help please (relay position)
Forum Name: South African T3s
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=80074
Printed Date: 20 Apr 24 at 15:01 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: help please (relay position)
Posted By: alxjsy
Subject: help please (relay position)
Date Posted: 05 May 13 at 12:00
Ok I will start with I made a balls up...
The other half's van has started with the dreaded blinking light issue, so I did a bit of research on the matter and started trouble shooting (as she stole my landrover and left the van this morning, didnt really have a choice)
However, Ive just finished 60hr night shift and not really awake....so...... I pulled relay 42...... and forgot where I pulled it out from...
Been hunting for pics of the relay/fuse box but no joy, does any body have one please, pretty please. Bit disheartened with the van at the moment cause it has been one issue after another lately . Cheers in advance
Alex
Posted By: Wychall
Date Posted: 05 May 13 at 12:42
Need to know what vehicle you have matey.
IF we are talking post 1991 big window then relay 42 is in slot 5 which is top row, 5th from left.
------------- South African 1991 2.5i 5cyl Microbus - virgin, not campered - piloted by Brian.
Posted By: alxjsy
Date Posted: 05 May 13 at 13:36
Thanks,
Trouble shooting fixes have still not solved the issue..
Posted By: TransPorscher
Date Posted: 25 Sep 13 at 09:34
Are you referring to the water temp gauge blinking ? The problem is most likely to be the gauge NOT the rest of the circuit. My brother ( RHGbristol on here ) rebuilds the gauges. Contact him he'll probably do you an exchange.
PS. All T3s have 1 issue after another,I've corrected 1 bodge after another on my 2.5 even after previous owners thought they had a "well sorted" bus !!! But I do 1000s miles around Germany ever year and mine has never broke down !!! :)) Plus nearly 500miles range on LPG is a BIG bonus !!!
PPS. If you haven't had them off Brian yet I can send you a printed copy of the 2.5 wiring diagrams ?
------------- Charlie
Small Moves Big Grooves! WeFunkRadio.com
Posted By: Wychall
Date Posted: 25 Sep 13 at 12:26
I need to contact your Bruv Charlie. I fitted the rev counter out of Nev's scrapper and now have the flashing temp light. Fully checked the circuit sheet that came with the rev counter but no joy so it must be the gauge. Different to my previous clock one so replacement required.
