LT 35 gearbox selector bearings
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=55421
Printed Date: 19 Apr 24 at 04:47 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: LT 35 gearbox selector bearings
Posted By: Squarebanana
Subject: LT 35 gearbox selector bearings
Date Posted: 06 Jul 10 at 19:01
Hi i have just bought myself an s reg lt35 good condition but the gearbox seems at fault, heres what it is, when changing gear if i inadvertantly push at the gate(because i am not use to it yet) i get a metal to metal dry bearing noise, in other words when th eengine is at idle with clutch in, i push the gear lever in neutral all the way to the left to the stop, now if i gently push on it there against the stop i get a whining noise like a dry bearing, this tell me (i think ) that it may be the selector bearings on the selector shaft, any one know this or had the same problem because when i am driving it i get the same noise at times when the engine just gets under load ie when letting the clutch out and the same when starting the engine or turning it off just a noticeable "squeak" for a split second, i am hoping that just the oile levels low as i am getting it checked in the morning, and if the selector shaft is in the top of the box that might explain it. Alan SB
Date Posted: 07 Jul 10 at 08:09
Just got my m8 to get underneath and have a look and rear oil seals gone so box is short on oil, does anyone know how easy it is to fit a rear oil seal?
Alan SB
Posted By: TwoSheds
Date Posted: 08 Jul 10 at 23:37
Hi Squarebanana
The rear seal can be done in-situ. Your have to drain the oil ( if you have any ), remove the prop and lever the end seal out ( taking care not to damage the internal bore ) . Plenty of oil on the running edge of the new seal and tap it into place gently ( ideally get a piece of wood and bore a hole slightly larger than the output shaft then you can drive the seal in square ).
Date Posted: 08 Jul 10 at 23:46
thank you for that but just had it to a gearbox mechanic its not the box i did the top up of oil and it took half a pint its the spiggot bearing behind the clutch thank god i didnt fancy buying another box
Alan SB
