Hi Guys We have a special offer for members of this forum (and South West Dubs) ONLY
Due to an overorder by a customer we have 10 sets ONLY of untreated (rat look) side bars for Splitty, Bay or T3 (we we fit the correct brackets at time of order)
PLEASE NOTE - LISTING IS FOR A PAIR OF SIDE BARS
At Stuke Designs we design and make our own unique side tubes with bespoke laser cut brackets that have slotted bolt holes to allow for precise fitting. Brand new high quality RAT LOOK / UNCOATED side tube / bars for T2 Split Screen T2 Bay Window and T3 Brick vans, campers, pick ups etc We can also arrange to have these Black Powder Coated PLEASE NOTE - These are NOT cheap imports but are designed and manufactured by ourselves here in the UK so you can be confident of the quality every time We make all our bars to order so please allow up to 10 working days for your order to be dispatched. If you require a more urgent service please contact us for availability. They are made from 63mm (2 1/2 inch) O/D tube with a thick 1.5mm walls. The brackets are the same dimensions as the jacking points and are TIG welded for extra strength. The bars are then left untreated for that rat look or for you to prep and paint to suit your requirements All of our bars come as a pair with full fitting kit and instructions Fitting is very easy and all you need are 2 x13mm spanners or 1 x13mm spanner and 1 x13mm socket. Can usually be fitted in minutes NO DRILLING OR WELDING REQUIRED TO FIT THESE TO ORIGINAL JACKING POINTS. If you have after market jacking points in a T2 you may need to drill a 10mm hole in the underneath of each jacking point to allow for securing bolt These bars should fit all T2 Split Screens, however for Barn Door side bars please contact us for availability. Probably the best value for money side bars currently on the market. If you would like any more information on these bars or any other item for sale by Stuke Designs do not hesitate to contact us on 07971241381
http://s408.photobucket.com/user/21windows-bratpack/media/Stuke%20Designs/Ratbars1_zps84196e9f.jpg.html" rel="nofollow">
We are offeriig the first 10 customers the chance to buy a pair of side bars for only £49 (or £74 for the zinc primed and black powder coated versions) We can arrange postage at £20 per set to mainland UK only
If you would like to order a set please contact us for availability
Many thanks
Stuke Designs
------------- Graham Williams & Stuart Williams Stuke Designs email stuke.designs@gmail.com Tel 07971241381
