which donor is best for a TDI 1.9 conversion
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=68715
Printed Date: 28 Mar 24 at 17:16 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: which donor is best for a TDI 1.9 conversion
Posted By: 16vmini
Subject: which donor is best for a TDI 1.9 conversion
Date Posted: 28 Sep 11 at 17:30
have come across a 1998 SEAT ALHAMBRA 1.9 TDI AUTO ,
is this a good choice ? i assume i would have to pickup a flywheel/clutch setup of a manual car ?
ideally what is the best donor for a 1.9TDI conversion ?
regards
Matt
------------- Westy Diary : http://www.teamorchard.co.uk / http://www.16vmini.co.uk
Posted By: Joker_Club
Date Posted: 28 Sep 11 at 18:47
------------- Sunny Lancs
Posted By: busbuddy
Date Posted: 28 Sep 11 at 20:23
I believe the auto box ecu's are different to manual box ecu's
------------- http://www.karmann-coachbuilts.com" rel="nofollow - Karmann
Posted By: mazz
Date Posted: 28 Sep 11 at 21:58
Auto ECU is different, but still not a bad donor car, really a golf 3 or seat ibiza,cordoba or toledo are your best bets as they are a more simple vehicle and ideal if you have not done a TDi conversion before
------------- MV Engineering-TDi conversion specialist 07989593569-01952 581818 mveservices@hotmail.co.uk
Posted By: 16vmini
Date Posted: 30 Sep 11 at 12:40
cheers guys , is a mk4 golf tdi ok to use ?
i have done many other engine conversions in other cars (vauxhall , suzuki , honda etc ), so i am very happy with ECU's and wires etc. .. , allthough never done a TDI .
i do have a re-cond gearbox that i was going to use with my SVX engine , ok , it sounds like it could do with a high gear really .. but better that what i have ., (guess you can cheat a little on tire sizes )
i have been reading allot on here , but as allways ... everyone seems to have done it a little different ..
cheers
Matt
Date Posted: 30 Sep 11 at 17:32
cheers
Matt |
hi, in a word...no, the mk4s like ALH etc have a different block, that in itself is not an issue but the sump of the t3 wont bolt on the the mk4 blocks, also the mounts wont, anything is possible and PD engines can be put in but for a sraight forward swap (ahem) you need to find a 1Z or AFN type motor with the water pump driven via the crank pulley not the cambelt as on a mk4. also the mk 4 electrickery is more involved...can be done but more of it and also the early TDIs dont have an immob to get round (pre 94 i think)
Posted By: 16vmini
Date Posted: 30 Sep 11 at 18:01
cheers , just read about the mk4 , also need clocks etc , (speedo pickup i think )
assume my standard diesel fuel tank is fine for a TDI conversion , i know with some of the engine conversions i have done before i had needed to increase the size of fuel lines running from the tank etc
Matt
Date Posted: 30 Sep 11 at 19:42
yep the tanks fine and the pipes will do, no lift pump to worry about or owt.
Posted By: 16vmini
Date Posted: 01 Oct 11 at 11:17
ok , found 96 golf TDI , with engine code AHU 077*
good to go for ?
Matt
Posted By: mazz
Date Posted: 01 Oct 11 at 12:37
yep, buy it now
Posted By: 16vmini
Date Posted: 09 Oct 11 at 20:47
would this have the correct TDI engine ? :
http://www.ebay.co.uk/itm/VW-Transporter-800-special-1-9-Turbo-Diesel-Restoration-Project-/180735979383?pt=Automobiles_UK&hash=item2a14b42f77#ht_589wt_1344" rel="nofollow - http://www.ebay.co.uk/itm/VW-Transporter-800-special-1-9-Turbo-Diesel-Restoration-Project-/180735979383?pt=Automobiles_UK&hash=item2a14b42f77#ht_589wt_1344
Date Posted: 09 Oct 11 at 20:57
i would avoid that because A, its a bin B, the t4 engine has no dipstick on the front of the block so you would have to drill one and block the old one and (C) i dont even think they do a tdi 4 pot t4...might be wrong but as theres no engine code stated i cant check...get a golf or passat one..earlier the better.
Posted By: light
Date Posted: 09 Oct 11 at 21:49
t4`s 1.9`s are all idi not tdi
Date Posted: 09 Oct 11 at 22:12
thats what i thought...but seem to recall seeing a non turbo indirect diesel in a t4...
Posted By: 16vmini
Date Posted: 13 Jan 12 at 19:56
sorry to drag this up again , but new year and started to look again for a donor ,
saw this :
http://www.ebay.co.uk/itm/VOLKSWAGEN-GOLF-DIESEL-TDI-ENGINE-1Z-COMPLETE-MK1-CADDY-T4-T3-/150549077191?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item230d6c9cc7#ht_524wt_1110" rel="nofollow - http://www.ebay.co.uk/itm/VOLKSWAGEN-GOLF-DIESEL-TDI-ENGINE-1Z-COMPLETE-MK1-CADDY-T4-T3-/150549077191?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item230d6c9cc7#ht_524wt_1110
any advice ?
Matt
Posted By: light
Date Posted: 15 Jan 12 at 19:47
saw this :
any advice ?
Matt |
It will do the job 1z is the earliest version of the tdi
Date Posted: 15 Jan 12 at 19:59
and will have no immobilizer as well if its early enuf...
Posted By: lloydy
Date Posted: 17 Jan 12 at 18:38
Trying to find a donor car myself, so if anyone knows of one local to them....... It would be appreciated. AHU, AFN preferred. I've set myself a £500 limit Cheers, Lloyd
Posted By: andy1300gt
Date Posted: 18 Jan 12 at 23:54
Hi Lloyd, I found a guy near me in Bristol. Removed everything required from the car for £450. I will try and find the details foe you.
------------- It's all rust in the end....
89 T3 Doka - AFN TDI 76 XJC 4.2 Daimler - Gone! 72 Austin 1300
Posted By: lloydy
Date Posted: 19 Jan 12 at 07:27
Thanks, that would be great. I've got some people coming back with prices this week hopefully.
