Stuck in wildest Northumberland
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=85879
Printed Date: 23 Apr 24 at 13:18 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Stuck in wildest Northumberland
Posted By: Kindasquirrelly
Subject: Stuck in wildest Northumberland
Date Posted: 02 Aug 14 at 19:01
Hello, Away using the van as she is meant to be. 2.5 D24 non turbo Injector pump belt has shed lots of teeth. Could someone please give me a basic guide to replacement and rough timing up? Or direct me to a relevant thread? I can't find one. I have a Haynes but of course it is for petrol motors. Thank you I have to be back to the grind in Heaven Wednesday morning.
Date Posted: 02 Aug 14 at 21:32
Looking for something written but found this instead.
http://www.youtube.com/watch?v=FTXAm4P6nXU" rel="nofollow - http://www.youtube.com/watch?v=FTXAm4P6nXU
Locked out of my MediaFire account so I cannot share the Manuals' written with pictures at the moment. Will keep trying to find a way.
?Where in Gods' own county are you?
Date Posted: 02 Aug 14 at 21:45
http://www.mediafire.com/view/so05c5fawq7v0vj/IPSetting.pdf" rel="nofollow - http://www.mediafire.com/view/so05c5fawq7v0vj/IPSetting.pdf
Done it, you just need to confirm it has worked.
Date Posted: 02 Aug 14 at 21:57
http://www.brick-yard.co.uk/forum/fuel-pump-timing_topic61498.html?KW=pump+timing" rel="nofollow - http://www.brick-yard.co.uk/forum/fuel-pump-timing_topic61498.html?KW=pump+timing
http://www.brick-yard.co.uk/forum/diesel-pump-timing_topic57616.html?KW=pump+timing" rel="nofollow - http://www.brick-yard.co.uk/forum/diesel-pump-timing_topic57616.html?KW=pump+timing
If you mark it all up when taking it off you should be OKish, but bear in mind the cam pulley is not keyed to the cam so if you take that off as well, you will struggle to get the timing right without the proper tools.
http://vincewaldon.com/index.php?option=com_content&task=view&id=24&Itemid=28" rel="nofollow - http://vincewaldon.com/index.php?option=com_content&task=view&id=24&Itemid=28
Date Posted: 02 Aug 14 at 22:42
I'd be concerned why the belt shed its teeth, if within the change interval.
For a rough on the road repair, you could probably get away with removing the cam pulley, getting the slot in the end of the cam horizontal, get the IP pulley so you can fit an improvised timing pin through the hole (I reckon something like an M16 bolt might do?) and the timing should be close enough to at least run.
Date Posted: 03 Aug 14 at 11:36
Engine manuals can be found here if it's any help.
http://www.mediafire.com/folder/d90hbt7ndxl54,xg5ivm3y8ub76,nfat7w4u3dyvi,tbkq303quqtag/shared" rel="nofollow - http://www.mediafire.com/folder/d90hbt7ndxl54,xg5ivm3y8ub76,nfat7w4u3dyvi,tbkq303quqtag/shared
Date Posted: 03 Aug 14 at 15:11
Thank you for all your help. Home is near Driffield
Date Posted: 03 Aug 14 at 15:36
The manuals and other advice will be enormous help. To give you the background, I was cruising along there was a clatter she kept running but badly. I pulled over and she stalled and would not restart. I took off all covers and with help from a local garage spotted the stripped teeth. Foolishly I haven't changed any belts in the last six years (will do them all when I get back). He reckoned age and a slack belt may have caused them to strip. The pump turns OK with the usual pump resistance. This is the first day without rain. My first challenge is to get at the crank bolt to turn to TDC. There is a lot of corrosion on the rad cowling bolts. I have ordered the belt for tomorrow hopefully I can get the M16 and a 27 mm socket. The AA can take me home but pride tells me to get her running here (Beadnall) Thanks
Date Posted: 03 Aug 14 at 20:27
You may need a file, grinder or lathe too.
For some reason, 'NewPosts' does not always bring up all new posts, so I missed your post at 15.36pm. I know I was checking all day.
Good luck, typical that it happens on a work day.
Beadnell, with an E, just in case the AA cannot find you.
Date Posted: 03 Aug 14 at 20:39
I have a bicycle and a cheese grater. I'm sure I can work something out!
Date Posted: 03 Aug 14 at 20:41
That's the spirit.
Date Posted: 04 Aug 14 at 18:45
Hello, I could see the manual when you sent it but no longer ( now I have the belt) Can you give me any advice? I am using an IPad and have downloaded the media fire app. Thank you
Date Posted: 04 Aug 14 at 19:12
Hello, If anyone can help. I cannot find the TDC O on the flywheel. I have rotated it twice tooth by blessed tooth. Other than taking an injector out is there any other way of finding TDC? There is a V cutout on the Cam pulley that drives the injector but I have no idea what to align it with. Sitting here on the campsite frustrated. There are some Germans here perhaps they will know about VW's will go and ask. Please get in touch if you can help
Date Posted: 04 Aug 14 at 19:58
According to the manual there is an 'X' about 50mm from the TDC on the flywheel. It does not seem to say which way though.
Edit; A picture shows 'above'
I think, but not having done it or being able to remember where I saw it, that the cam lobes on cylinder 1 should both be pointing evenly up. Logically this would be correct, highest lift furthest away from the valves.
Date Posted: 04 Aug 14 at 20:14
http://forums.turbobricks.com/showthread.php?p=1925387" rel="nofollow - http://forums.turbobricks.com/showthread.php?p=1925387
From D24 Manual.
Turn engine until cyl. 'l is at TDC - iniection Always use the vibration damper center bolt to turn the engine. 27 mm socket or wrench 5188. Both cylinder 1 cams should point obliquely upwards. Flywheel at 0 mark
That may help you find the '0'
Date Posted: 04 Aug 14 at 20:47
Thank you for all this help. I am moving the flywheel with a screwdriver a tooth at a time! I tried taking the cam cover off but succeeded only in rounding off the nuts I was unable to get the radiator shroud off with the tools available. The battery is now going flat so it looks like the AA home. Boo!
Date Posted: 04 Aug 14 at 21:11
Shame, but at least you did not lose your holiday by it happening at the start.
See you some time maybe.
Posted By: markpark
Date Posted: 04 Aug 14 at 23:48
The mark on the flywheel is almost impossible to see. I remember having a ballache with mine but can't remember how I found it as it was a long time ago.
------------- DJ T3 homrbrew camper and 98 LT 2.5 TDI crew van
Date Posted: 05 Aug 14 at 01:54
Are the D24's a "safe engine", cos when a belt snapped on my SD1 it turned the valves into lovely shapes.
Date Posted: 05 Aug 14 at 23:41
Hello, Thank you all very much,especially LT Campers. Thompsons of Seahouses picked it up this afternoon to start the joyous relay back to Driffield. They decided to take it back to their garage to have a look first After a fair bit of fiddling they found I had the timing 180* out! They retried it she started but would not run, come on girl! Moved it a tooth and she struck up first kick (oops slipping into motorbike prose) Woo hoo! Repacked her slipped em a tenner (they were charging it to the AA anyway) In case anyone has the same woes as me this is what they did. Jacked up one back wheel put it in 5th and found TDC much quicker than I did by turning the wheel. They lined up the cutout on the cam pulley with a marker on the cam housing at about 7 o clock and it was within a tooth straight away. There were two pros doing it mind but a top set of lads who could just as easily have packed us off on a low loader. Just tucking into a second Bloody Mary. Thanks again everyone
Date Posted: 06 Aug 14 at 06:08
Brilliant.
I will remember that name, Thompsons of Seahouses, for future use.
You get another lovely day in Northumberland too.....except it is raining a bit here.....
Motorcycle prose accepted here, there are lot of us.
Date Posted: 06 Aug 14 at 07:26
Excellent news, enjoy your hols mate.
Posted By: dr-rob
Date Posted: 06 Aug 14 at 07:58
Great news dude, Thank you for the " how to guide " also as I'm sure this will help others and myself as my other lt is a TD with its head off, Rob
------------- little trixie the lt28 [1985] diva the disco lucy the land rover 1200 sportster bike in boxes so babe iv seen this.... NOOOO...No more projects.... yeah but.... I SAID NOOOO Bloody mrs
Date Posted: 06 Aug 14 at 17:41
http://ajkthompson.co.uk/" rel="nofollow - http://ajkthompson.co.uk/
There often enquiries for good garages around and about, who will not shy away from LTs, I think these fellows fit the bill nicely.
AndyT, ?Worth having a sticky in Chat, in which to list the helpful ones?
Date Posted: 06 Aug 14 at 19:46
Possibly, only difficulty is getting full & accurate information. Plus you'd have to scroll through all the entries to see if there was one nearby. Give it a go, if there's a good response I'll make it a sticky.
