new DTA Fuel injection on WBX
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=92041
Printed Date: 25 Mar 19 at 13:03
Topic: new DTA Fuel injection on WBX
Posted By: akciddento
Subject: new DTA Fuel injection on WBX
Date Posted: 22 Sep 16 at 23:30
A belated update,
after toolling around on a slightly modded 2.1DJ with MSD and some other bits I snapped a head stud and while waiting (a long time) for things to resolve (via buying and gutting a subaru impreza for the EJ20, prepping it and then changing my mind) i dropped in an unknown quality MV (2.1 low compression) and moved on the carb, fuel pump, MSD etc and replaced with this,
2.1MV
42mm throttle bodies
DTA s40 ECU
Coil pack
speedshop stainless exhaust
speedshop pulley and crank sensor
high pressure electric fuel system
narrowband lambda
new FI tank
new radiator
custom loom
etc
the bus finally has a new MOT and runs fairly well
pulls strong for a small MV, makes a wonderful noise and hot and cold starts (kinda) but is hugely rich so a trip is booked to a rolling road this weekend for tuning and tweaking.
The bus itself is 1989 double slider - originally a devon multivan now with a westfalia poptop, big disc brake conversion all round, 30mm lower, rebuilt 5 speed box with LSD on 18inch Khan RS1 rims.
just though i'd share....
...though it's been a long time
D
http://www.akciddento.com" rel="nofollow - akciddento.com         let's drag race the bus....
weblog, tech articles, movies, shop, stupidity
Posted By: silverbullet
Date Posted: 05 Oct 16 at 20:11
Like the sound of this! Is it full sequential or semi? I reckon that would go nicely on one of my 2.5 engines!
Have I missed anything?
Date Posted: 07 Oct 16 at 23:43
semi sequential,
got it mostly dialled in now and it hot starts fine and cold starts well enough.
I took it to JPR Racing north of bristol for a few hours on a rolling road to bug fix and trouble shoot and baselined the map for safety and did a few power pulls.
apparently it makes 101 bhp and 125ft lb of torque. power dies over 4200rpm with what looks like valve float that needs to be looked at. I've a few things to fix -  change the throttle linkage, lifter pre-load, change fluids etc then will go back to tune for power and see what happens.
Date Posted: 07 Oct 16 at 23:49
Date Posted: 07 Oct 16 at 23:53
Date Posted: 08 Oct 16 at 00:00
however, i think the 2.1mv may be more than a little limited for tuning, it was a stock 2nd hand unknown find. It makes good power for a low compression engine (stock is circa 90bhp) but it is always going to be limited.
so i've torn down the old 2.1 high compression dj motor that was in it ready for a rebuild. all looks good apart from a broken head stud - that appears to have been welded on top of another broken stud - if you did this you should be ashamed !
i'm in the middle of porting heads and will slowly work through checking and balancing everything.
the plan is a stock rebuild with a mild cam, new lifters, dynamic balancing, some ratio rockers and TLC
Date Posted: 08 Oct 16 at 07:05
Thats a pretty good hp improvement in % for a used MV!
Peak power coming in at stock rpm so no suprises there. The cams are always knackered, I have one here with a genuine 140kkm and the ramps have just started to fail due to scuffing.
Got a source for good quality valve springs that will let a wbx rev a little more? I am only looking for 6k max on a 2.1, no more.
I had some hydro cams done by Newmans, more aggressive lobe ramps (you cant go mad because of the lifter diameter) and they make the 2.5 into a torque monster!
Date Posted: 08 Oct 16 at 10:31
the torque is pleasantly flat all the way and with valve adjustment and some better tuning it should see a little more. The throttle bodies and the merged exhaust help.
the cam in the 2.1dj is worn so i am shopping for a replacement, probably the CB eagle 2280
http://www.cbperformance.com/product-p/2280.htm?CartID=1" rel="nofollow - http://www.cbperformance.com/product-p/2280.htm?CartID=1
with new hydraulic lifters. I did a solid lifter conversion on a wbx years ago and the machining starts getting a bit involved. several places are advertising repalacement dual springs for WBX - any recommendations ? (I believe that type 1 HD springs will fit but way need larger retainers?
what lifters did you use with the newmans? expensive?
Date Posted: 08 Oct 16 at 10:41
Head work continues, inlet ports and exhaust, careful unshrouding of valves and then they will go off to be resurfaced.
here are two inlet ports after the first run, removing lumps, bumps and casting marks and a little work around valve guides. The machining marks and angles in the bowl below the inlet and exhaust valves is particularly poor and took a lot of work to smooth the transitions. I'm not going for anything radical - just smoothing transitions and cleaning up to help flow. Where I can i'm opening up the short side transitions as the exhaust particularly has a really tight bend directly after the valve.
The surface corrosion is quite pronounced in places but the valves, seats and heads in general are good. When reassembly happens I will do a mild port match against the throttle body manifolds.
Date Posted: 11 Oct 16 at 08:40
I have to do all the same work on new AMC/KS heads, the valve seat area machining is mismatched to the port casting, they need about half a day's carbide burr action per pair just to clean them up...
I will keep on grading used spring sets until I can find decent quality. Not keen on going backwards an using type 1 stuff. I can get them made but minimum quantities make it an expensive exercise.
Posted By: Dave Dorson
Date Posted: 01 Nov 16 at 15:43
Is that the Von Rat bus?
Crikey.
Good to see you're still keeping a toe in Dan. :)
Date Posted: 01 Nov 16 at 16:15
yes, it's the one i picked up on a trailer from you, circa 2005/6 ;)
still bussing, how are things ?
Date Posted: 01 Nov 16 at 16:38
I'm glad to see it's still out there doing its thing :)
Things are good mate.  I've still got the rusty brown heap.  Currently spending a lot of money on mig wire and gas, and bits for an AGG engine.
Date Posted: 01 Nov 16 at 16:44
the bus is much changed,
LSD gearbox, big brakes all round, suspension, interior - westie pop top, EFI, etc... still full of dents....
good to hear the brown things's still going, i thought you had put a subaru into it?
Date Posted: 02 Nov 16 at 10:28
Yeah, I did.. it sat too low and never ran right, so I sold that on and decided to go diesel.  Then remembered that I hate diesel engines so used a lot of the parts go to GTi instead.  I'll be happy with 115-120bhp in the van... Hub's old one with the 2.1 DJ went plenty well enough, so if I can get close to that kind of performance, I'll be happy.
Besides, I've got a 1303 for making quicker.. (Subaru Turbo)
Date Posted: 02 Nov 16 at 11:26
the black schick pop top or the brown one?
I built the turbo motor for the blackone up at RaceShack - a massive labour of love at the time, hours of headwork, solid lifter conversion, turbo cam, straight cut cam gear, custom H beam rods, KEP stage II clutch, rotating assembly all dynamically balanced etc etc.
but a 2.1dj with basic mods will give you usable basic power - exhaust, lifters, induction etc
Date Posted: 02 Nov 16 at 16:12
The Don mate :) (beige one he had off Mr Walker I think)
I totally forgot he owned that turbo one :).
Problem with the DJ engines and all the kit to make them work, is that it's a lot cheaper to throw an AGG from a Mk3 GTi in, especially when you've got all the "conversion" bits off a diesel.
I'd quite like a 2.1 DJ in a panel van though. LOL I'd add some kind of duck whistle to the home brewed turbo that I'd end up throwing on :p
Date Posted: 08 Nov 16 at 19:58
like this one ?
https://youtu.be/LC-GY6n2t9Y" rel="nofollow - https://youtu.be/LC-GY6n2t9Y
Date Posted: 08 Nov 16 at 20:36
I know what you mean, but then I can buy a ten year old M3 BMW for less than the price of a rotten out T3...
it's a strange and twisted world :D
Date Posted: 21 Dec 16 at 20:39
had a fun morning with James at Stateside tuning, picked up some custom H beam rods and had James dynamically balance the crank, pulley, flywheel and pressure plate. Letft the case with him overnight for dipping in the hot tank.
James at Stateside tuning balancing the rotating assembly, pulley, camgear (fancy CB straight-cut ones to go with the new 2280 cam), crank, flywheel and pressure plate.
I also dropped the heads off at a local head specialist to have them reface the sealing surfaces and install new valve guides
progress is happening.
Date Posted: 23 Dec 16 at 14:47
the Bosch style hi pressure fuel pump in the bus is insanely loud. It's mounted under the rear floor between the chassis rails in a damped holder but still pierces through the whole cabin.
Date Posted: 16 Sep 17 at 18:41
quick update,
with some running around the long block os together, events over took things and I took all the prepared parts to Rob Judge at RNJ motorsport who did the final bug fixing and assembly. I picked up the block last week and am now doing the build up on the modified 2.1DJ.
it's a simple enough engine but will make a little more and maybe live ok.
2.1 DJ
custom h-beam rods
new german high comp barrels and pistons,
new ported AMC 2.1 heads
CP performance 2280 cam with straight cut cam gear
SCAT 1:1.25 ratio rockers
new lifters etc
pistons, rods, crank, pulley, flywheel, pressure plate all balanced
