Alloy mod help
Forum Name: T3 Wheel help
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=90108
Printed Date: 20 Apr 24 at 07:47 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Alloy mod help
Posted By: apak69200
Subject: Alloy mod help
Date Posted: 05 Aug 15 at 18:47
Hi all,
Just joined the forum so hi all I recently brought a T3 auto sleeper pop top and desperate to put some alloys on her. So I brought a set of Audi a6 alloys which are 5x112 I understand I will need to have the centre bored out. But could anyone please help me on what size studs etc I will require for these to fit. I understand you can buy the whole kit but can't seem to find a site that sells them.
Cheers Andy
Date Posted: 05 Aug 15 at 19:37
Click the banner top right!
Posted By: T3ADICT
Date Posted: 05 Aug 15 at 22:24
what age a6 wheels are they? the newer stuff on quite a few of the range have gone over to a bigger centre bore.
its very helpful of them. (I would think though that it is more likely you have 57.1 centre bore wheels as there are so many more out there)
first of all before you go getting wheels machined it would be worth working out what spacers may or may not be required.
do your wheels have centre caps covering the bolts? depending on the wheel design you may or may not be able to use these once centre bore is machined.
do you know the width + size + et/offset
I can probably tell you what you should need with a bit of information.
