T3 Autosleeper low top - the return!
Category: The Brickyard
Forum Name: The Bus Park
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=92019
Printed Date: 23 Jun 18 at 20:38
Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: T3 Autosleeper low top - the return!
Posted By: fufflenarnia
Subject: T3 Autosleeper low top - the return!
Date Posted: 16 Sep 16 at 20:23
Well, I couldn't stay away for long, the garage was looking far too empty!
Mrs Fuf was missing a cm per too, as we're the kids.
So this is it, needs a little work, but a much better starting point than the last one:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/s-l1600_zpsiqwxoh2v.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/s-l1600%208_zpszycwl6ks.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/s-l1600%209_zpsqrezw7ip.jpg.html" rel="nofollow">
Drivers side has been done already - nice job too.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/s-l1600%2010_zpsk24ur5cr.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/s-l1600%2011_zps3xbn1tkn.jpg.html" rel="nofollow">
Only 3 areas of rust left to weld:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20160916_172305_zpsqiblhcan.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20160916_172220_zpsg4oywbub.jpg.html" rel="nofollow">
And behind the front bumper.
Underneath is brilliant:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20160916_172239_zpsaanlk9td.jpg.html" rel="nofollow">
A quick run round with a wire brush and loads of dintrol will do it.
Oil lek on one of the push rod tubes:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20160916_172233_zpsk9sptedn.jpg.html" rel="nofollow">
Inside is very clean too:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/s-l1600%205_zps2hgk7nqx.jpg.html" rel="nofollow">
And he critical bit - a big double bed:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/s-l1600%204_zpsxgg1rrgi.jpg.html" rel="nofollow">
So, the list:
Weld sliding door runner, behind bumper and rear quarter.
Thorough rust treat and respray.
Fix oil leak
New curtains and seat covers
Sort out the wiring and uprate the headlamps (one full of water!, but they are like candles).
Thorough engine sort out (runs like dog when cold)
Fit tow bar (anyone got one)
Repair both big bumpers
EPAS
Fit land rover mirrors (forgot how shit the standard ones are)
Fit 3 point belts in the back
And this list will expand exponentially from here!
Date Posted: 16 Sep 16 at 21:43
Smile
welcome back!!
Posted By: 912
Date Posted: 16 Sep 16 at 22:10
I nearly bought this but didn't have time to view it :(
Date Posted: 16 Sep 16 at 22:20
Tee hee, wasn't gone for long, 3 weeks!
Date Posted: 16 Sep 16 at 22:35
oh the joy of cut panel vans and chipboard..
#WestySnob
Date Posted: 16 Sep 16 at 23:14
Don't worry, I know my place.
Does the west have an "anti running over yourself" feature?
Date Posted: 16 Sep 16 at 23:30
LOL
I don't know how anything works in it.
Your new bus looks ace..  Engine staying stock?
Date Posted: 16 Sep 16 at 23:40
I think so. As long as it works, may be a gti one day....
Anyhoo wide boys need wide beds!
Posted By: tennis
Date Posted: 17 Sep 16 at 07:50
Hutch is swapping the Westie for Ava, he is just in denial.
Foursprings Dutch Picnic
Date Posted: 17 Sep 16 at 07:58
Ava?
Posted By: BeJay
Date Posted: 17 Sep 16 at 08:42
Originally posted by fufflenarnia fufflenarnia wrote:
Ava?
Gardner?? now that wouldn't be a bad swap Wink
 Image result for ava gardner
NIL ILLIGITIMUS CARBORUNDUM
Date Posted: 17 Sep 16 at 09:32
Yep, looks like a fair swap!
Date Posted: 17 Sep 16 at 09:33
So, on to van fixing. Pushrod tubes - change one (the leaky one) with a springy one or all and do the heads?
Date Posted: 17 Sep 16 at 10:00
just do the one..  and use the bus.
Posted By: tennis
Date Posted: 17 Sep 16 at 10:36
Steve
If its a 2.0ltr cu, you take the rocker cover off, unbolt the rockers and slide them in and out from there.
the springy ones only fit beetle and split engines.
Date Posted: 17 Sep 16 at 11:25
1.9 dg.
Im happy to do the 1. Putting a nice big order together.
Date Posted: 17 Sep 16 at 14:11
I've managed to get 3 bolts out of the heat shield, but th last one, omg! Hammered on smaller socket, tried heat, chizzeling one side of the head.
I'm thinking I may just cut the perfectly good heat shield, change the leaking pushrod covers and tack it back on!
Any other suggestions I should try first?
Posted By: Bromy
Date Posted: 17 Sep 16 at 16:10
Thumbs Up looks a good one
"follow the masses, do the opposite"
Date Posted: 17 Sep 16 at 16:35
grind the head off the bolt, remove heat sheild intact, get medieval with the stud.
Date Posted: 17 Sep 16 at 18:05
Too late! Cut and off. The bolt can be a challenge for an engine out job.
Not sure if the silicone goo on the tube is oem!
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20160917_162610_zpsf9k3sbtc.jpg.html" rel="nofollow">
Also 1990's car alarm removed.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20160917_115349_zpsuwgvf21d.jpg.html" rel="nofollow">
And back quarter removed, nothing wirse than anticipated.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20160917_162628_zpsgos8pmh7.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20160917_162640_zpscyrwqulk.jpg.html" rel="nofollow">
Date Posted: 17 Sep 16 at 18:07
putting a metal one back on? Saw the fibreglass ones rhoen bulli do at bustfest - very good quality
Date Posted: 17 Sep 16 at 18:15
So, on to why she is not pulling at low revs.
I have looked for the filter in the carb to see if it is blocked, but no filter - any ideas? It has a new folder by the tank. Do I need to strip the carb down, aledgedly it's already been done.
Posted By: Bromy
Date Posted: 17 Sep 16 at 21:23
I had no end of stuttering at low revs untill i pulled the carb apart, re built with brickwerks kit. Job jobbed
Date Posted: 17 Sep 16 at 21:55
Hutch, I'll put the metal one back on, it's in really good condition.
I want to get the body sorted and mechanics OK so we can use her in the spring, I'll probably whip the engine out next year and give it the full monty.
I'll order a rebuild kit and check for anything else, thanks Bromy.
Date Posted: 02 Jan 17 at 17:21
So having been distracted by redoing the dildo, its much bigger and has hard granite finish! I am now back on the van.
New distributor fitted along with 2 new pushrod tubes from brickwerks. I forgot to order rocker gaskets so new order placed.
Oil drain plug has stripped too, so m16 drain plug ordered from Brickwerks along with an m16 tap. Meanwhile the rocker covers have had a quick wire brush and paint.
Exhaust is blowing too, and some clamps are missing, so I may drop the engine and whip the exhaust off for a full investigation at some point.
Bodywork:
Both back corners had gone (despite the drivers side havin a new rear wing, they hadn't fixed the rust hole under the vent or the corner panel.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170102_152953_zpszputw0ev.jpg.html" rel="nofollow">
New corner ordered for the other side.
Small hole in the wheel arch - same as on the last one.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170102_130544_zpswidlzpz4.jpg.html" rel="nofollow">
Done the sill under the sliding door too, excellent repair panel, cut down to retain most of the original sill, but all new rail for the seal.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170102_142617_zpssaadsdy7.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170102_152940_zpse83qpgx7.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170102_152931_zps3w7lodtm.jpg.html" rel="nofollow">
I may need to sort out the wood floor, looks like Wheetabix!
Front panel to do, plus one in the wheel arch and at the bottom right of the sliding door opening.
I need to decide if I want to paint it myself, or shell out for someone else to do it - if I can find someone at the right price. Also need to do upholstery and curtains.
Date Posted: 02 Jan 17 at 19:48
whats the bus sat on fella? trying to figure it out?
Date Posted: 02 Jan 17 at 20:52
4 post lift.
The white bit is some left over mdf skirting from the dildo, its important to have a nice finish on the dildo. 4.2m long, can't fit it in the car to take it back! Must get round to cutting it in half and putting it in the car port.
Date Posted: 07 Jan 17 at 18:07
More progress today:
2 holes in nsr wheel arch done:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170105_165143_zpsol5fjtfi.jpg.html" rel="nofollow">
This one courtesy of an untreated screw I think:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170107_121450_zpstonuspca.jpg.html" rel="nofollow">
One at the back of the sliding door:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170107_121440_zps7p9nddqb.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170107_125318_zpsnhlpo2kg.jpg.html" rel="nofollow">
NSR should be complete now, so OSR to do, a different make of panel from Brickwerks this time "oversize"?!?
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170107_103850_001_zpsvsdpvsbr.jpg.html" rel="nofollow">
Definitely not as good a fit as the Schofield one from Brickwerks for the other side. Perhaps oversize means "this one didn't come out right"!!!
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170107_104906_zpsrclaxxa9.jpg.html" rel="nofollow">
Lots and lots of fettling and it's good enough:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170107_152710_zpsekles1un.jpg.html" rel="nofollow">
Luckily the bits of rear roof rust courtesy of Autosleeper riveting the roof on through the rubber seal (so water is retained next to the screw and it rusts lots) aren't too far gone, one small hole to fix:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170107_152723_zpslfupxcwd.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170107_152726_zpsh0ekqhmh.jpg.html" rel="nofollow">
The bit under the sliding door runner isn't too bad either:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170107_152736_zpsfwdfidlb.jpg.html" rel="nofollow">
Now to turn it round and sort out behind the rear bumper. NSR window needs doing, that can wait.
Push rod tubes done along with an oil change and new plugs. Timing done.
Running poorly on cold start 🙁, so need to check a few bits.
Date Posted: 08 Jan 17 at 17:39
And more, on a roll!
Given her a good pressure wash so I can check the wheel arches etc, all very good.
Worked on the engine, it is only running on 3 cylinders.
Done a compression test, all 152 to 165 psi, except no 2 which is zero!
I took the rocker arms off and it comes up to 152psi, so double check everything is seated, set the tapits and guess what? Still zero!
Any ideas?.?
Gave up in that and turned the van round and worked on the front:
Yuck:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170108_151008_zpsnzg62fye.jpg.html" rel="nofollow">
Barely need the grinder, you can sweep it out! This done with fingers only:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170108_152506_zpsx70rievd.jpg.html" rel="nofollow">
So a good run with 9" grinder, air chief to remove the spot welded steel at the bottom, and a bit more grinding and a go with the power file:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170108_163021_zpsn31cclyv.jpg.html" rel="nofollow">
I have a repair panel from Brickwerks which looks good (bottom right of the photo), I guess I will have to drop the rad out to weld the back.
Checked behind the seal on the pop top at the front, and nothing terminal there which is great.
Posted By: BeJay
Date Posted: 09 Jan 17 at 10:25
If you're getting good compression without the valves operating but zero when the rocker arms are back on I can't see it being a head problem, then my first thought would be either a badly sticking valve or a weak/broken valve spring not closing one of the valves quickly enough when it should, thus allowing pressure to escape into a manifold on the compression stroke.
Date Posted: 15 Jan 17 at 21:15
Front done and thoroughly soaked in POR15.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170114_131921_zpsmqjxnw5l.jpg.html" rel="nofollow">
I back flushed the radiator too and sorted any surface rust. I need to have a spray round with dintrol before the rad goes back in.
I will then turn the van back round and have a look at the hydraulic tappets on cylinder 2 and look at the window surrounds.
I haven't decided we ther to spray it myself or find a sensibly priced bodyshop, any suggestions round Redhill, Surrey welcome......
Date Posted: 21 Jan 17 at 19:51
A bit more progress to report.
I've removed the exhaust off no 1, didn't think it would come out without shearing the studs, but I managed it, well chuffed:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170121_181511_zpsei8p9muo.jpg.html" rel="nofollow">
Also been rust treating stuff and a coat of paint where necessary:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170121_181525_zpswo3qbfky.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170121_181500_zpshzczrkkv.jpg.html" rel="nofollow">
I also have all 4 cylinders running, I guess the tappet leaked down. It won't tick over tho, and runs like a dog. The new fan belt from brickwerks is screaming too, but it's at its full adjustment
I guess it's going to be engine works until the weather perks up, it's too cold for spraying. I need to buy a replacement exhaust for no 1 too.
Date Posted: 29 Jan 17 at 17:50
Got me a lovely set of Carat wheels, so the Audi ones have been sold. The rear long studs were loose (spinning), so I took the hubs off and put the standard set I removed from my last one in. Front long studs removed too. Steels put on for paint. One of the brakes is missing it's locator, the spring, or what's left of it was in the bottom of the drum. The shoes have plant of meat, but material missing drom the lining, so need replacing.
I've removed all the exhaust head studs (except one which looks scary and doesn't need to come out (why tempt fate).
I salvaged 3 branches of exhaust, no 2 had sheared at the silencer flange, but that welded up OK. I managed to pick up a nos one for cylinder 1 on ebay for a song. The silencer needed a small patch and all the studs drilling out (tried welding nuts on etc, but they weren't coming out, new studs drilled, tapped and loctited:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170129_111452_zpsxrs1vp4n.jpg.html" rel="nofollow">
I know it's alot of work on a consumable item, but they are soooo expensive and I have the desire to fit a different engine at some point so it's a waste to spend too much on this one.
I've repaired the other pushrod cover too. http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170129_111443_zpsnhvmoqab.jpg.html" rel="nofollow">
It was only mounted on one port and the lower mount had split, now repaired, I had to extend the mount for the exhaust port as it didn't want to reach. It's now nice and shiny like it's twin.
Last bit of welding is on the side window, odly the seal is missing the filler strip - not good.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170129_124950_zpswcd4kuon.jpg.html" rel="nofollow">
Date Posted: 29 Jan 17 at 18:29
I also checked the gear change, the screws which hold the box under the stick to the body were properly loose, seems strange. Otherwise it's pretty good, I'll change the plastic parts anyway, seems daft not to.
There's an so been a repair on the front to rear coolant pipes, a section next to the engine bay has been cut out, but not quite enough, and the rust needs treating or they will get worse.
I need to get on with body prep, hopefully it will be warm enough to spray soon.......
Date Posted: 04 Feb 17 at 17:53
Done the window surround:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170204_140138_zpsjle0zjex.jpg.html" rel="nofollow">
Also Jeysered the underside of the engine and box so I can tell how many leaks are left. Refilled the coolant and fitted the exhaust.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170204_121248_zpsi17zgxnw.jpg.html" rel="nofollow">
Found out why my new aux belt wouldnt tighten fully:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170204_121232_zpscnwiqd0b.mp4.html" rel="nofollow - flubbered water pump
I see another order to brickwerks on the way for a new water pump.
It's still running rough, so a carb rebuild is in order, but brickwerks is out of stock of kits.
I've also been checking the electrics, I've removed a homemade split charge relay working off the charge light and fitted a rev counter.
Started filling.....
Date Posted: 12 Feb 17 at 17:20
Waterpump fitted.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170212_165750_zpshkhzmkxr.jpg.html" rel="nofollow">
Choke pull down on carb is buggered, so need to order one of those.
Have fitted an oil pressure guage and rev counter in a brickwerks pod. Oil guage is fitted to a sandwich plate from ebay (£10), and ca me with the right threaded adaptor 3/4 unf.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170212_165932_zpsvbuw0ipf.jpg.html" rel="nofollow">
All windows out, no welding required. Rust shot blasted and treated.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170212_165816_zps5haqu0di.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170212_165906_zpsqhvqegl8.jpg.html" rel="nofollow">
Transfers removed, Fillathon underway:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170212_165757_zpsb9n0zo2o.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170212_165808_zpswstm4vil.jpg.html" rel="nofollow">
Now, why is there expanding foam in the bottom of both cab doors? Is this a vw rust promotion method, luckily it hasn't worked!
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170212_165836_zpsvjlo3qqv.jpg.html" rel="nofollow">
And to help it on the way I now have surround sound 5.1! A kind donation from a friend. I can even hear it over the sound of the sander!
I need to finish the prep and remove the doors and tailgate, then it's a clean up the garage and spray time!
Date Posted: 18 Feb 17 at 18:20
Last of the welding done, a little bit more prep and it ready for spray:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170218_150306_zpsha9balll.jpg.html" rel="nofollow">
Choke pull down replaced, running a bit better, but still not 100%, I'm waiting for Brickwerks to get pierburg rebuild kits back in stock.
Working on plans for a gti converdion in the meantime.
Date Posted: 18 Feb 17 at 20:07
there over rated - diesels the future ask hutch...... apparently it isnt just a lubricant LOL
Date Posted: 18 Feb 17 at 20:14
Hmm, funny how things work isn't it, all of a sudden everyone turns against diesels, councils talk of banning them in town centres and Hutch decides he likes them.
I did think of going 1.8t, but I'm not sure I can be bothered with charge coolers and all that stuff. Having said that when I got it working properly on the pd, the difference was phenomenal! You could go straight on on any bend!
Date Posted: 18 Feb 17 at 23:31
alright, point taken..
Got the westy,
vanfest coming up
Olympic Tom and I finished throwing in a 77K 1.9D 1Y on the saturday morning
it goes, it stops, I can sleep in it
that oil burning thing can stay in the back for now.
it will only come out if replaced with something stupid.   audi v6 prolly..  get  a shift on rowlsey.
Recently bought all the bits to turbo it, but couldn't do it..  it just works.
@steve - just stick a GTi in it and be done.  (or a 1.9D)
Posted By: Bromy
Date Posted: 18 Feb 17 at 23:35
LOL
Date Posted: 19 Feb 17 at 09:31
Just need a diesel bell housing and starter/adaptor plate and TDI starter and a donor vehicle
Date Posted: 25 Feb 17 at 17:56
What happened to the weather??? I had it all ready for spraying by Sunday and it gone cold and windy, bastards!
Today I've finished hanging dust sheets in that garage and double checking everything.
I've started collecting bits, just need a diesel bell end and starter:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170225_143420_zpsbqclum6z.jpg.html" rel="nofollow">
I'm thinking of maybe going 1.8t, just because......
Posted By: flying haggis
Date Posted: 25 Feb 17 at 22:09
I'm planning a 1.8t in a syncro doka for my next project, almost got all the parts, just short of a syncro doka and a 1.8t engine, oh and most of the diesel parts to fit it!!
On the other hand I have a set of engine bars and 3 16" merc wheels so nearly there
Take a walk on the wild side
Posted By: fatboy
Date Posted: 25 Feb 17 at 22:49
Bloody hell chap, that didn't take long!
'83 T3 westy
'85 SA microbus
Seat torpedo
68 buggy again!
Shit I need to sell some MORE cars!
Date Posted: 25 Feb 17 at 23:14
Got some spare engine mounts with bolts if anyone needs them.
What didn't take long? Getting pissed off with the wbx, prepping the van for paint or collecting all the parts?
Date Posted: 26 Feb 17 at 11:21
Diesel bell housings are very expensive!
Does anyone have a petrol bellhousing they can loan, or sell cheap so I can design an adapter?
I think I will put it between the bellhousing and gearbox, like this
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/IMG_0361_zpsejtx1xvg.jpg.html" rel="nofollow">
That one is 15° to 0° I think, I guess I need to go 15° to 50°......thoughts?
I may need to borrow a diesel bellhousing too!
Posted By: fatboy
Date Posted: 26 Feb 17 at 11:27
Pretty much all of the above!
Can't se how putting your adaptor between the gearbox and bellhousing will help you fit a wbx bell housing to a gti though chap? Indexing a diesel bellhousing to have the engine upright maybe?
'83 T3 westy
'85 SA microbus
Seat torpedo
68 buggy again!
Date Posted: 26 Feb 17 at 14:28
If I rotate the bellhousing by 35° (anticlockwise looking from the back of the vsn), it should put the starter above the gearbox (like the diesel) and rotate all the bolt positions.
I'm not sure gearbox to engine adaptor would work as the starter would be in the wrong place.
I can't cross check on the van atm as it is all masked up.
I wish you were a bit nearer, it would be easier to borrow bits and swap knowledge.
Posted By: fatboy
Date Posted: 26 Feb 17 at 14:38
A wbx bellhousing won't bolt up to an inline four engine chap as far as I'm aware
'83 T3 westy
'85 SA microbus
Seat torpedo
68 buggy again!
Date Posted: 26 Feb 17 at 15:45
nope! but running an adaptor (+15mm) like my doka's might work out cheaper? but then you have trouble with flywheel. custom jobbie or a modified 2.1 with h/d clutch kit......
Date Posted: 26 Feb 17 at 16:05
Or its bellhousing shaving like flipped box, so little point.
So it's back to needing a diesel bellhousing then.
Posted By: fatboy
Date Posted: 26 Feb 17 at 17:41
I can template a diesel bell housing for you chap and measure thickness of a diesel flywheel if that helps. Rowlsey had to shave the back of the air cooled flywheel to correct the depth once the adaptor was fitted. Bonus is you end up with a 228mm clutch without the cost of a tdi input shaft. As I remember the 20vt was a 228 mm friction plate too.
'83 T3 westy
'85 SA microbus
Seat torpedo
68 buggy again!
Date Posted: 26 Feb 17 at 19:35
dont forget i was only running a 2e - your 20vt might eat h/d boxer clutches anyway.... can you get h/d diesel clutches? baxter dont list em?
Date Posted: 26 Feb 17 at 19:49
slow down jimmy! think this through....
diesel bell housing - the starter is relocated as the flywheel is smaller in diameter and in the same place as a petrol you'l be close/in the sump.
petrol bellhousing i think will be ok if you run at 35 degrees if you have an adaptor but it might be worth offering up first.
page 11 of the doka build chap Thumbs Up
Date Posted: 26 Feb 17 at 20:16
I'm not convinced it's worth the effort, as long as the bell housing prices don't go up any more, if the do then it's beck to a4 flipped boxes......
The A4 adapter was around £80, plus 105 cv joints £30, spacers £20, gearbox mount (time only), machining (time/or cost...) and gear linkage and terminators cock £££££)
I've got my eye on a diesel gearbox which has a good final drive ratio which would work with my box on a 1.8 20vt.
Not convinced I will go down that route yet tho.
Posted By: Lits
Date Posted: 28 Feb 17 at 21:30
Hi if you are going 2.0 GTI engine then I'd just get the diesel bellhousing you've got almost everything else you need. The picture of the adaptor plate a few posts back is to go inbetween a diesel bellhousing and the gearbox turning it from the standard 55 degrees to 15 degrees. I think 15 degrees would suit the 1.8t engine much better but you would have to fab up some mounting bars to suit the engine.
The 1.8t is a great engine but would be more involved fitting compared to an AGG or similar.
Don't start what you can't finish!
Date Posted: 01 Mar 17 at 06:18
Fitting a 1.8t doesn't worry me in the slightest, it looks a lot easier than the pd install I did a few years ago. I just need to sort out a diesel bellhousing.
I've missed out on one complete gearbox already. I've got my eye on another, but it's a bit too far away to collect. Does anyone know someine whi travels south east from Stafford?
Date Posted: 01 Mar 17 at 06:34
Where is it fuf?
Date Posted: 01 Mar 17 at 07:30
I only have Stafford at the moment.
Date Posted: 01 Mar 17 at 07:58
ST17 0PA
Posted By: nick1973
Date Posted: 01 Mar 17 at 15:40
i found out what the fancy gaer lever is  fitted to and i should be able to get some second hand ones
Date Posted: 01 Mar 17 at 17:13
Oooh sounds interesting I've got one out of a Vauxhall combined van that looks like a likely candidate.....
Posted By: Lits
Date Posted: 01 Mar 17 at 22:05
Watching this with interest hope you go for the 1.8t engine, it'll be a great conversion.
Had several mk4 golfs with the engine in. Have you decided on which engine code you are going for? or are you waiting for the right donor to come along?
Date Posted: 01 Mar 17 at 22:26
I'm thinking early a4, a6 or passat mounted at 50° with diesel sump.
150bhp which is plenty on a standardish gearbox.
Should be a nice conversion, especially if I can keep it under the hatch.
The aim is to keep the dg going for the summer I'd I can and spend time collecting parts.
Date Posted: 04 Mar 17 at 18:00
The Redstone spray shop has been in full operation today. Borrowed heaters on full:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170304_173415_zpskise7mwh.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170304_173428_zpspo1ibytp.jpg.html" rel="nofollow">
It's like Christmas unwrapping it!
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170304_174821_zps7xec8tzs.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170304_174831_zpsxxhhnr8l.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170304_174840_zpsymmgeajg.jpg.html" rel="nofollow">
It needs a good buff up, and the doors, engine hatch and side covers doing, looks like rain tomorrow, so probably not possible this weekend
Posted By: Lits
Date Posted: 06 Mar 17 at 08:11
Looks smart, good work
Posted By: Titus A Duxass
Date Posted: 06 Mar 17 at 14:43
Nice, what paint did you use and what have you for a spray gun?
Bollocks to it all!!
51°24′N 12°52′E
Date Posted: 06 Mar 17 at 15:41
It's a Non-isocyanate 2 pack with a cheapish Italian HVLP spray gun.
Date Posted: 07 Mar 17 at 05:08
Cheers.
I've never used the non-iso 2k, was it relatively easy to spray?
51°24′N 12°52′E
Date Posted: 07 Mar 17 at 07:13
Yes, it has come out well. 3 coats and it's got a good shine. It dties slower than standard 2 pack, but without the cyanide, I can't say I noticed the difference. I'll flat it and machine polish it and it should look good.
I've done cellulose before and that was harder to get a good finish, 2 pack is easier.
Date Posted: 11 Mar 17 at 17:20
It's been a nice warm day, so I've painted all the other bits:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170311_141341_zpsbbuz6vxf.jpg.html" rel="nofollow">
And braved fitting them as the weather is crap tomorrow (the paint was a little too soft, so will need a bit of work)
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170311_154618_zpsrx6p3faq.jpg.html" rel="nofollow">
Also stripped the carb, it is running a little better, but still very lumpy. Give me an agg any day!
Posted By: simmyhall
Date Posted: 15 Mar 17 at 09:15
Thats looking pretty awesome, just about to start rust repair on that thing of mine.
TNT - dynomite
Date Posted: 19 Mar 17 at 20:25
I've had a weekend of tinkering.
New rear shoes, springs and drums - there were chunks missing out of one.
Up front, the Shields had disintegrated off the disks,
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170318_092258_zpsnj3w0qhq.jpg.html" rel="nofollow">
Amazingly all the retain screws came out without too much bother.
Next job, seats. I have a nice set from the back of a crysler voyager. I removed all the unnecessary ironwork and set about making a flat surface to bolt the runners onto:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170319_160451_zpsw8qwsmii.jpg.html" rel="nofollow">
Choppd up the plynth (excess metalwork)
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170319_164007_zpsnv7h7rta.jpg.html" rel="nofollow">
And a bit of butchery and welding:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170319_164013_zps7m8q9nsh.jpg.html" rel="nofollow">
Fitted.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170319_175910_zps0f3lk3os.jpg.html" rel="nofollow">
And refashioned and refitted the plastic bits:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170319_190647_zpsb0lmfckv.jpg.html" rel="nofollow">
Date Posted: 02 Apr 17 at 22:00
A little update.
Use a starter solenoid of a agg started from a previous conversion to make a boot release mechanism and fitted an alarm and central locking.
All windows fitted.
Colour sanded and machine polished the paint.
Repaired a section of floor - why do Autosleeper use chipboard for floor? It must zvd been conceivable that it would get wet!
Seem to have the DG running pretty well, fitted new leads, that with the other parts seems to have done the trick, hope it will sell for more than the cost of parts!
Also picked this up yesterday:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170401_132446_zpsd9azmvya.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170401_132454_zpsgazpqr9y.jpg.html" rel="nofollow">
The camper is definatly narrower and shorter than my daily driver, it barely fits on the ramps
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170401_132451_zpsis7l2dmz.jpg.html" rel="nofollow">
It's been very nicely painted, so Elvis should be pleased, mileage isn't too bad, and apparently it's been rebuilt, not sure of that though. It does have a piper adjustable timing gear on the camshaft, so maybe it has a cam too....
There was a broken stud on the exhAust outlet, but welding a nut on worked a treat, http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170401_163724_zpsng2yjgub.jpg.html" rel="nofollow">
Having spent a fortune on new curtains and retrim ming the cushions, I need to work on saving some money! Whilst I would love a wolfy's exhaust, at £460 plus delivery, it isn't going to happen, so I need to work on an alternative.....
Anyone need a good dg, new dibby, choke pull down, water pump, leads, plugs, exhaust rebuilt, etc...
Date Posted: 01 May 17 at 18:09
Hi all,
Overdue an update, all the little jobs done, interior upholstery is away for recovering, new curtains waiting, electrics sorted, reversing camera fitted, split charge all done and a solar panel fitted, interior cleaned etc. Headlamps uprated, some of the woodwork repaired and recovered.
It took a good weekend to repair the front and rear bumpers, the front was in 2 halves, riveted together badly and the rear wasn't much better
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170402_094316_zpsgf4cbghg.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170402_094017_zpsrdy0vi2t.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170402_093852_zpseltkzpms.jpg.html" rel="nofollow">
A good day with the fibreglass and filler and a coat of paint and they came up a treat, a set of wahonbuild secondhand brackets later and ......
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170408_163806_zpslb4vtfuy.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170408_183814_zps8an6ys1a.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170408_183824_zps2t5wc6rb.jpg.html" rel="nofollow">
Spent yesterday morning fitting the decals:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/FB_IMG_1493657617392_zpswh8epfsc.jpg.html" rel="nofollow">
I've also been prepping the agg, but I want to use the van before I take it off the road to do that.
I've got the DG running ok, but not brilliant, it doesn't pull on the higher rev bands, it sounds like it is misfiring, I think I am going to throw in the towel and send it to a local garage
Posted By: scottish vanners
Date Posted: 04 May 17 at 11:47
looks great Thumbs Up
Date Posted: 11 Jun 17 at 21:44
An update.
Been away in it a few times, it's been great, I can't get on with the wbx tho.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170513_170921_zpsi2prxj59.jpg.html" rel="nofollow">
So, yesterday morning, this happened:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170610_092814_zpsjvdis85k.jpg.html" rel="nofollow">
And this went in:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/IMG-20170610-WA0003_zpsdogmychm.jpeg.html" rel="nofollow">
Exhaust done, I purchased a down pipe off here, an elbow and comussioned a stainless steel 32" x 6" silencer. Easily fitted together and clamps welded onto the silencer to fit jx rubbers
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170610_175608_zpsbpnbyznl.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170610_1839490_zpsesg6lv6w.jpg.html" rel="nofollow">
And Terrano II air filter fitted with butchered volvo v40 intake hose:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170610_153451_zpsmvdzcakd.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170610_153503_zpsykv6zkfn.jpg.html" rel="nofollow">
This morning, fuel system done and engine plumbed up:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170611_155507_zpszaqieg6r.jpg.html" rel="nofollow">
And now wiring.....
Date Posted: 25 Jun 17 at 10:37
Wiring all done last week.
Had a bastards of a time trying to get comms to vcds (thanks Barny), so borrowed another ecu and immo just in case, still nothing.
I bought one of these:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/Screenshot_20170623-161307_zpszogqizbh_edit_1498383119307_zps0ume6dtn.jpeg.html" rel="nofollow">
3 wires connected and it starts first flick of the key, yay!
I put it in a small potting box with the obd socket:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170621_202920_zpsts8vxb3q.jpg.html" rel="nofollow">
And mounted it at the front of the van, I'll break the k-line for the immobiliser at some point.
Also built one of these - works a treat
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170624_123958_zpsmb8aqbqx.jpg.html" rel="nofollow">
That works a treat too.
The exhaust is noisier than I want, so I will probably extend the tail pipe a bit.
I also nood to sort the wobbly brakes and replace the speedo cable.
Date Posted: 25 Jun 17 at 10:38
Oh, and fit an injection tank as the pump is not happy with the 8mm feed, luckily I have one ready.
Posted By: club joker 84
Date Posted: 25 Jun 17 at 22:15
Good work on the speed sensor Wink.  Glad to hear it is working for you!
Ben
Date Posted: 25 Jun 17 at 22:28
Yes, many thanks for that.
Date Posted: 02 Jul 17 at 20:18
Had a weekend with vcds, initially trying to fix the hall sensor and other error codes but made them worse.
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170702_115733_zpsiomndwpq.jpg.html" rel="nofollow">
Wouldn't even run properly. After a bit of head scratching I suspected the engine multiplug, it had been damaged by the guys who rem9ved the engine. A good spray with Wurth Contact ol sorted it and error codes came up as:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170702_161535_zps6xyuxuwc.jpg.html" rel="nofollow">
The maff is shit so that's unplugged hence the code, new one on order.
Also a pleasant surprise:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170702_095204_zps3hl1sviw.jpg.html" rel="nofollow">
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/20170702_095146_zpsoeru0axy.jpg.html" rel="nofollow">
Now I need to work out how to use that to the best effect...
Date Posted: 02 Jul 17 at 21:06
ooh its you on faceache! that is a nice surprise........ (cam) i take it they couldnt figure out how to get the plug off so resorted to molegrips to get it off? have you got earths to engine? one at t68 to end of cylinder head around water outlet one off coil to rocker-cover and another (for good measure) from earth point on block to chassis or battery? to have that many faults in one hit i would say an earth or two is missing or very poor connection.
Date Posted: 02 Jul 17 at 21:19
Yup, twas me.
The second shot of vcds was wrong above, now updated.
Yes, it's well earthed. The earth leads were fitted before the fuel pipes!
It is all down to the multi plug, they ripped the cable out of the lambda sensor too. I though getting them to remove it would save me the effort - how wrong can you be!
The cam looks like it could be fun:
http://s344.photobucket.com/user/fufflenarnia/media/2016%2009/Screenshot_2017-07-02-21-16-43_zpsiprexxti_edit_1499026752914_zpsjas9pcit.jpeg.html" rel="nofollow">
Solid line is standard cam, dotted line is 272 cam. Torque and bhp
Date Posted: 03 Jul 17 at 21:30
you can suffer lumpy tick over but hey power comes at a price!
Date Posted: 04 Jul 17 at 06:31
I didn't even notice when I bought the engine, it's not lumpy at all. I guess the penalty will come with the mpg,
From the drives I've had in it, there is a power band in higher revs, but it was cutting at 5k, so I couldn't make the most of them, there was still plenty of low torque.
Forum Software by Web Wiz Forums® version 11.10 - http://www.webwizforums.com
Copyright ©2001-2017 Web Wiz Ltd. - https://www.webwiz.net
