Result!
It was a lot of work but overall pretty happy with it so far.  The Portugal trip is due in two weeks.  I'm aiming to clock 500miles before to run it in properly, do the final head bolts nip up and gain more confidence in it.  Fingers crossed and thanks for your help!
'90 T3 Bluestar
Posted By: ob1
Date Posted: 25 Apr 18 at 14:48
Nice. Bet you were gutted to have to drop the box!
I expect you know better than I but I thought modern steel layered head gaskets do not need additional torquing?
I presume the engine recon gave you specific instructions otherwise?
Posted By: akw
Date Posted: 25 Apr 18 at 16:33
Yeah, dropping the tranny wasn't fun, but I did it before so it went pretty quick.  Mating it back with the engine is always a bit of a wiggle...
I'm following instructions that came with the Elring head gasket.  It's mostly fibre I think with metal rings around the bores:
http://www.brickwerks.co.uk/cylinder-head-gasket-t3-1-6d-td-2-notch.html" rel="nofollow - https://www.brickwerks.co.uk/cylinder-head-gasket-t3-1-6d-td-2-notch.html
Using new Elring set of bolts too.  I just hope they don't snap! Dead
'90 T3 Bluestar
Posted By: akw
Date Posted: 26 Apr 18 at 02:03
Went for another drive today, engine seems nice.  Started on the button cold for the first time which was nice Big smile
However I'm getting a slight clunking noise from the rear now, most noticeable when changing up gears.  Also happens when sharply accelerating/decelerating.  Last time I heard that clunk I replaced all CV's and it went away but that was only 10k miles ago!
The engine mounts are new and gearbox mount replaced recently too.  Checked all the nuts and bolts, all looks tight.
No noticeable play in the driveshafts, but I'm going to re-pack the CVs with more grease to see if that helps.
Anything else I should be looking at?
'90 T3 Bluestar
Posted By: ob1
Date Posted: 26 Apr 18 at 07:20
Ah that’s good. Don’t think you’d snap the head bolts. It’s a horrible feeling though as they start to stretch.
Especially when you reuse them. Which I don’t. But have done to get home with a cheap cylinder head swap. Reused the gasket as well on that occasion. Went okay for a few more thousand miles before the disintegration of the bottom end finally killed it.
Posted By: RogerT
Date Posted: 27 Apr 18 at 10:23
Clunk? I had similar, but on cornering as well. Discovered my offside outer rear suspension mount was starting to let go of the sill, nearside not far behind. Don’t worry, I’m sure it’s not that though for you.
Posted By: akw
Date Posted: 30 Apr 18 at 23:32
I took apart my CVs, cleaned them up, re-greased.  Not much wear there at all as expected.  One was a little bit stiff if anything.
While I had them out I had a little fiddle with the drive flanges.  There is a little bit of back/forward play.  Is that ok?  No up/down in/out play at all.  Here's a vid:
http://www.youtube.com/watch?v=3jofpBWAXQ0" rel="nofollow - https://www.youtube.com/watch?v=3jofpBWAXQ0
I checked an old box I have in the shed and it also has a similar amount of play.  I suspect this is probably fine.
Other than that I didn't find anything unusual.  Checked all the mounts are tight, suspension looks fine too.  No noise when cornering.
The cluck is very very minor.  Mostly when shifting from 1st to 2nd.  Passengers don't notice it.  Maybe it's just my paranoia :-). It doesn't bother me as long as it's not a symptom of something bigger.
The new rubber engine mounts seem a little on the soft side, but that's very subjective.
I clocked just under 400 miles so far.  No problems to report Big smile  Heading to Portugal this weekend after the 500 mile service.
'90 T3 Bluestar
Forum Software by Web Wiz Forums® version 11.10 - http://www.webwizforums.com
Copyright ©2001-2017 Web Wiz Ltd. - https://www.webwiz.net
