overhaul parts needed
Forum Name: South African T3s
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=92302
Printed Date: 20 Apr 24 at 07:57 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: overhaul parts needed
Posted By: monkslayer
Subject: overhaul parts needed
Date Posted: 04 Jan 17 at 15:53
Hey everyone,
I am a newbie both to the forum and the T3 world. I have a south African T3 vin number: AAVZZZ25ZMU002835. Engine number : AY002419. I can't seem to find any parts based on the details provided. Does anyone know the reference OEM numbers for the following parts:
Piston rings( 82.5,1.5,1.5,2) Crankshaft main bearings Cylinder head gasket
Thank you in advance.
cheers!
------------- MONK
Posted By: marlinowner
Date Posted: 04 Jan 17 at 18:27
Think pistons and rings are the same as golf 2.0 16v at 82.5mm bore and same stroke as South African 2.5 AAY engine? Main bearings will (I presume) be the same as other Audi 5 cylinder engines eg Audi 100 2.2l. Apparently head gasket is same as Audi 7a 2.3 20v
I am prepared to be corrected though, as I have never actually needed these parts...
Should add that I have a South African T3 with the AAY engine.
Posted By: Wychall
Date Posted: 04 Jan 17 at 18:42
Try sending a PM to T3 NEV on this forum. I know that he has extensive experience in getting his hands oily in the AAY engine.
(I also have a 2.5 AAY SA T3)
------------- South African 1991 2.5i 5cyl Microbus - virgin, not campered - piloted by Brian.
Date Posted: 05 Jan 17 at 04:55
Cheers guys. It is a 2.5i. Will PM neil and see his reaction. I'm welcome to many more ideas!
------------- MONK
Posted By: T3 Nev
Date Posted: 05 Jan 17 at 10:10
Happy New Year to you all.
Golf 16v rings won't do as top ring is 1.2mm instead of 1.5mm thickness needed. Will have a look see what I have. What size of bearings are you wanting? Audi 2.3 20v 7a cyl head gasket is the same as are the bearings.
Will be sadly breaking my 1992 2.5 AAY SA in the next few months so all parts will be available. Vehicle in Spain at the moment but will be bringing back to the UK as mot expires end July.
Date Posted: 05 Jan 17 at 11:00
Hey,
Nev is right . I checked the golf and they are 1.2 at the top which is too thin.My bearings are standard . Any idea where I can get the rings,cylinder head gasket and bearings ?
------------- MONK
Date Posted: 05 Jan 17 at 16:28
Try part number 053198151B for the ring set and 054103383J for the head gasket.
Date Posted: 05 Jan 17 at 16:50
Hey marlinowner,
Thanks for the feedback. Checked out the part numbers provided and seems i can only find them on ECS tuning. I did however do my own checks and found the following reference numbers:
Piston rings: 044198151 Cylinder Head gasket:023103383B Crankshaft bearings: 034198491D
Could you confirm if these are relevant to the AAY engine? seems they are part numbers for the Eurovan with the same 2.5L engine.i found them on http://www.jimellisvwparts.com" rel="nofollow - http://www.jimellisvwparts.com .
Anyone used this site to order parts?
Thank you in advance .
------------- MONK
Date Posted: 05 Jan 17 at 17:31
Eurovan is US name for T4, 2.5 petrol engine is code AAF, it's not the same as the South African AAY. Bore is 81mm. The part numbers I gave were from the South Afrcan T3 2.6 litre engine which replaced the AAY and is better documented. It has the same bore at 82.5mm, as does the 7a 20v 2.3 Audi engine. See http://www.oemepc.com" rel="nofollow - http://www.oemepc.com
Date Posted: 05 Jan 17 at 17:38
Does that mean that the piston rings, crankshaft main bearings and cylinder head gasket are the same as the 2.5 AAY?
------------- MONK
Posted By: T3 Nev
Date Posted: 05 Jan 17 at 17:41
monkslayer wrote:
Hey,
Nev is right . I checked the golf and they are 1.2 at the top which is too thin.My bearings are standard . Any idea where I can get the rings,cylinder head gasket and bearings ? |
Try gsf using 7a engine code. As for rings, when do you need them as I have 2 sets back in the UK.
Posted By: T3 Nev
Date Posted: 05 Jan 17 at 17:46
[QUOTE=monkslayer] Does that mean that the piston rings, crankshaft main bearings and cylinder head gasket are the same as the 2.5 AAY? [/QUOT
7a all the way except for the rings as they are different.
Date Posted: 05 Jan 17 at 17:48
As for the rings, I need them like yesterday. ;-)
------------- MONK
Posted By: T3 Nev
Date Posted: 05 Jan 17 at 17:59
[QUOTE=monkslayer] As for the rings, I need them like yesterday. ;-) [/QUOT
Just seen that you are in Kenya. Best bet is to get the rings directly from VW South Africa.
Date Posted: 05 Jan 17 at 18:03
The ring part number I gave is specced at 82.5, 1.5, 1.5, 2.0 and is used on SA T3 2.3 and 2.6 as well as 7a, is it different to AAY?
Date Posted: 05 Jan 17 at 18:08
it is the same,let me check the links provided.
------------- MONK
Date Posted: 05 Jan 17 at 18:42
no worries Nev. I also have a UK address to ship to. I can check the part numbers provided and see what i can come with.
------------- MONK
Posted By: T3 Nev
Date Posted: 06 Jan 17 at 10:45
7a has a 1.75mm top or second ring if my memory serves me correct.
Date Posted: 06 Jan 17 at 12:06
http://oemwolf.com/oem-parts/053198151b.html" rel="nofollow - http://oemwolf.com/oem-parts/053198151b.html
Suggests 053198151b is 82.5 1.5 1.5 2
Date Posted: 13 Jan 17 at 07:28
Hey guys...me and again. I am still overhauling the engine and managed to get parts from ECS tuning and buycarparts.co.uk. Still waiting for them to arrive and i hope they arrive as expected. I am assured they are from OEM suppliers therefore i expect many years of trouble free service once i am done!!
Another question, anyone with the part numbers for the pressure and clutch plate (pressure plate and clutch kit maybe)for this engine/microbus? Now that i am doing the overhaul , i may as well get all doubts out of the way.
Cheers.
------------- MONK
Date Posted: 13 Jan 17 at 14:00
The clutch parts are specific to the South African T3s, an Audi 240mm clutch with 24 splines will fit eg LUK 624083900 (Audi 200 2.1) but on the original clutch friction plate the centre boss is offset towards the gearbox - this means that the LUK kit (or other off the shelf clutches) will not fully engage on the input shaft splines. I think many people use the Audi clutch kit with no problems, I had my original clutch refurbished but don't know if that route is open to you.
Date Posted: 13 Jan 17 at 14:05
Thank you marliinowner. Will have a look see if i can find the part number given. if not will go the audi route and see how that works out. If you and other have gone that route with minimal issues then i guess why not!;-)
I also have been checking for the rotor and distributor cap for it. The ones i see online seem a bit different. Do you have the part numbers for this too?
------------- MONK
Date Posted: 13 Jan 17 at 14:49
just to confirm...will the kit as it is work? i.e the clutch friction plate,pressure plate and even the release bearing?
*apologies for what may seem a silly question
Cheers.
------------- MONK
Date Posted: 13 Jan 17 at 14:57
I'm using BERU VK385S, VW 034905207B, distributor cap, and Beru 0300900096 (rev limited) rotor arm as that was what was already fitted. Original rotor arm is 052905225C which is used on loads of VWs.
Date Posted: 13 Jan 17 at 14:58
Clutch kit will work but friction plate will not fully engage with input shaft.
Date Posted: 13 Jan 17 at 15:02
cool..got it. I guess in a nutshell,from the LUK kit:
- The pressure plate in the kit will work just fine
- the clutch plate/clutch friction plate will work somewhat but not fully engage
- The release bearing will work
------------- MONK
Date Posted: 13 Jan 17 at 15:04
http://www.oemepc.com" rel="nofollow - http://www.oemepc.com is a good source of part numbers, selecting ZA and typ2 1995, although 2.5 engine is not covered - most parts are the same as 1995 2.3/2.6 although not front brakes and rear driveshafts (i think).
Date Posted: 13 Jan 17 at 15:07
Cheers marlinowner. You have been quite helpful!Thank you for clearing the newbie questions!
Much appreciated.
------------- MONK
Posted By: mucho
Date Posted: 25 Jan 17 at 09:40
Hi Monk, welcome aboard, nice to have a fellow Kenyan on these boards. If you are still on the hunt for the original clutch plate, the part number is 22S 141 031 A. Good luck.
------------- 2.6i Caravelle 1997 powered by Audi 5 Cylinder - Motronic
Date Posted: 25 Jan 17 at 09:57
Hey,
That's awesome news. Yes got the original part numbers. Now only to find them......any leads on the original clutch plate locally will be appreciated.
------------- MONK
Date Posted: 03 Feb 17 at 07:32
Hello guys,
Does anyone know the part number for the nozzle seals at the cylinder jead for engines that use the CIS injection system?
Can't seem to find them on oempc.com , since they show the catalog for the EFI engine.
Thank you in advnance.
------------- MONK
Date Posted: 03 Feb 17 at 10:27
For fuel injection parts for the 2.5 engine,look at 80's Audi 5 cylinder parts, eg
http://www.oemepc.com/audi/part_single/catalog/au/markt/RDW/modell/A200/year/1988/drive_standart/87/hg_ug/133/subcategory/37035/part_id/253757/lang/e" rel="nofollow - http://www.oemepc.com/audi/part_single/catalog/au/markt/RDW/modell/A200/year/1988/drive_standart/87/hg_ug/133/subcategory/37035/part_id/253757/lang/e
Date Posted: 03 Feb 17 at 10:34
