merc wheel drill out
Forum Name: T3 Wheel help
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=89786
Printed Date: 16 Apr 24 at 15:32
Topic: merc wheel drill out
Posted By: trailertrash
Subject: merc wheel drill out
Date Posted: 21 Jun 15 at 21:40
I've got a set of merc alloys that are going to need the stud holes taking from 12mm to 14mm, but the nut seat radius looks a lot smaller than the vans nut seat radius, anyone had any experience of this?
Posted By: cornish pasty
Date Posted: 22 Jun 15 at 20:11
Drilled mine with hand held electric drill, you're only removing a millimetre all round so no real danger of running off centre. My wheels were a taper fit (not radius) so I had to buy extended studs and tapered nuts, get the correct nuts and it shouldn't be a problem.
http://www.youtube.com/watch?v=FjPhopki9sQ&sns=fb
