two stage injectors and jx pump
Forum Name: T3 Diesel upgrades
Forum Description: Trial forum for dicking around with Rudolfs finest.
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=92303
Printed Date: 25 Apr 18 at 11:46
Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: two stage injectors and jx pump
Posted By: mrmee
Subject: two stage injectors and jx pump
Date Posted: 04 Jan 17 at 17:31
Will the two stage injectors from the aaz work with the standard jx pump. They are 150bars so in theory they should work just fine, and are quieter..?
Posted By: radje69
Date Posted: 13 Feb 18 at 12:54
Same question here, will a 2 stage injector do its work efficiently with a JX dieselpump meant for 1 stage injectors?
Does the JX pump(cam plate) need an upgrade to run the two stage injectors  ?, Has anyone done this?
Grtz Radje
Radje69
Date Posted: 13 Feb 18 at 13:03
As I understand it, injectors are matched to the cam plate in the pump. If the pump had dual stage cam plate then you need dual stage injectors. I believe the cam plate ramp has a step in it to initiate the first stage then ramps up for the second stage.
Sticking a JX pump on a AAZ with JX injectors seems to give the best results but leaves you with a lack of adjustment on the LDA. LDA can be tweaked and twiddled a little.
Posted By: radje69
Date Posted: 14 Feb 18 at 06:01
Is it possible to modify a JX pump to run the 2-stage injectors? Are cam plates for JX and AAZ/1Z interchangeable? If they are , do you need to modify other components of the JX pump?
Grtz Koen
Radje69
Date Posted: 14 Feb 18 at 13:21
Why?
Posted By: radje69
Date Posted: 14 Feb 18 at 14:06
Is it possible to give a correct answer to the question: "Why?" ?
The main answer would be to give it a try.
Why?
Everybody is converting AAZ pumps with JX covers, isn't it possible to convert a JX pump with an AAZ cam plate?
Why go for a modified AAZ pump if you can modify your JX pump? (if it is technically possible)
Grtz Koen
Radje69
Forum Software by Web Wiz Forums® version 11.10 - http://www.webwizforums.com
Copyright ©2001-2017 Web Wiz Ltd. - https://www.webwiz.net
