15 inch Penta for VW Bluestar T3
Forum Name: T3 Wheel help
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=91884
Printed Date: 09 Apr 20 at 10:53
Topic: 15 inch Penta for VW Bluestar T3
Posted By: jamait
Subject: 15 inch Penta for VW Bluestar T3
Date Posted: 13 Aug 16 at 00:07
Hi All,
I have got hold of these Penta wheels that according to the spec seems to fit.
Anyone got any more info on these and how well these are aimed for a vw T3 multivan?
5x112
ET 35
Martin
Posted By: GavB95
Date Posted: 17 Aug 16 at 09:27
Hi Martin, they should be fine. I've also just picked up a set of Pentas for my Bluestar.
The bolt holes will probably need drilling out to M14, you'll need longer studs on the rear and a stud conversion or longer bolts on the front. You may also need a small spacer on the front.
Thumbs Up
Bluestar T3 running AAZ/flipped box
