2.5 BNZ Battery Light - Alternator
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=89501
Printed Date: 23 Apr 24 at 20:05 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: 2.5 BNZ Battery Light - Alternator
Posted By: joncorry
Subject: 2.5 BNZ Battery Light - Alternator
Date Posted: 16 May 15 at 19:34
I went to pick my van up from storage today and noticed the battery light was on and stayed on for the 1.7 mile drive home.
First check was to put my black & decker charger on it as its got an alternator check facility... Sure enough it returned there's a fault.
Then, I ran a full scan using my full fat VCDS:
005379 - Load Signal from Alternator Term. DF P1503 - 000 - Implausible Signal Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 262729 km Time Indication: 0
Freeze Frame: RPM: 777 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 12.01 V Bin. Bits: 00000000 Load: 0.0 % (no units): 0.0
Readiness: 0 0 0 0 1
Has anyone else had this problem?
I'm guessing the alternator is fubar but I thought I'd ask on here just in case.
------------- 87 California 90 Atlantic Both in need of bodywerk repairs!
Posted By: joncorry
Date Posted: 16 May 15 at 19:52
And... having just seen its location, I'd like to meet the designer of this engine and offer my non technical appraisal of its fitment....
FFS, it looks like the front has to come off....
Date Posted: 16 May 15 at 22:47
No need to take the front off, I've just done mine. (See the 'Freewheels and couplings' thread). It's very tight but it's a hell of a lot better than taking the front off. I found it really was worth taking the power steering pump off to give you more room, you can leave the pipes on. Yours could just be that the coupling is stripped, if it is then make sure to check the freewheel isn't seized. I think most serious cases of damage to alternators and A/C compressors are down to seized freewheels.
Testing the water here.. I'm seriously thinking of offering a service for replacement freewheels, couplings, water pumps and powers steering pumps in the North Cornwall/South London areas because plenty of garages either don't understand these gear driven engines or don't want really to work on them. I'm semi-retired these days but I am qualified and insured so what do you guys reckon?
Date Posted: 17 May 15 at 03:10
T5 TDI wrote:
Testing the water here.. I'm seriously thinking of offering a service for replacement freewheels, couplings, water pumps and powers steering pumps in the North Cornwall/South London areas because plenty of garages either don't understand these gear driven engines or don't want really to work on them. I'm semi-retired these days but I am qualified and insured so what do you guys reckon? |
If the demand is there it could be a goer. These engine ancillaries are so crowded if you have lots of experience and know all the tricks you can most likely offer a better (and cheaper) service than someone who doesn't really know what they are doing.
Pity you don't live near me - I'm seriously considering replacing pretty well all these components to ensure I'm not left immobile on the side of the road 10 or more hours drive from home in the middle of nowhere (we have lots of nowhere in Oz).
Date Posted: 17 May 15 at 09:30
We do have literally hundreds of T5's here in Newquay especially in the summer :-)
I've already changed my water pump once even though it wasn't leaking. It was about ten years ago when it was still under warranty. Even though R5 pumps were leaking all over the place, VW wouldn't do anything until it actually filled up the sump with water. (Even the guy on the service desk agreed that it was probably a matter of when not if) So I did it myself. So now, ten years/50k down the line I'm going to do it again.
Posted By: joncorry
Date Posted: 17 May 15 at 09:37
It sounds like quite a job, possibly beyond my capabilities. I'd readily pay for it to be done but alas I think my radius is limited to local garages due to the battery and as its one of the rental vans and going out next Saturday... I'll check out the fuse under the battery tray as well, when I looked last night the gates coupling was just visible and seemed to be spinning.
Posted By: joncorry
Date Posted: 17 May 15 at 12:26
Checked the fuses under the battery tray and all are good. I disconnected the split charge system too, just to check there was no issue there, alas the battery charger alternator test function still said it wasn't enough.
Sadly, I think its garage time.
Date Posted: 17 May 15 at 14:56
joncorry wrote:
..... when I looked last night the gates coupling was just visible and seemed to be spinning. |
If the gates coupling is chewed out on the inside on alternator side the exterior of the coupling will rotate, but it won't be driving the alternator.
Date Posted: 17 May 15 at 18:00
gregozedobe wrote:
If the gates coupling is chewed out on the inside on alternator side the exterior of the coupling will rotate, but it won't be driving the alternator. |
Exactly The couplings always strip in half like this-
If it is just the coupling stripped and you are 80k-plus get the freewheel changed. If it's a new alternator needed most of them come with a new freewheel anyway. Ask the garage to check if the freewheel on the old alternator was actually working just out of interest.
There have been a couple of reports on the other forum where the alternator drive gear has undone itself. This is really bad news and if any damage is done to the rest of the geartrain it's RIP engine. I think this (rare) fault could be due to a seized freewheel.
Posted By: joncorry
Date Posted: 17 May 15 at 18:10
Cheers chaps for the info, that makes perfect sense to the technical ludite like me! I'm getting a few prices, including from VW Van centre in Liverpool. Having seen the price of the alternator and the coupling.. I'll make sure I'm seated when they deliver the quotes.
Date Posted: 17 May 15 at 18:15
Let us know how it goes and of course, how much they are charging!
Posted By: joncorry
Date Posted: 21 May 15 at 11:25
Its all sorted. I used a chap from facebook 'ME Automotive' to do the job for the simple reason that I'd have cocked it up.
He elected to remove the front: http://smg.photobucket.com/user/joncorry/media/9DE5F400-5205-4BB2-B2F4-03F2146D4B8E_zpsxzawz0li.jpg.html" rel="nofollow">
The alternator is in a stupid spot in my non technical opinion but there for a reason...: http://smg.photobucket.com/user/joncorry/media/55980510-0726-4CD2-B4C2-6BE35206A1A2_zpsm2asdmw7.jpg.html" rel="nofollow">
Anyway, I got a new alternator for £130, the coupling was £60 and labour was £240. The job was done on my drive, absolutely no mess during or after it and all is well again. Mark is a top chap, very professional and knowledgeable and I'd recommend him. He even travelled from Staffordshire up to Warrington.
Date Posted: 21 May 15 at 18:18
Excellent result
Date Posted: 21 May 15 at 20:58
Yes, and thanks for reporting back. 162,000 miles isn't too bad for an alternator if it was the original. Any news on the state of the freewheel on the old alternator?
Posted By: joncorry
Date Posted: 21 May 15 at 21:04
T5 TDI wrote:
Any news on the state of the freewheel on the old alternator? |
I've got the old alternator in the garage, the teeth on the pulley are in good nick as was the gates coupling. The freewheel seems ok, spins freely and no play. I'm guessing its the bit on the back (plastic) that has failed.
Date Posted: 21 May 15 at 22:45
If you stick something through the cooling holes of the old alternator to lock the shaft (you can use a splined tool to hold the centre of the shaft if you have one) the pulley should then still be able to 'slip' in one direction if the freewheel is working. If the freewheel is seized, once the shaft is locked the pulley won't turn either way and just behaves like an old skool solid pulley.
Date Posted: 16 Jun 15 at 12:37
joncorry wrote:
Anyway, I got a new alternator for £130, the coupling was £60 and labour was £240. |
Those prices look excellent value to me. T5 parts are rather more expensive in Australia. I've just received quotes from my local VW dealer for parts only (no labour) (all prices $AU):
Alternator: $1,019.48 (Gates) coupling: $214.02 Air con compressor: $1947.07 Freewheel: $326.37 (Gates) coupling: $214.02 DMF $1,661.75 Power Steering pump: $ 736.98 Water pump: $475.62
Labour to install all the above would add significantly to the total.
I have been considering replacing all the above as a "pre-emptive counter-strike" to ensure maximum reliability. I do lots of interstate trips away from home so I want a very reliable van. My T5 hasn't really inspired me with lots of confidence (it has been carted home on the back of a flat top truck 3 times so far, and had several other non-mission-critical faults). In the past I've been covered by VW's warranty and then the extended (Allianz) warranty, but now I have to foot all the bills regardless.
Considering my options has led me to seriously consider one of the new model M-B Vitos. Such heresy on a VW forum, I know. I'm not worried about rust (where I live is quite dry).
I looked at Hyundais when I was waiting (months) for the gearbox to be fixed on my T5 but didn't like them much, and I have read too much about Transit and Renuualt problems to go there.
And of course the T5.1 seems to possibly even worse than my T5 (EGRs every x,000 miles anyone ?
I suppose I'll look at the new Vitos when they finally get around to selling them here and decide one way or the other ( I already know I hate foot operated park brakes for vehicles with manual gearboxes).
Posted By: The Transporter
Date Posted: 16 Jun 15 at 20:42
Greg, I'll keep you informed about my Transit... 1000 miles so far and the doors still haven't fallen off. If it gets to 2000 miles without the window falling out, then it is one up on my T5
Posted By: Alonline
Date Posted: 17 Jun 15 at 00:55
Remember Kev the Gas and I spoke too soon post!
Now Gregg the fact you have though about it lighting will strike!
Wonder should I open a VW parts export to AU land?
Date Posted: 17 Jun 15 at 02:19
After last night I have completely lost faith in my local dealer. Had my Skoda in for a cambelt change and waterpump etc, plus seatbelts stalk. $AU 1535.00 later went to collect car, they couldn't find key or car. After 1/2 hour of further waiting they found car (out the back paddock), but the key was nowhere to be seen. I got sick of waiting so used my spare keys to get home. I'm so glad I'm such a "be-prepared" boy scout
I'm still waiting to hear about the key they lost.
Maybe I'll ditch VW altogether and buy a new Mazda MPS 3 when they come out later this year/early next year to complement a new Vito 119 CDI
Date Posted: 17 Jun 15 at 08:38
Wonder should I open a VW parts export to AU land? |
Yeah, that's why I have kept quiet about the Custard so far...On a brighter more positive note, the T5 hasn't had any new issues for the last 8 weeks...
Was thinking the same as you about parts to Oz
Posted By: Alonline
Date Posted: 18 Jun 15 at 23:15
I would have asked for service managers key for his car and told him I will take that until you find my key.
Posted By: Alonline
Date Posted: 18 Jun 15 at 23:19
I would charge 70$ fir the half hour wait.
So Skoda is as bad as VW
Date Posted: 19 Jun 15 at 09:28
In my town VW IS Skoda (same dealer, same service people, different new car sales people)
Posted By: RichardF
Date Posted: 02 Sep 16 at 13:15
It's been a while since I posted here. Having a T3, I don't have so many problems as owners of new vans
Anyway, my son, who lives in Denmark, has a T5 7H 2.5 TDI 174cv, which seems to be at the point where he should check out/replace the freewheel clutches and couplings for the alternator and aircon compressor.
I have offered to get the parts for him from my supplier in France, as they are a lot cheaper here than Denmark. I have found the clutch and coupling for the alternator, but can't find them for compressor on the website.
Can anyone tell me if the parts are the same as those for the alternator, please?
Also, any other parts he should look at while he has the front off?
Date Posted: 02 Sep 16 at 15:28
Yes, both couplings and the freewheels are the same for the alternator and the A/C. In case it's worth you buying in England Eurocarparts are cheap. The freewheels are made by INA (same as original parts). They are quite hard to find on the ECP website so here is the link: http://www.eurocarparts.com/search/425440240
Bear in mind if you search around you can get up to 31% off that price when they do offers. Today it's 20% so that would be £140.78 for all four parts.
Posted By: RichardF
Date Posted: 02 Sep 16 at 18:22
Thanks for that info' T5 TDI. The 4 parts here cost €209, about £175, so a bit cheaper there.
Is there anything else he should check out while the front end is off?
Date Posted: 02 Sep 16 at 19:04
If it's showing signs of poor cold starting or has done vast mileage you could replace the glow plugs and the coolant temp sensor (cheap) while you can get at them. I have done 103 k with mine and it's fine. It is a bit colder in winter Denmark though I guess! If there is any reason to think the camshaft is worn, (I hope not because it's very expensive!) it will need the front off to do, so now would be good time.
You can actually replace the freewheels and couplings without taking the front off which saves a good few hours. I had a guide with photos up on here until recently but when I wanted to edit it, it kept losing parts of it so I have deleted it for now. If you want it I can email you the file.
Posted By: RichardF
Date Posted: 02 Sep 16 at 20:43
Thanks again, T5 TDI.
I'll forward a link for this thread to my son, maybe he'll have time to read it during his busy weekend!
Posted By: Potatoman73
Date Posted: 06 Dec 18 at 22:46
T5 TDI wrote:
No need to take the front off, I've just done mine. (See the 'Freewheels and couplings' thread). It's very tight but it's a hell of a lot better than taking the front off. I found it really <span style="line-height: 15.27272605896px;">was </span>worth taking the power steering pump off to give you more room, you can leave the pipes on. Yours<span style="line-height: 15.27272605896px;"> could just be that the coupling is stripped, if it is then make sure to check the freewheel isn't seized. I think most serious cases of damage to alternators and A/C compressors are down to seized freewheels. </span>
<span style="line-height: 1.4;">Testing the water here.. I'm seriously thinking of offering a service for replacement freewheels, couplings, water pumps and powers steering pumps in the North Cornwall/South London </span>areas because plenty of garages either don't understand these gear driven engines or don't want really to work on them. I'm semi-retired these days but I am qualified and insured so what do you guys reckon?
Could you pm me the guide to removal without taking front end off. Thanks
Date Posted: 07 Dec 18 at 23:38
No problem but not for a couple of weeks since I only have my y at the moment. Consider going the whole hog and taking the front off though if you don't have a known history because there are other jobs that may crop up later that can only be done this way.
