T3 1.8t conversion build thread
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=76783
Printed Date: 28 Mar 24 at 18:01 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: T3 1.8t conversion build thread
Posted By: Sid1800
Subject: T3 1.8t conversion build thread
Date Posted: 07 Oct 12 at 18:18
T3-1.8T Conversion Thread Hi just starting my 1.8t conversion in a vw T3did the conversion a year ago with a 50 degree engine how ever it all fitted perfect but the gearbox could not handle the power from the 230bhp engine. it was ok for local driving even at traffic lights line up. but motorways it was a bit loud due to the gearbox gearing. this time i am doing the conversion at 15 degree with the help of tims adaptor plate which will fit to the audi gearbox flipped upside down. before i ran a stand alone ecu from qpeng. im in two minds as to which ecu to use at to moment. thats the last job on my mind. Heres a few pictures as the project goes on, this pic is when i had the 2.1 petrol engine After i took the 2.1 out i started cleaning the engine bay by sandblasting it and then sprayed it with rust remedy and then top coated. Went out and bought a Audi a4 1.8t sport with 105,000 on the clock, stripped it down and took the engine out first thing was to get rid of the things that i didnt need like the power steering and a.c as iv alredy got electronic power steering. Heres the pics of the pullys modified to run the external water pump. After this i took the original engine support bar out from the T3 and cut the mountings off and cleaned the bar up, made the extensions for the support bar and made some mountings to support the engine. Next step was to cut 15mil off the gearbox bell housing as the 15mil adapter plate is going on to flip the gearbox upside down. I did this by making my own jig and then using a router carefully cut 2mil at a time which was time taking but it cut with ease. Before cutting i had to drill the dowl holes deeper as not to lose them. Now im waiting for tim to get the adapter plate, gearbox mounting and cv joints so i can carry on mocking the height as where it will fit and then i can work out how high the engine will sit, will keep you informed as the project goes on and notify me with any ideas or tips.
------------- S-Line Motors-Photobucket German Vehicle Specialist
07971728333
Posted By: T3Panel
Date Posted: 07 Oct 12 at 18:31
Can't see your pics. If they have T2 5 in the title, swear filter changes it to T3, so you will need to rename them.
------------- 1987 T3 Panel 2.0 T3i! 1990 T3 Atlantic 1.8T Conversion sat on an engine stand waiting for spare time.
Posted By: Cableguy
Posted By: Sid1800
Date Posted: 07 Oct 12 at 18:45
Dont no why the pics dont show up have tried different ways . . ??
07971728333
Posted By: Sid1800
Date Posted: 07 Oct 12 at 19:51
Cableguy wrote:
Where's the photos? |
How about now ? Think photobuket was the problem
07971728333
Posted By: T3Panel
Date Posted: 07 Oct 12 at 20:34
Cracking! Keep it coming!
What engine are you using? Is it an AWT, or a later post 2001 engine?
Posted By: Sid1800
Date Posted: 07 Oct 12 at 21:26
The engine using is aeb cable throttle at the moment Maybe upgrade to 225bhp as my first conversion
07971728333
Date Posted: 08 Oct 12 at 00:44
shit, competition...
s'all good chap, looks like the race is on - http://www.brick-yard.co.uk/forum/turd-polishing-101-red-oxide-gti-t3_topic69606_page9.html" rel="nofollow - see turd polishing 101 thread...
be good to compare shizzle..
Posted By: T3Panel
Date Posted: 08 Oct 12 at 00:46
The race is definately on, and like a proper gent, I plan on coming last
Date Posted: 08 Oct 12 at 00:54
and I plan on being first, but with the least amount of engineering prowess..
FFS he's even made a jig to rout the gearbox, that gets a win in my book from the start, my gearbox is now 15mm shorter but with no need for a jig..
and he's thought about "dowl holes".. fuck....
better crack on, I've got a junior hacksaw here with some fresh blades, it'll be fired up by morning.
Posted By: T3Panel
Date Posted: 08 Oct 12 at 00:56
Posted By: Sid1800
Date Posted: 08 Oct 12 at 08:05
Talking about being first check YouTube Vw caravelle/ s3. This I did a year Ago
07971728333
Date Posted: 08 Oct 12 at 10:27
seriously chap, only kidding about being first, good to see someone else playing with the 20vt - it's a great engine.
Can I ask you about the external water pump and modified pulleys etc.. on the pic above?
Posted By: Sid1800
Date Posted: 08 Oct 12 at 13:55
On the earlier 20vt the waterpump is on the Outside .you need to cut the alternator bracket In half so you can mount the alt back on You can then get a vr pump pulley and use that As the waterpump pulley and your done. Alternative is to use mk 4 pulley take waterpump Of and press the front pump about 2 mil in so It lines up with the crank pulley . Hope that helps
07971728333
Date Posted: 08 Oct 12 at 13:58
cheers mate!
Date Posted: 08 Oct 12 at 17:24
mrhutch wrote:
cheers mate! |
he didn't understand that one bit!
Posted By: T3Panel
Date Posted: 08 Oct 12 at 17:37
Sid1800 wrote:
Talking about being first check YouTube Vw caravelle/ s3. This I did a year Ago |
Bet the corsa driver was a bit shocked
Posted By: fufflenarnia
Date Posted: 08 Oct 12 at 19:18
That's a brilliant video.
Now I am all intreagued on a 50° fitting - does it fit under the lid OK? Also, what mounts did you use?
Posted By: Sid1800
Date Posted: 08 Oct 12 at 19:57
the 50 degree fitting will not sit under the lid you have to lift it by 6-7 inches. the mounts have to be made up but the bars are the standard diesel ones also you need to re make the sump.like a diesel sump. turbo oil return has to be moved. diesel belhousing g60 flywheel and vr6 clutch if you are interested i do have all the bits to do the conversion again. except for the flywheel and clutch
07971728333
Posted By: Sid1800
Date Posted: 08 Oct 12 at 20:10
Today i made the breather for the gearbox and blocked the original breather hole.
07971728333
Posted By: T3Panel
Date Posted: 08 Oct 12 at 21:17
7 inches?
That seems like an awful lot, also taking the need to change sump, turbo oil return etc etc into account.
I keep coming back to the same example, but http://www.gmwerks.com/Vanagon.html" rel="nofollow - These guys do it at 15 degrees and raise the deck lid by an inch. Also means no messing about with sumps and oil feed returns.
Is there a reason why 50 degrees is better?
Date Posted: 08 Oct 12 at 21:19
Thanks, that's a shame, as mine is a camper, I cannot raise the engine lid.
Still, that takes away the temptation - I just need to be happy with the agg conversion in it
Best of luck with yours, - I think it will be brilliant!
Posted By: VW Nerd
Date Posted: 08 Oct 12 at 21:34
I am about to start fitting an AFN tdi upright and hope to get it to fit under the std boot floor as the conversion will be into a camper. Time will tell if a 15 deg engine install will fit.
Tim.
------------- Developing parts for the VW T3 TDI market Inc flipped audi gearbox install parts.
Tim Shettle www.ultimate-engineering.co.uk Bristol
Tel/txt 07810 320 464
AFN TDI Panel Van
Posted By: Sid1800
Date Posted: 09 Oct 12 at 19:58
[/QUOTE]
7 inches?
Is there a reason why 50 degrees is better?[/QUOTE]
these guys use the standard gearbox which i know will not last if you are running 200+bhp.unless you drive like an granny! I like to actually drive mine . the golf or audi a3 sumps are flat at the bottom. but the audi and passat 1.8t sump has a big notch in it to go over the cross member this is where i am going to fit my mounting bar so it does not sit below the sump.
07971728333
Posted By: Sid1800
Date Posted: 09 Oct 12 at 21:16
hello Tim regarding the 15 degree on afn engine; should fit under the lid may be because the inlet and exhaust manifolds sit on the left of the engine as posing to petrol where the inlet manifold sit on the opposite side and closer to the lid at 15 degree.
07971728333
Posted By: Sid1800
Date Posted: 12 Oct 12 at 20:10
as you can see im trying to convert my t3 but i have a couple of questions if any one can help. first of all is that im trying to line my gearbox (passat flipped).the gearbox mounting sits of set on the 2.1 t3 do i need to mount the passat gearbox the same way. the other problem is the driveshafts do i need to put a spacer in one side as the gearbox is ofset, or do i move the box to central and try to see if the shafts fit equal. i have measured the shafts and both are the same length. i know some 4 speed have different length shafts. the 5 speed t3 box is wider than the passat. if i centre the box might need to space both shafts equal. like to come up with all advices then put them in a basket to come up with a final.
07971728333
Posted By: VW Nerd
Date Posted: 12 Oct 12 at 22:24
Martyn (Bus boy on here) used 2 equal size adaptors on his Passat gear box which he mounted in a central position. He made his own nose cone mount to suit (so the choice of fitting holes was not relevant as he did not use a std mount here) and he also fitted his 5 cylinder Audi motor where it needed to go to keep the drive flanges on the gear box central to the std 5 speed drive shafts.
Tim.
AFN TDI Panel Van
Posted By: VW Nerd
Date Posted: 12 Oct 12 at 22:27
On my tdi conversion with Flipped Passat gearbox I used the near side set of fitting holes in the chassis cross member for the gearbox front mount.
Tim
AFN TDI Panel Van
Date Posted: 13 Oct 12 at 00:54
I'm keeping everything as central as I can. engine (20VT) and box should be midline, gearbox mount isn't difficult to fab up, as are mounting points on the crossmember.
Got some info on driveshafts as well but not confirmed/tested yet but really want to keep with the stock T3 ones, with different inners.
Posted By: Sid1800
Date Posted: 13 Oct 12 at 12:31
thanks for the info. what i have come up with is that, t3 2.1 gearbox from flange to flange is 286mm audi gearbox 270mm that gives me 16mm difference so if i make 2 spacers at 8mm each put one on each end,then line the gearbox central.i will know the thickness of the spacers once i have got the inner cv. as far as i know the cv should be the same thickness as the stock ones. dont know why i like to keep both shafts the same size not put spacer in one side or use two different shaft sizes. only time will tell!
07971728333
Posted By: MADMATT
Date Posted: 14 Oct 12 at 12:08
another thing to take into account is that when you lower a van the distance between the flanges is shortened over a standard van. even derv and petrol gearbox flanges are in different positions but the drive shafts are the same length.so you have to take the suspension travel into account as well as gearbox position.
Posted By: Sid1800
Date Posted: 14 Oct 12 at 17:07
as lowering vehicle mine is standard, i have measured my driveshaft heights before stripping the van. so when i fit my gearbox in will measure again and try to fit as close to original position plus it depends on the height of the engine,want to raise engine lid by 2 inches the max,if it comes to it. when lowering vehicle you dont change the driveshaft so if you sit the gearbox lower it should not make a difference. if you hold the driveshaft at horizontal and lift it,it gives you the same distance as to lowering it.
07971728333
Posted By: Sid1800
Date Posted: 17 Oct 12 at 21:16
here we have pictures of my spacers which i got a 108 driveshaft gave it to engineers and got them to cut two 8mm spacers for me.
as i was mocking the gear box to the engine notice the oil filter was fouling the gearbox. after measuring up it was only fouling by one of the bolt holes, which i can grind the corner of and the filter will fit. if it was a diesel the oil filter is well bigger and a lot more problem if doing the 15 degree fitting.
07971728333
Posted By: Sid1800
Date Posted: 02 Nov 12 at 19:11
finally got the adaptor plate and mount from tim. started to mock the gearbox to the right height noticed that i cant go to high due to the drive shafts hitting the top of wishbone. here is some of the pictures of the build. next was to mock where the engine will sit first made the engine mounts then fitted the engine. it sits 2 inches lower than the deck lid.could do with it sitting little higher for ground clearance,at the moment it is sitting 5 inches of the ground. had to lower the gearbox mount by 12mm to get the engine to sit level. next step is to fit the drive shafts but dont know which way to go round this yet, if any body can help all is appreciated.
07971728333
Posted By: VW Nerd
Date Posted: 02 Nov 12 at 20:36
The petrol engine bar did not clear the Passat sump when put in line with the factory Passat rubber mounts. I guess from looking at your photos that your sump allowed space for the bar to pass behind the main pan of the sump. Are your alloy mounts from a Passat or another VW Audi car?
Looking good by the way.
I'll let you know what I do to fit my drive shafts next week.
AFN TDI Panel Van
Posted By: Sid1800
Date Posted: 04 Nov 12 at 18:04
hi tim the engine bar does not clear the sump if you line it up from mount to mount. the 2 tubes that fit to the mounts are ofset to the mount bar this gives you access to the nut that goes underneath so you can get a socket to tighten it up. the mounts are the standard ones from the audi a4. went into garage today and did all the water pipes and fuel lines just need to work out where best place to fit intercooler. then the exhaust system.
07971728333
Posted By: VW Nerd
Date Posted: 05 Nov 12 at 08:26
Have you looked at my intercooler scoop design posted on one of my build threads where the intercooler sits on top of the gearbox with an air scoop running down to the gearbox cross member. A low cost install that allows the use of std passat cooler.
AFN TDI Panel Van
Posted By: Sid1800
Date Posted: 06 Nov 12 at 17:32
looked at your intercooler nice job. still looking where to fit my intercooler,reason being is that on the diesel the intake and the turbo is on the same side where as the petrol the intake is on the opposite. dont know if longer pipes will make difference to the time it takes to boost.might still try fitting it on the side of gearbox or just above. now i have got the van on to the floor it is sitting 5 inches from floor. as to oil filter with the adaptor plate in cant fit oil filter on. i might try oil filter housing from transverse engine if it clears the engine mount if not need to buy oil filter relocation kit,then i can put oil filter any where in engine bay.
07971728333
Posted By: Sid1800
Date Posted: 21 Nov 12 at 20:24
sorry for the delay but been busy here is a video of my 20vt caravelle for the first time start up. http://s1185.beta.photobucket.com/user/SLineMotors/media/1C05CEE5-6D91-476C-BCA5-31065B90463C-3967-0000022BDF0323B4.mp4.html" rel="nofollow - http://s1185.beta.photobucket.com/user/SLineMotors/media/1C05CEE5-6D91-476C-BCA5-31065B90463C-3967-0000022BDF0323B4.mp4.html just a few issues to sort out,first of all is the ecu is not sending a signal to switch the fuel pump relay on. maybe because the immobilizer taken out of ecu has cut the supply to the relay but does start with the relay bypassed.the main issue is that the rev counter does not work,i need this to work because i am running electric power steering which needs a signal to work.if any body knows how or if any body can make me a tacho box,from the ecu i got a negative rev wire but does not work with the t3 rev counter. other than that waiting for tim for the gear linkage to go for a test drive. by the way thanks to tim for all the parts supplied and for all the information he has helped me on. if any body doing diesel or petrol conversion tim is your man for all your conversion parts.
07971728333
Posted By: Dyno Soar
Date Posted: 27 Nov 12 at 20:30
Hi Sid, Its nice to see you on here at last. I am keen to see how the 1.8t engine and box going into your van and the TDI conversion you are doing for Chris goes? I am thinking of taking out the SVX conversion you helped me with and going for one of these. Are you doing both of the conversions at the same time? You should stick a few pics of the TDI conversion up when your able in the Diesel upgrade forum. Cheers Al
Posted By: Sid1800
Date Posted: 28 Nov 12 at 19:17
Hello al I will get some pictures up shortly for the diesel conversion. I am doing both vehicles at the same time just waiting on some Parts at the moment. It looks like if you already have diesel the Conversion is much easier if going to tdi petrol takes some fabrication Parts to be made. But I have made it fit under the hood which is the main Objective . Any idea on your svx engine what went wrong with it, is it worth saving.
07971728333
Date Posted: 28 Nov 12 at 21:38
Its coil packs most likely. Just a bit of a bugger really...
Posted By: Sid1800
Date Posted: 29 Nov 12 at 18:01
why dont you flash the ecu to see what code comes up it should come up with coil pack problems.on mine still having problems with rev counter got it to work with taking signal from ignition amplifier,but not accurate as i rev the powersteering kicks on but on idle no powersteering. my vehicle revs faster than the needle moves,at the moment dont know what to do. there must be someone out there who can give me some advice on what to do.
07971728333
Posted By: Sid1800
Date Posted: 01 Jan 13 at 16:12
at last my t3/20vt is up and running. got the rev counter and powersteering up and running. so far have drove it 100 miles local driving and had no issues at the moment, at 50 mph the revs were sat at 2000rpm and cruising along. will get some pictures up soon of the rest of the conversion and it driving. also waiting on ecu for chris van so i can test drive the 50 degree diesel install which i carried out aswell.
07971728333
Posted By: ELVIS
Date Posted: 01 Jan 13 at 16:34
nice one sid!
deffo piccies and an in depth build thread!
Date Posted: 02 Jan 13 at 09:11
Congratulations mate! Thats some going using the prototype parts. Hopefully this solution will ensure our wagens have a modern alternative drivetrain. I am really keen to see how Chris's Tdi conversion turns out. Any thoughts of performance chip upgrades at this point? How does the 150bhp feel verses the 112bhp from the 2.1?
Posted By: Sid1800
Date Posted: 02 Jan 13 at 21:56
Hello Alam happy new year. You saying the difference, well the 2.1 on original Box was good reving but the 20vt is more refined as to How you drive it. The turbo is more like a supercharger Long in gears 2nd gear easy 45. As for upgrade bigger turbo, Injectors,and a remap should be easy 200bhp, As you know I have had 230bhp in same vehicle And I do drive it!
07971728333
Posted By: Arc Eye
Date Posted: 07 Jan 13 at 12:19
Hi there, great conversion youve done there
What gearbox are you using for this as you say its an Audi and all you did was turn it upside down, no internal mods at all???
Awesome stuff there
------------- When all else fails, read the instructions.
Posted By: VW Nerd
Date Posted: 07 Jan 13 at 13:33
Arc Eye wrote:
Hi there, great conversion youve done there What gearbox are you using for this as you say its an Audi and all you did was turn it upside down, no internal mods at all??? Awesome stuff there |
Hi Arc Eye check out my build thread for more details about what is involved in the gearbox install. http://www.brick-yard.co.uk/forum/audi-a4-passat-gear-box-install_topic71714.html
Tim
AFN TDI Panel Van
Date Posted: 07 Jan 13 at 14:17
Sid did the Diesel conversion is done too... my mate Chris should soon be picking up his camper with VW Passat TDi engine and gearbox (all from the same donar Passat) from Sid this or next week. Sid has promised a test drive in his Turbo Caravelle with Audi engine and Box back to back with the Diesel conversion. Lets see how they compare. I'm hoping tag along and get a test drive myself. I'll do a video and post them upf for everyone to have a looksee. :)
Posted By: Racebiz
Date Posted: 07 Jan 13 at 21:59
Should make for a couple of interesting test drives. Up to a few months ago I was all set on dropping an AFN in with a flipped box, however leaving any fuel savings out of the equation for the diesel I am quite keen on the 1.8t as an alternative so will be reading your comparison with interest.
------------- 98 T3 PD130 Viking Top A4 1.9 TDI Classic RangeRover 3.9 EFI
Posted By: Arc Eye
Date Posted: 08 Jan 13 at 18:23
Lets see how they compare. I'm hoping tag along and get a test drive myself. I'll do a video and post them upf for everyone to have a looksee. :) |
Just read the thread, really excellent
Posted By: Sid1800
Date Posted: 09 Jan 13 at 20:07
hi im looking to do the same conversion with a upright diesel so every thing from an audi or passat will fit need to do it with the entire engine sitting under the hood which should not be a problem. the only issue is that i dont have any t3 left to do the conversion in so if any body out there whants it installing give me a shout.ill be more than happy to do it.or for that matter even 1.8t. does anybody know of someone who can do the wiring loom for the 1.9pd engine that will be the diesel conversion to go for.
07971728333
Posted By: rhysdubber
Date Posted: 10 Jan 13 at 16:02
I'd very much like to know how you would go about it with a upright Diesel engine and I would crap myself if my van could do what yours done! haha
------------- If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit. "Better To Be Pissed Off Than To Be Pissed On" 1989 1.7D DK Box "Dylan"
Posted By: Sid1800
Date Posted: 10 Jan 13 at 19:01
hi nothing is impossible to do the upright conversion,if i can do the 1.8t upright whats so hard about the diesel upright.using the same engine mounting support bar for the petrol and diesel is the same. hitting 88 miles per hour dont know what you mean i have had the van at 120 mph with a s3 engine on standard box in the same van.
07971728333
Date Posted: 10 Jan 13 at 19:04
Sid1800 wrote:
hitting 88 miles per hour dont know what you mean i have had the van at 120 mph with a s3 engine on standard box in the same van. |
thats his signature! on every one of his posts!
Date Posted: 11 Jan 13 at 01:28
Ive only ever reached 87/88 mph in my 1.7D Thats outright dangerous to the public Very nerving... and loud. We done a 118 in my Dad's 2.1 Auto. That was much more enjoyable (Not shitting myself) haha Ive had a look at your 1.8T conversion thread. Very well done, its made me want to petrol instead of diesel now
Posted By: spuds_own
Date Posted: 10 Feb 13 at 18:22
Cracking job mate ive just started my 20vt build which direction did you go for the gearbox flip adapter plate or machine off and reweld?
Posted By: Sid1800
Date Posted: 22 Feb 13 at 17:40
hi spuds sorry just been a busy person from work and home. any way the gearbox was cut on the face by 15mm all round due to the adaptor plate being 15mm thick.the direction is 180degree flip for the gearbox,no welding involved atall you can buy the adaptor plate from Tim under the user name vw nerd.he supplied me with the parts and i did the build. by the way your not to far from me (bradford)if you want to have a look at mine by all means if you make it during this week i can also show you a t3 with a 3.3 subaru that i did a while back.customer collecting it next week end.
07971728333
Date Posted: 22 Feb 13 at 17:53
Hey sid that would be cool can you pm me your number and I'll give you a call about coming up
Posted By: Sid1800
Date Posted: 22 Feb 13 at 18:02
hi my number is on the bottom of each of my thread but here it is 07971728333.
07971728333
Posted By: A.Muppet
Date Posted: 02 Jul 13 at 15:45
Hi Sid,
what exhaust set up are you using for the 1.8T? Is it a custom job?
I'm 90% certain the 1.8T is the route I'll be taking, just trying to piece together what parts I'll need, and the overall cost.
Thanks,
Ben.
------------- Laughing all the way in a Bluestar Commencal Meta 5.5.2
Pace RC200 F2
Specialized Allez Sport
Posted By: Sid1800
Date Posted: 18 Jul 13 at 22:30
I made the exhaust for my original 2.1 engine, when I did the conversion i then adapt it to fit the 1.8t engine.
07971728333
Posted By: Sid1800
Date Posted: 18 Jul 13 at 22:35
[QUOTE=Sid1800]
I made the exhaust for my original 2.1 engine, when I did the conversion i then adapt it to fit the 1.8t engine. got a couple of people wanting to see the conversion.
07971728333
Date Posted: 19 Jul 13 at 17:35
Sid1800 wrote:
[QUOTE=Sid1800]
I made the exhaust for my original 2.1 engine, when I did the conversion i then adapt it to fit the 1.8t engine. got a couple of people wanting to see the conversion. |
Posted By: SplitBusVanatic
Date Posted: 27 Jul 13 at 12:37
Good Thread This. Any more info on how you did this..
How did you level the box and hold it in place.? Cheers
Posted By: shapey
Date Posted: 27 Jul 13 at 20:28
very interesting thread indeed...
i happen to have a '97 20vt aeb engined passat on my drive - i'm trying to decide whether to get rid of it or keep it to convert my bus...
any cons to this conversion or only pros? and does anyone have a ballpark cost of parts required to go from 2.1 petrol to 20vt?
cheers.
Posted By: Sid1800
Date Posted: 05 Aug 13 at 17:09
Once you stand the gearbox up it will stand on its own, It will level it self. The flat piece of board was 15mm thick the same amount Of material I had to remove.
07971728333
Posted By: Sid1800
Date Posted: 05 Aug 13 at 17:20
The main parts you need are Gearbox mount Adaptor plate Driveshaft cv joints Gear linkage Engine mounting bar Wiring loom and Ecu Pipe works can be adapted Have a word with Tim Shettle He can supply all the parts needed for the conversion. You just need to get some one to fit and adapt it all
07971728333
Date Posted: 06 Aug 13 at 14:14
Sid1800 wrote:
Once you stand the gearbox up it will stand on its own, It will level it self. The flat piece of board was 15mm thick the same amount Of material I had to remove. |
Ok Cool. I'm on the verge of doing this.
So you cut out a hole in the wooden 'table top' in the exact shape of the outer edge of the bellhousing, Then placed the gearbox into the wooden template. Keeping it flush. Then passed over 2mm at a time with the router. until you had 15mm cut off of it.?
Am I right.?
Thanks. Dan.
Posted By: Sid1800
Date Posted: 06 Aug 13 at 18:14
That's right Put the gearbox bell housing face down Then draw around it and cut it out. Then put the gearbox the other way round and Make some legs for it, the legs might be slight Difference in height but not matter as long as the Board you cut sits level with the bell housing face. You can have a board on either end of box and Sandwich the gearbox in then make the legs for it But it's how you feel comfortable with, By the way don't forget to drill the dowel holes first
Hope that helps, any problem just bell me. You can Cut more than 2mm but it depends on your router Make sure you wear goggles. Once done get a flat piece of wood with sand paper And smooth the top.
07971728333
Date Posted: 06 Aug 13 at 18:36
You're a gent Sid. Thanks Very much. I have borrowed a router. It's a 110volt, so once i borrow a transformer, I'm good to go.
Thanks Again.
Posted By: youthy giblets
Date Posted: 14 Aug 13 at 08:27
Have u sorted your tachometer issue? On the pug motor with eps I simply converted my alternator to have a w signal, was very easy just took the rear cover of alt and solder a wire (w connection) to any of the outer 3 windings and job was done, then fine tuned tach with the little potentiometer screw in the back of it till it read correct engine speed at 70mph was a bit of trial and error but got there eventually
Posted By: Sid1800
Date Posted: 16 Aug 13 at 20:23
Hi I did the same with alternator w wire for the Power steering. For the rev counter I took a feed from each of The 4 coils with a couple of diodes and the rev Counter working.
07971728333
Posted By: Sid1800
Date Posted: 28 Oct 13 at 19:08
here we go again I have just made a adaptor plate to fit the 20vt onto a standard t3 box. it works a treat no gear linkage conversion or flip gearbox,driveshaft adaptors and on top of that adaptor for gearbox. ive made one adaptor and you can keep the original gearbox. all you have to do is make engine mounts to fit the original engine cross bar, ill post some pictures of adaptor plate and what you need to fit it. the engine cover needs to be raised by 1 to 1 and inch depends on how you want the engine to sit.
07971728333
Posted By: T3Panel
Date Posted: 28 Oct 13 at 19:14
have you also built a custom tray to go underneath to catch the debris when the standard gearbox gives up the ghost?
My GTI conversion with standard gearbox, and diesel flywheel is dreadful even with a black diamond clutch, and thats only an alleged 115BHP.
which box/flywheel combination you going with?
Posted By: Sid1800
Date Posted: 28 Oct 13 at 19:50
you cant beat the standard box especially the 5 speed. been running it for 12 years no problem. you used the diesel flywheel which is shiit to small for the job. early agu engine did a solid flywheel conversion which for the whole kit, flywheel,clutch,pressureplate is only 155 to buy which is ideal for the money, even a g60 flywheel alone will cost you 260 new. I got 180bhp and it is fine.
07971728333
Posted By: T3Panel
Date Posted: 28 Oct 13 at 20:01
yes and I also have the ABD 4 speed box, so double shit!
To be fair I knew it would be from the start, but thought I would get it on the road and sort it later.... still haven't got around to it yet!
Food for thought there - There is no real cheap answer to this from what I can tell (unless you already have the right 5 speed box) as the flipped box conversion is fairly expensive, but so are 5 speed boxes, and a decent rebuild as most of these boxes now are at leasT3+ years old. Having said that, i'm hoping to get a new car in the next couple of months, which means I can take my Audi A4 1.8T to bits, so i'm leaning towards the flipped box at the moment.
Posted By: Sid1800
Date Posted: 28 Oct 13 at 20:03
http://s1185.photobucket.com/user/SLineMotors/library/t3%2020vt%20conversion" rel="nofollow - http://s1185.photobucket.com/user/SLineMotors/library/t3%2020vt%20conversion some pictures of the adaptor plate.
07971728333
Posted By: Sid1800
Date Posted: 28 Oct 13 at 20:16
the flipped box is ok but I found out that the gears are to long, you can go one end of street to the other just in second. motor ways fine on flat and down, but when it came to hills it would slow down to 60 then you had to drop gears and re built the momentum.which I don't like, unless you use diesel gearbox shorter gears but don't know not tried it. this is why I went back to 5 speed original. I did run 230bhp on standard box and had no issue, to many parts involved in the flipped gearbox, don't get me wrong it is good coversion but for diesels. you can fit the audi or Passat tdi in to t3 as it is with the adaptor plate I made with out the hassle of fitting it at 50degree, which there again you need more parts which are getting hard to get hold off. the main thing you need is a diesel bellhousing that's it.
07971728333
Posted By: Gtavalanche
Date Posted: 28 Oct 13 at 20:19
How much does a complete 1.8t conversion cost through you Sid? (Obviously minus the donor Vehicle)
A. With flipped Box B. With T3 Box?
------------- I taste Hurty!
Posted By: Sid1800
Date Posted: 28 Oct 13 at 20:36
any one interested I have got the flipped gearbox for sale with the conversion bits all intactthat's gearbox ,adaptor plate,gearlinkage,mounting, and drive shaft adaptors.
SORRY NOW SOLD
07971728333
Posted By: Sid1800
Date Posted: 28 Oct 13 at 20:45
depends on what you got first petrol or diesel, not really worked out price as for a drive in and drive out service, mechanical side is not a problem its when it comes to electrical side but working on to resolving it. manage to get mine running after a lot of ecu problems. but it was the donner car that had the ecu issues there from start which the last owner not told me about.
07971728333
Date Posted: 28 Oct 13 at 21:02
I suppose its how longs is a piece of string really. But from petrol no un foreseen circumstances.
How much for the whole set up?
Posted By: booted
Date Posted: 28 Oct 13 at 23:41
Sid what gearbox code / ratios is it I am considering options to replace my gearbox on a 2.3 audi 5cyl engine
Posted By: GavB95
Date Posted: 29 Oct 13 at 14:41
Sid1800 wrote:
any one interested I have got the flipped gearbox for sale with the conversion bits all intactthat's gearbox ,adaptor plate,gearlinkage,mounting, and drive shaft adaptors. |
Interested in these Sid, what's the gearbox code and how much are you after for the lot?
Cheers Gav
Posted By: Sid1800
Date Posted: 29 Oct 13 at 18:25
the gearbox is from a 96 18t audi. ill get the code tomorrow for you, make me a reasonable offer as you can see from tim how much the parts come to. thanks
07971728333
Posted By: Sid1800
Date Posted: 29 Oct 13 at 18:27
hi the labour cost is 1250 plus parts
07971728333
Posted By: Sid1800
Date Posted: 29 Oct 13 at 18:58
Picture of the adapter plate fitted to the box
07971728333
Posted By: Sid1800
Date Posted: 29 Oct 13 at 20:11
hi their the box is from a 96 audi a4tsport ive got one person coming on Friday to buy it all, if not ill let you know if it is still for sale. thanks
07971728333
Posted By: Racebiz
Date Posted: 29 Oct 13 at 21:59
Interesting set up Sid and as you say, a lot less hassle than a flipped box if not wanting diesel.
Is this 20vt-t3 adapter plate/kit something you are going to be making available in the future, if so I would be interested.
Date Posted: 29 Oct 13 at 22:36
Forgive me for being numb but if your using standard box and diesel bell housing what's the point of the adapter plate??
Date Posted: 29 Oct 13 at 22:40
To stand the engine upright I think.
Date Posted: 29 Oct 13 at 22:55
Oh yeah thick f**k I am. I forgot about the upright install, got my head in Tdi mode
Date Posted: 30 Oct 13 at 00:15
youthy giblets wrote:
Oh yeah thick f**k I am. I forgot about the upright install, got my head in Tdi mode |
you need to stop that marra.. lubrication oil as a fuel?? it'll never catch on.
@Sid, top work there fella, watched a thread on the samba where some clever chap did the same, good work!
Posted By: Sid1800
Date Posted: 30 Oct 13 at 18:30
The adaptor plate is available now, Got 2 more on shelf ready to sell. The price is 280 pounds for the adaptor.
07971728333
Posted By: Sid1800
Date Posted: 30 Oct 13 at 18:32
The adaptor plate is made for both petrol 20vt And the diesel upright,I'll get a picture of the upright Diesel uploaded.
07971728333
Posted By: Sid1800
Date Posted: 30 Oct 13 at 20:19
booted wrote:
Sid what gearbox code / ratios is it I am considering options to replace my gearbox on a 2.3 audi 5cyl engine |
the gearbox code is 012301103
07971728333
Posted By: Sid1800
Date Posted: 30 Oct 13 at 20:37
adaptor plate fitted and box mounted to diesel engine.
07971728333
Posted By: Sid1800
Date Posted: 30 Oct 13 at 20:43
fitted to the petrol engine
07971728333
