golf 1z TDi immobiliser wiring
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=38149
Printed Date: 29 Mar 24 at 09:14 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: golf 1z TDi immobiliser wiring
Posted By: Full Throttle
Subject: golf 1z TDi immobiliser wiring
Date Posted: 27 Apr 09 at 11:56
This works for vw golf 1.9 1z engined model yrs 1994/1995 with 68 pin ecu's
This enables you to remove the instrument cluster and still keep the immobiliser and electronic pump.
You will need the black box immobiliser, original key, ignition key transponder reader and the ecu from the same car.
How to wire the Black box immobiliser.
2 connectors
one is three pin the other is 6 pin. The 3 pin goes to the transponder reader.
The 6 pin connector is numbered if you look at the end of it. 1 to 6
So starting with pin 1
1= Black , connect this to a switched 12v i.e ignition
2 = Grey/ White, goes to the ecu
3 = Grey, goes to Diagnostic plug, but changes to a grey and white at the diagnostic plug end.
4 = Brown, Earth
5 = Not connected
6 = Brown, earth
Pin 1 was connected to the golf instrument cluster and got it's 12v feed from there.
If you removed the cluster( no 12v to pin 1) it would start for 3 seconds then stop.
If you use this information and it works for you please add what year and model of car you used.
This conversion is time consuming especially on the wiring side, so i would recommend you pay someone else to do it. when you work out how many hours it takes to do it, you soon realise it's worth the money.But if you are prepared for do it your self this info will help you get past the last stage. i.e getting it started for the first time.
This may work for vento's jettas etc, with a 1.9 1z tdi engine with 68 pin ecu's.
If you know how to get other vw tdi engines working electronically without instrument clusters etc that would be good info to add to this thread.
We all need help when doing conversions so it's only fair to put something back into the knowledge pool.
Anyway good luck and lets us know if it works for you.
Posted By: jamie masters
Date Posted: 27 Apr 09 at 20:41
All the infomation i get and what i need i would most certanly share with anybody else doing the same converision. thanks j.
Posted By: ROB1N
Date Posted: 28 Apr 09 at 07:00
Cheers it worked the engine I used is from a golf tdi its a 1z and a 1994 model.
------------- Vw's are for life .
Posted By: mazz
Date Posted: 26 May 09 at 00:58
Hi i know this works as i have done it sevral times before, i dont understand why people think the wiring is so complicated,its very simple,the hardest part is making the new engine mount
------------- MV Engineering-TDi conversion specialist 07989593569-01952 581818 mveservices@hotmail.co.uk
Posted By: ROB1N
Date Posted: 26 May 09 at 08:28
Then wiring is very simple if you have the wiring diagrams in this case i didnt
Date Posted: 21 Jul 09 at 22:09
hi! thanks for info just need to no were diagnostic plug is located. it starts then stops. havent conected the grey up yet. many thanks. j
Date Posted: 21 Jul 09 at 23:10
I just pulled one out of a Golf, no immobiliser, bonus!
Date Posted: 23 Jul 09 at 00:42
any help with the grey wire please baxter??? its almost there. then i can start on sorting out the body abit. its all diy here. cheers j
Date Posted: 25 Jul 09 at 07:54
Do you have a wiring diagram. ?
If not there is one here:
http://www.haywood-sullivan.com/vanagon/TDI/1996_Jetta_TDI_wiring_LONG4.pdf - http://www.haywood-sullivan.com/vanagon/TDI/1996_Jetta_TDI_wiring_LONG4.pdf
The grey wire (pin 2) on the connector goes to the ecu.
Date Posted: 25 Jul 09 at 07:56
I heard there were some early tdi's without immobilisiers.
What year was it. ?
Posted By: T3di
Date Posted: 25 Jul 09 at 15:34
mines one. 93 is the year stamp on most stuff on it
Date Posted: 26 Jul 09 at 12:02
Yeah, M plate Golf the one I have.
Just makes me wonder if you can use the ECU's from these early ones on later systems, would have to check pin data.
Date Posted: 28 Jul 09 at 18:20
many thanks will try it and see what happens. cheers j
Date Posted: 28 Jul 09 at 22:16
The golf i got mine from was an M reg from memory, must have been the change over year as mine had the immo.
Date Posted: 28 Jul 09 at 23:00
Can you get to the ECU for the part number, could be an interesting thread, find out which ones do and don't.
Date Posted: 29 Jul 09 at 21:40
yippee its running! thanks to everyone who has helped so far. engine is 1.9 tdi from a golf estate 1995. 100k on clock. so chuffed. cheers j
Posted By: iow
Date Posted: 06 Aug 09 at 23:50
What is the min amaount of wires you need to run a TDI engine ? as want to put one in a boat
------------- There must be a better way
Posted By: T3di
Date Posted: 07 Aug 09 at 08:08
ecu is 68 pin but many commons are used .Every sensor on the engine seems to have its own yellow&black,an some join up in the loom.
Posted By: iow
Date Posted: 07 Aug 09 at 12:54
Have to say in my case it is the immobiliser that I could do with getting rid of don't need it on a boat lol
Also the fly by wire throttle is some thing I could do with out if there was a way round it wires and salt water don't seem to mix well.
Still I pick the car up this afternoon so will see what has to be done hope I can mate it up to the leg.
I have to say 10 out of 10 to this site I have spent day's looking at the web for info on Ford engines with out much luck I came to this site found all I wanted to know in 10 min's and you all seem to be very helpful keep it up it is good to see some one doing it right
Gord
Posted By: iow
Date Posted: 08 Aug 09 at 14:28
Hi well got the car engine out it is a M reg no immobiliser thank god . What a baby Turbo what does it boost to ?
But have a few problems to get over you might be able to help me with.
1st is the starter comes in from the gearbox do VW do a starter and flywheel for this engine that come's in from the engine ?
2nd slight oil leak from rear crank oil seal ? Does this mean the main's are on there way or is this common?
3rd does any one make adapter plates to fit Ford gear box or OMC leg ?
Sorry if this is off topic but you guy's seem to know all the in's and out's
Posted By: iow
Date Posted: 13 Aug 09 at 19:28
diagnostic plug can any one tell me where it would have been ? As I have now pulled all the wireing out of the car and have not found it .
But did find the immobiliser grrrr
Date Posted: 13 Aug 09 at 23:32
My diagnosic plug was near the gearstick in the plastic house stuff.
Some are in the front dash area.
Suspect an adapter plate will be required to fit to a ford gearbox.
Posted By: iow
Date Posted: 14 Aug 09 at 10:32
Some one did say it would be by the ash tray but nothing there did not have any wires go around the gearstiock. I have one plug that was by the servo under the bonet 6 pin but it does not fit my code read/writer ?
I have had to make adapter plate to fit OMC bell houseing also had to put ring gear on the other side of flywheel to run a starter coming in from engine side rather than gear box mounting
Posted By: iow
Date Posted: 14 Aug 09 at 17:40
OK found it any one know where to conect the wires to on fuse box ? woops
Posted By: APdiesel
Date Posted: 14 Aug 09 at 23:00
water and electrics don't mix, go for a mechanical pump.
Posted By: iow
Date Posted: 15 Aug 09 at 11:28
well yes this is true but when you look around all engines have some electrics most have ecu's .
Had to laugh fly by wire and they have a cable doing it lol
Still looking to find where the di wires go ??
Posted By: APdiesel
Date Posted: 15 Aug 09 at 22:28
Bin the fly by wire pump. Fit a mechanical pump = no problem with electrics
The only electrics needed is a wire to the solenoid and alternator.
No ecu messing around with.
Produces good 30-40 mpg
Posted By: iow
Date Posted: 15 Aug 09 at 22:48
that pump is used for the Transporter non turbo I think I don't think it would work on TDI
Posted By: iow
Date Posted: 19 Aug 09 at 00:56
Looked into the mechanical pump they do do one for the turbo tdi but have to get adapter plate to fit it. Plus with the ECU pump you have more scope to get more power out of the engine by remaping. On a good note I have the engine running on the workshop floor thanks to this posting the wireing is not that much of a problem to sort and have lot's of dry room on the boat
Posted By: iow
Date Posted: 21 Sep 09 at 14:33
Well all working fine had boat out for test what a good engine almost made for the job can any one point me to a ECU wiring diagram or tell me where the rev counter is taken from ?
As would like to try and link it to the boat one .
Thank's again to you all could not have done this engine change with out your help
Date Posted: 22 Sep 09 at 08:29
Mine was taken from the original tdi alternator, i connected mine to the original t3 diesel clocks.
wiring diagram for 1z tdi http://www.haywood-sullivan.com/vanagon/TDI/1996_Jetta_TDI_wiring_LONG4.pdf - http://www.haywood-sullivan.com/vanagon/TDI/1996_Jetta_TDI_wiring_LONG4.pdf
Posted By: iow
Date Posted: 23 Sep 09 at 14:57
does it not come from ECU ? Mine seems to as have run it a few times with the alternator off and rev counter still works on VW clocks ?
Date Posted: 24 Sep 09 at 10:46
I dont think so, will have a look and confirm, has been a while since i looked at it.
The ecu may use the crank sensor for the golf tacho instead of the alternator.
Which might explain why it works without the alternator connected.
Posted By: iow
Date Posted: 10 Oct 09 at 17:26
Has any one had a problem reprograming the ECU after bypassing clocks ?
I am logging into the ECU and it gives me the ECU info then tell me to pull fuse 12 and turn back on ? but then it just keeps repeating ???
Posted By: crewpad
Date Posted: 06 Feb 10 at 16:40
hi... the wiring diagram links dont seen to work. does anybody have them? cheers.
------------- chips dips chains n whips....
Date Posted: 07 Feb 10 at 22:47
I just clicked on the link and it still works.
Posted By: crewpad
Date Posted: 08 Feb 10 at 17:23
now mine is working.... i think my laptop was being a knob. cheers.
Posted By: T3di
Date Posted: 08 Feb 10 at 17:53
No you were right it didn't work on that day
Posted By: crewpad
Date Posted: 08 Feb 10 at 20:00
ahhh ..... not mine then.
Posted By: crewpad
Date Posted: 04 Mar 10 at 16:42
how important is the diagnostic plug? its the only bit i dont have......
Posted By: T3di
Date Posted: 04 Mar 10 at 18:49
Its as important as vagcom. Without communication you'll eventually be stuffed! It is only 3 wires though, and only one of those goes to the ecu I think, so easy enough to fit one, particularly if your loom isn't fitted yet??
Posted By: crewpad
Date Posted: 04 Mar 10 at 19:52
ok..... now ive got to find one.. cheers dude.
Posted By: shrek
Date Posted: 04 Mar 10 at 21:11
pin 61 of ecu is for the data link plug not sure of others prob just earth and live that is for 1z though
Posted By: crewpad
Date Posted: 05 Mar 10 at 15:17
cool... can anyone tell me what the diagnostic plug looks like? what colour the plug is or even what colour wires are on it(i now know about the grey/white one) i might have it but im not sure. the hard thing is im trying to work from a jetta ecu diagramm..... i cant find a 95 golf one but ive been told they are the same. ....cheers.
Posted By: iow
Date Posted: 05 Mar 10 at 15:29
Hi it is a oblong black the wires on mine when I did the boat. it had a brown =earth red/yellow dig + grey/white = data/ecu and a red =+ .
I found to use code reader or laptop to rewriite to ecu had to not have + disconected could be some lee way in this as when I took loom out of car to put in boat I cut the plug off by mistake lol
Posted By: crewpad
Date Posted: 05 Mar 10 at 19:05
cheers dude. ill hunt through the crap ive got to see if its there..... fingers crossed.
Posted By: T3di
Date Posted: 05 Mar 10 at 20:24
google search for OBDII connector you'll get the idea Also on the ross tech site it shows you where they lurk on some vw models, ie behind a blank on dash near steering wheel or down near the handbrake.
Posted By: crewpad
Date Posted: 05 Mar 10 at 20:30
cool... ill do it now. cheers.
Posted By: T3di
Date Posted: 05 Mar 10 at 20:34
Quite a nice touch I thought about doing would be to have the vagcom lead conncted to the OBD plug permanently and run it in tidy so you just have a small usb socket showing wherever you want it to be in the van, a bit like the obd locations on factory vws.
But I couldn't be arsed
Posted By: crewpad
Date Posted: 05 Mar 10 at 20:46
yikes... i thought it was a small little thing, not 16 pins lol . ill have another look through my pile of wires and see if its there, i dont think it is.... any ideas where i an get a wiring diagram for a 95 tdi golf? thats my other headache.
Posted By: syncrodoug
Date Posted: 05 Mar 10 at 20:56
Get yourself a copy of ELSAWIN.....http://www.manuals-on-disc.com/elsawin3.61full.htm
Posted By: crewpad
Date Posted: 05 Mar 10 at 21:15
looks interesting.... does it have a a diagram for the ecu, diagnostic plug and all the engine bits? cheers.
Posted By: Beelzibus
Date Posted: 05 Mar 10 at 21:23
Crewpad, I've just done a complete 1Z conversion, can offer a diagram and point you in the direction of the diagnostics plug, PM me for a number to call me on. If you want a quick hand, cheers Andy.
Posted By: iow
Date Posted: 05 Mar 10 at 21:30
think mine was next to rear window switch in center of dash that's why it got cut did not see it behinf plastic blanking pannel lol
Posted By: crewpad
Date Posted: 14 Mar 10 at 15:35
ITS ALIVE........ im well chuffed. starts straight away and runs sweet.just got a bit of tidying to do and sort the pipework. thanks for all your help people beers at the bar for yawl.
Posted By: kooldubs
Date Posted: 14 Mar 10 at 15:54
ere boy..none of this imaginary beers,, i want a proper cider...bey!!
nice one my friend...spot on...
------------- 86 t3 doka & 2001 T4 2.5 TDI 07752280999...
Posted By: shrek
Date Posted: 06 Jun 10 at 21:06
hi everyone just got a audi 1.9 tdi ahu 1997 p reg starting without clocks and hear is how i found it. immobiliser unit box is white not black i have no pin numbers but wire's are two that go to the key reader are in there own plastic cover and the others are as follows
1--green and black go to ecu pin number 61 2--black is ignition fed 3-- green and red diagnostic socket 4-- red and black go to the clocks
red and black goes to yellow connector of clocks and the other connector is blue and the same colour wire on the blue connector need to put these together the wire keeps going to little bulb and then from the bulb the colour changes to green and brown then that wire goes to the engine ecu and the pin number is 48 hope this helps it worked for me it must be a signal wire as it goes up and down between 0.8v to 2.3v hope this helps some one as i used this post to help me along i know its a bit different but it might help some one
------------- IF ONLY IT WOULD GO RIGHT EVERY TIME ???
Posted By: Tinman
Date Posted: 15 Jun 10 at 10:15
I've got to pick up a golf 1z 1996, the key is missing!! will I be able to get it to run??
Date Posted: 16 Jun 10 at 08:10
No, the key has a little chip in it, and the transducer on the steering coloumn reads the chip.
You should be able to get a new key easily enough if you have the cars documents.
Posted By: VW Nerd
Date Posted: 16 Jun 10 at 09:42
I lost the key from my tdi conversion car, but found a local guy who managed to create a new chip from the immobiliser black box which he pluged into his lap top and got out the chip info.
So it can be done. My van now starts and runs using this new chip.
------------- Developing parts for the VW T3 TDI market Inc flipped audi gearbox install parts.
Tim Shettle www.ultimate-engineering.co.uk Bristol
Tel/txt 07810 320 464
AFN TDI Panel Van
Posted By: Tinman
Date Posted: 16 Jun 10 at 12:33
Apparently the key from Vw is expensive.
I was gonna offer the engine up for sale on here, But if I'm not able to get it running then I guess I'll break it up on e-bay.
Date Posted: 16 Jun 10 at 22:21
So it can be done. My van now starts and runs using this new chip. |
Pritty sure VW do it the same way but charge a few quid for the service and wont do it if you have no documents proving the vehicle is yours etc.
Where did your chap get the chip from ?
Had a look at my chip a while ago and dont remember seeing any contact pins, how did he program it with his laptop.
Posted By: subwoofer
Date Posted: 17 Jun 10 at 06:28
There are immobilizer emulators out there, costing about 50£ off the Interweb. Sounds like it is worth a shot? Then you don't need the immo box, nor the coded key, it simply works like any standalone ECU would.
------------- Joachim
'90 Caravelle C Syncro w/ various mods and Megasquirt3 ECU
Posted By: VW Nerd
Date Posted: 17 Jun 10 at 09:16
As I have had a T3 stolen in the past, I think it is well worth keeping the immobiliser. You also only need to look on the stolen van pages to see how much of a target our vans are these days.
I did not watch the guy create the chip for my key, I just let him get on and do his job.
I gave him the black box which he took into his van. 5>10 minutes later he came back with a cut key with a chip fitted to it.
I guess that he has a device to hold the chip while it is being programmed.
AFN TDI Panel Van
Posted By: Tinman
Date Posted: 17 Jun 10 at 09:37
How much was is? and do you have his number??
Posted By: VW Nerd
Date Posted: 17 Jun 10 at 14:07
I think it cost £100 for the key and chip
The guy is called Andy Morgan tel 07899043902
He may be able to come out to you at Radstock, if not drop your immobiliser box over to me and I'll get him to do it here. Don't forget to bring your van key for him to copy.
Tim
AFN TDI Panel Van
Posted By: iow
Date Posted: 19 Jun 10 at 18:20
Hi has any one used a KWP2000 chip programer on there TDI ? I am having problems with the one in my boat only seem to get half power ?
When I try to read info from ECU gives me number's of ECU but then tells me to pull fuse 11 and turn back on .That's as far as it goes it will net read the ECU it has got to point it is driving me nut's ant idea's any one ??
Posted By: Catalin_BN
Date Posted: 25 Oct 16 at 17:57
2 connectors
4 = Brown, Earth
5 = Not connected
6 = Brown, earth
Hello guys, I need some info because the Immo drives me crazy. I made a ecu / ip upgrade, I have 2 Ecu msa 15, with immo and everything. If i respect the wiring posted above, engine starts without chips near the coil. With vcds, immo box says that start is permitted, talks to ecu and key is not recognized. No matter how I do it, it won't kill the engine. Tell me that I'm crazy when everybody wants immo off, I want immo on... :)). I really need some info because if I look in every wiring diagram, pin 61 from ECU means Immo, or Immo and OBD line. So, that means pin 2 and 3 from immo box must be joined together and then to diagnostic plug? I'm correct ? Please help me clarify this!
No matter how I tried, I still get the same error from Immo box: 00546 - Data Wiring faulty: Implausible Signal
My current wiring, pin 61 from ecu goes to Immo box, pin 3 from immo box goes to diagnostic plug. - is this correct ?
Posted By: Scimdiesel
Date Posted: 27 Oct 16 at 21:43
Please post if you find a solution. Pre engine install I started the engine on the floor and it needed the chip to be near the ring in order to remain running. After install I put all the immo stuff in a sealed box in the engine bay. A few months later I thought i''d like an immobiliser and extended all the wires to the front. Went to start it and it started fine. I was quite relieved it still started except!!! The immo chip was no ware near the ring. In fact I could disconnect the black box and starts and runs fine. At the time a mentioned it on here and was told lots of the original ecu never had the immo part switched on. I've assumed since that the initial apparent working of the immo with the engine on the floor was actually just air in the ip.
------------- Without engineers science is just philosophy..... Joined the revolution with a 18 year old TDI :
Date Posted: 28 Oct 16 at 13:25
I dont know what to say. First time I tried 2 ECU msa 15 and with both of them car started and then stopped after 2 seconds. After the immo wiring, it doesn't matter if I have the box plugged or not still starts. Same here, please if you find anything let me know. PS What is the engine check light on msa 15? all wiring diagrams says is pin 61 for us models, well that does't work, my ecu is european.
Date Posted: 28 Oct 16 at 14:26
Sounds exactly like mine. I find it hard to believe that there is a get around the immobilizer by wiring the ECu or immobiliser wrong. I was also told which may not be true that if the voltage is to low the engine might start then cut out again like if the immobilizer is activated. In normal use the alternator would cut in and boost the voltage but when I started mine on the floor the engine had no belts on it.
There is no engine check light on he European models. The Glow plug light flashes angry if there is something worth being angry about.
Maybe one day I will try a spare ECU, black box and chip and see what happens.
Date Posted: 30 Oct 16 at 10:19
I tried 2 ECU and 2 immo boxes and it is the same thing. Tried pin 60 and yes, it works as the CEL
