Parasitic battery drain
Category: T4 Section.
Forum Name: T4 Chat
Forum Description: Forum forT4 specific chat.
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=79720
Printed Date: 28 Mar 24 at 12:09 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Parasitic battery drain
Posted By: SebRogers
Subject: Parasitic battery drain
Date Posted: 12 Apr 13 at 13:51
Advice appreciated... my battery's going flat over a week or so standing on the drive.
While my bus was in the paintshop over the winter the battery died on several occasions. No-one really worried too much about it - everyone concerned just assumed it was cos it had been sat around a lot in the cold.
Got it back, battery dead after a few days. Full charge, lasted nearly a week this time. So I bought a new battery.
Which is also now dead, after a bit over a week...
So either both batteries are duff, or I have a leak. I'm going to charge both batteries up. I've cleaned all the battery terminal connections and replaced one that looked a bit skanky. Had a look at the battery earth - looks fine, nice and clean. Can't do much more because the riveted plastic shroud around it makes it hard for me to even get an open ended spanner on there.
With one of the batteries freshly charged I'm gonna disconnect the -ve feed and put a multimeter between that and the battery. That should hopefully show a current drain (if it doesn't I'm really stumped!). Drain established I'm then gonna pull fuses to see if I can isolate the circuit that's the cause of the trouble, starting with the Webasto engine heater (which has never worked and I haven't got round to fixing).
If none of the fuses show anything the only other thing I can think of to check is the earth strap on the starter motor.
Anything else I can check fairly easily?
------------- '85 T3 Doka EJ22 '94 T4 Westy Cali Club ABT 2.4td
Date Posted: 12 Apr 13 at 13:53
Oh, not sure if the 2.4d has an auxiliary water pump, but I've been fiddling around sorting undertray rattles and there's nothing whirring under there, so I don't think it's that issue...
Date Posted: 13 Apr 13 at 01:00
If you weren't driving van during the week the new battery then it is almost certainly parasitic drain. Stereos, alarms and any other wiring mods are the most common culprits, so I'd start pulling fuses to those first.
Please let us know what you find (it might help some other poor soul).
Date Posted: 13 Apr 13 at 08:00
Seb if the leisure battery is goosed then I'm pretty sure due to the way they are wired westys leach power to the knackered battery.
Be thankful yours is an earlier bus, it has two leisures as opposed to the five hundred quid gel type in the later ones!!
Date Posted: 13 Apr 13 at 08:45
Thanks for the replies!
Jase, AFAICT the leisure isn't connected to the main battery at all (and I've only got one, and yeah it's goosed...but not a priority right now). Could be wrong though (thinking about it I probably am wrong, cos of course the alternator charges the leisure...)
Made some progress, anyway. Drain is 180-190mA, which tallies with the week or so it takes to drain the battery. Started pulling fuses, got to no. 21 (interior lights, clock, radio)... BINGO! Zero drain.
So... I'm guessing the stereo is the most likely culprit? It works without the key in the ignition... is this the problem, or is it not that simple?
Date Posted: 13 Apr 13 at 10:49
It might be as simple as the stereo not powering down completely, but sometimes aftermarket Stereos can prevent VW controllers from "going to sleep" properly after switching off the ignition, so it might be caused by the stereo (keeping something else "awake") but the actual current drain is elsewhere.
Date Posted: 13 Apr 13 at 12:39
Thanks!
How would I find out? The 2.4d's a pretty simple beast - no ecu to power down afaik. Also... this was happening with the 'old' Blaupunkt stereo too. The new Alpine head unit only went in recently, which makes me think it might be a stereo wiring issue (rather than an inherent problem with the stereo itself).
I read somewhere about VW's switched and permanent live stereo feeds being the 'wrong' way round?
Date Posted: 13 Apr 13 at 13:26
Also... if the stereo was the cause but the drain was on another circuit, then logically I'd get zero drain pulling both the radio fuse AND the fuse on the culprit circuit...right? Or is it not that simple?
Date Posted: 13 Apr 13 at 13:48
On the radios seb you switch the red and yellow wires for switched and permanent lives.
I'm still putting my money on the leisure supping it.
Posted By: D&D
Date Posted: 13 Apr 13 at 15:16
I agree with Jase as i recently had a problem charging. The leisure charged but the engine battery wouldnt & my bus was pulling on the leisure when trying to start because the engine battery Amps were low, the issue was down to a simple switch, both batteries will be on the same system.
The 2.4 has got a small electric after run pump under the rad. These are nearly always goosed, on my last 2.4 it was still supping power even though it was not working.
------------- Carthago 32.1 T4 LWB BY Golden Nut Winner Chug & Tug Team Member
Date Posted: 13 Apr 13 at 19:43
All good advice, cheers!
Though if I pull the radio fuse and the drain drops from 180mA to zero, I'd have thought that'd rule out secondary pump or leisure battery issues (leisure voltage is fine - 12.7v w/out load, it's just the capacity that's shot).
I'll investigate further...
Date Posted: 14 Apr 13 at 17:29
Update: I'm not 99.9% certain it's the stereo.
Ignition feed wasn't connected; instead the live feed was split and run to the igniton / live inputs on the stereo. So it worked independently of the ignition (good), but was drawing 0.18A permanently (bad). Quick test rewiring as it should be drops the current drain to 0.01A, which is where it should be I reckon.
The trouble is that wired that way it won't work unless the ignition is on. Which is a pain in a camper...
So before I put plan B into action (wire the ignition feed through a switch in one of the blanks on the dash), is there another way to wire it up so that it'll run without the ignition on but not flatten the battery in a week?
Date Posted: 14 Apr 13 at 17:33
On the t4s I've done seb I just switch the red and yellow as the iso wiring live and switched live are reversed on the standard wiring. The stereo then just works off the acc live
Date Posted: 14 Apr 13 at 17:37
Thanks Jase.
Being an early van I think the wiring might be a bit different. Not sure if there's an acc live...
Date Posted: 14 Apr 13 at 17:54
Acc live is first click of the ignition key seb.
Date Posted: 14 Apr 13 at 17:58
Don't have that on my ignition. Off, glow plugs, start...
Date Posted: 14 Apr 13 at 17:59
... which would explain the stereo wiring
Looking like a switch on the dash, then...
Posted By: Piledriver
Date Posted: 14 Apr 13 at 19:14
......sounds like a plan seb
Date Posted: 14 Apr 13 at 19:31
Piledriver wrote:
I want one like that
Posted By: Alonline
Date Posted: 14 Apr 13 at 21:27
Wire it to the leisure, that way it can kill that, but you will be able to get started and it can charge or as others said Good old switch but how good is your memory to remember to switch it?
Date Posted: 14 Apr 13 at 21:49
Alonline wrote:
Wire it to the leisure, that way it can kill that, but you will be able to get started and it can charge or as others said Good old switch but how good is your memory to remember to switch it? |
Might wire it to the leisure as a future project... For now though, switch'll get me going. Eyeing up one that lights up red when it's on. Reckon I'll remember to switch that off!
Posted By: Alonline
Date Posted: 14 Apr 13 at 23:44
SebRogers wrote:
Might wire it to the leisure as a future project... For now though, switch'll get me going. Eyeing up one that lights up red when it's on. Reckon I'll remember to switch that off! |
Will that colour match the colour of the wine?
Date Posted: 18 Apr 13 at 20:59
Right then. Here's where I'm at:
Ignition does have an 'acc on' position which feeds the switched ignition live. BUT there seems to be a problem - the supply intermittently cuts out completely and randomly (but only to this one cable). So I need to replace the ignition switch, which is the most obvious culprit...
In the meantime I've bypassed the ignition and plumbed in an illuminated switch via the battery feed. It means I have to switch the power to the radio on separately even when the key's in the ignition and on, but it also means I can't forget to switch it off.
Current drain is down to 10mA with the new switch set to 'off'. That'll do me
Date Posted: 18 Apr 13 at 21:20
Ignition switch is not as simple as it appears to change seb .
Date Posted: 19 Apr 13 at 07:11
That's what I thought Jase. But according to http://www.vwt4forum.co.uk/showthread.php?t=8993&highlight=Ignition+switch" rel="nofollow - this it's not too bad...
