Engine temp sensor
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=92931
Printed Date: 28 Mar 24 at 11:50 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Engine temp sensor
Posted By: mattm123
Subject: Engine temp sensor
Date Posted: 14 Aug 17 at 21:16
Really basic question... I'm still learning a lot. Where is the engine temp sensor on a jx engine and how can I test it's working? Is it the black plug sensor by the gearbox end injector , behind the metal top hat thing with a yellow and brown wire?
https://goo.gl/photos/ermE1PrzA5SRwXM69" rel="nofollow - https://goo.gl/photos/ermE1PrzA5SRwXM69
My problem is the temp needed in dial in the dash moves to the thick white mark when up to temp , sometimes even to the edge of that mark but never any further so I'm guessing there is a sensor fault.
Can I ground one of the wires on the plug going into the sensor to test the dash guage?
Sorry for all the questions.......
Posted By: mattm123
Date Posted: 15 Aug 17 at 19:38
For future people, on a jx yes it is the black one with the yellow and brown wires. And yes if you jump the two wires on the plug with the ignition on the guage ( if working will shoot up to the top and the led will blink)
So a new sender needed for me!
