Offset
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=89812
Printed Date: 28 Mar 24 at 10:01 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Offset
Posted By: Stannerz
Subject: Offset
Date Posted: 23 Jun 15 at 18:57
Hi all,
Have had a set of wheels sent over from Budapest!! Ronals nice wheels I was assured they would fit straight on as they were pictured on a T3 I went ahead Problem is the offset is 35 fine if they bolt straight on but they will need 15mm spacers bringing the offset to 20! is this to extreme from the point of view of handling, Tyre/bearing wear? Anyone running similar? can I put up with them? Thanks
Posted By: boxer998
Date Posted: 24 Jun 15 at 08:50
I'm running 25mm and 215s I wouldn't recommend it without power steering. No idea on wear yet although after about 3K they look fine.
Date Posted: 24 Jun 15 at 17:42
if you mean you need to fit 15mm spacers to fit them which in turn will make the new et of 20 then you are moving the wheels further out of the bus - if they fit under the arches theres one problem sorted but you will shift the load to the outside of the centre of the hub which eventually wear out your bearings prematurely
Posted By: Stannerz
Date Posted: 24 Jun 15 at 18:40
Thanks fellas will fit them and see how they run.!
Posted By: Zebedee
Date Posted: 25 Jun 15 at 12:14
What width are they? Oettinger and Projektzwo both offered Ronal R9s in 7" width with a 23mm offset and 8" with 11mm offset both with TUV.
Posted By: Stannerz
Date Posted: 25 Jun 15 at 18:12
Hi They are 7.5 x15 et 35 but will be ET 20 with the spacers
Date Posted: 25 Jun 15 at 18:35
Try them without the spacer first
Posted By: Stannerz
Date Posted: 26 Jun 15 at 07:38
Hi I cant they foul the front suspension arm without spacers!
Posted By: bobby-gg
Date Posted: 26 Jun 15 at 12:01
I'm running 16 x 7.5 et41 Merc alloys, I've had to use 15mm of spacers and longer studs, I think you'd get away with 10mm of spacers with your et35
Date Posted: 26 Jun 15 at 16:51
are you sure the et on the wheels are right? unless there like 10 inches wide they should fit?
Posted By: Bromy
Date Posted: 26 Jun 15 at 21:52
my previous wheels were 7j et 35 and they were close to the suspension but just cleared!
------------- "follow the masses, do the opposite"
Posted By: Stannerz
Date Posted: 27 Jun 15 at 10:34
Hi with spacers they will clear I am just concerned about wear and handling!
