Jx wont start
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=92283
Printed Date: 18 Apr 24 at 12:54 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Jx wont start
Posted By: rob1927
Subject: Jx wont start
Date Posted: 23 Dec 16 at 18:47
Hello all and xmas!
My JX is having some starting issues, it's completely dead, it's an intermittent fault that's got worse. The battery is good, the starter motor and solenoid are both new and I've just put a brand new ignition switch in today but alas the problem persists.
Any ideas where to look next? The wires on the alternator appear to be good, it's just been in the garage for the glow plugs to be repaired, all the dash LEDs come on with the ignition but dead when I try to fire.
Any help would be greatly appreciated.
Posted By: ob1
Date Posted: 23 Dec 16 at 19:11
Run a big fat earth cable from the starter to the chassis. The earth path often gets disrupted when you change the starter. I ran a cable from the starter to the negative on the battery and it sparked and then has worked ever since. The cable was only need once?
Posted By: rob1927
Date Posted: 24 Dec 16 at 00:29
Cheers ob1 I'll have a look tomorrow. Is the starter circuit completely independant of the glow plug circuit? I know the ignition triggers both the glow plugs and the starter but is the starter circuit completely separate?
Posted By: rob1927
Date Posted: 24 Dec 16 at 00:58
Is there a relay in the starter circuit that shuts off the lights, radio etc to allow full current to the starter? If so could this be possibly knackered?
I had someone try to start the van whilst I was at the engine bay, I could hear a relay clicking which I'm certain is for the glow plugs, I could also hear the aux water pump kicking in whilst the key was fully turned.
Posted By: rob1927
Date Posted: 07 Jan 17 at 19:23
It seems to be fine now, I disconnected the big earth from the battery to the gearbox and gave everything a good clean and all seems well.
