:---T5 RECALL INFO----:
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=24993
Printed Date: 09 Jul 20 at 17:52
Topic: :---T5 RECALL INFO----:
Posted By: BANANABUS
Subject: :---T5 RECALL INFO----:
Date Posted: 23 Mar 08 at 21:37
http://www.vosa.gov.uk/vosa/apps/recalls/searches/search.asp?cboStartMonth=1&cboStartYear=1980&cboEndMonth=1&cboEndYear=2010&cboMake=VW&cboModel=TRANSPORTER&cboSortOrder=rec_launch_date&cboAscDesc=ASC&PageSize=10&Search=Search - http://www.vosa.gov.uk/vosa/apps/recalls/searches/search.asp ?cboStartMonth=1&cboStartYear=1980&cboEndMonth=1& ;cboEndYear=2010&cboMake=VW&cboModel=TRANSPORTER& ;cboSortOrder=rec_launch_date&cboAscDesc=ASC&PageSiz e=10&Search=Search
Posted By: DOGSBREATH
Date Posted: 24 Mar 08 at 14:41
Thats a bloody usefull bit of info......fanks .
Posted By: Ex-car bloke
Date Posted: 29 Mar 08 at 12:43
So basically no recalls for build dates after May 2006.  Affects only the rear seats for me (March 06 build date).
Thanks for the info.
ECB           2006 SWB 174 window van
Posted By: Onefut
Date Posted: 06 Apr 08 at 14:11
will have a look at that later
thanx
Posted By: Mister Rafiki
Date Posted: 05 May 08 at 20:02
In mainland Europe  almost all T5 were recalled for replacement  of oil cooler I got mine Multivan  august 2007 recalled a few weeks ago and got a new one.
Edited 8 may 2008..  sorry I meant oil cooler not water pump!!!!.  stupid of me..getting old!!!
Embarrassed
Embarrassed
Posted By: mikeT
Date Posted: 08 Aug 08 at 15:39
Just phoned the stealer and it needs to be done on mine, too.
no letter has been sent out to me so thanks to the brick-yard.
for the thumbs up phoned the stealers yesterday and
just had mine changed today i.e.  LWB T32 130  also built in Hanover,!!  Feb 2007 ish
Thanks again Mike
Posted By: dehlilah
Date Posted: 09 Sep 08 at 00:28
I dont know if my 2006 camper is affected with oil cooler-- i will phone & check,  it is hannover made--
there was a recall on the windows -caravelle- as they leaked before i got it,
 but at least cant have rear seat probs as it has the 'rock&roll bed' seat
Camper has been in VW garage all day today the big sliding door got stiffer & stiffer until couldnt open at all from inside & labour of hercules from outside to get it open- seems there is a cable inside door-- Fixed now free on warranty- but so used to attacking it full strength it is a shock now opening it---
Date Posted: 09 Sep 08 at 13:32
I've had the oil cooler replaced, and the fix to the stiff opening sliding door too. Oct 2006 build.
Posted By: gason
Date Posted: 19 Feb 09 at 21:50
mine an 07 trendline and i had mine done just by luck i was at dealers with a dodgy stalk
Posted By: wounded_gull
Date Posted: 20 Feb 09 at 12:22
I've had some handbrake issues with mine, it's an 06, not sure of the month though...
I parked up on a quiet back road visiting a local castle. The road was fairly flat thank god! as when I returned I found my van had rolled approx 40 ft  across a junction and parked itself into a wooden fence at the bottom of the castle moat!
I did a double take as I was sure it must be someone else van but it wasn't Confused
amazingly only slight damage to the 2 front plastic grills which popped back into place and a bit of scuffing the the bumper but it could have caused an accident or run someone over...
I def pulled the handbrake on as it's my pride n joy but it had definitely released. Luckily the pot holes in the road must've stopped it building up any proper speed.
I'm taking into VW tomorrow for a few things to be done whilst still under warranty
steering wheel knock has come back, stereo not installed correctly, drivers door hinge loose, side door squeak which is driving me nuts and the handbrake!
and they'll hopefully sort me out with 2 new front grills...
I was in the van yesterday, slipped it out of gear( I now park in gear!) and started to roll down hill! so there's def a fault.
I checked the chassis no but it doesnt seem to correspond to any of the recalls -  WV1ZZZ7HZ6H097723
Posted By: CLONKY
Date Posted: 20 Feb 09 at 16:14
Early ones def had a problem. Mine was an early one and i returned it as the handbrake was self releasing. Needless to say the mindless muppets could not find a fault, but it was eventually recalled and rectified. I'd have expected yours to be okay though, i'm sure the recall was well before '06
Posted By: zedzedeleven
Date Posted: 21 Feb 09 at 11:07
My `04 was done on a recall. I think they have redesigned the ratchet pawl, made it a bit wider.
1.9 85ps swb 2004 in friesan green.
bring me sunshine.
Date Posted: 23 Feb 09 at 09:25
oh well... they've given me a courtesy van while mine is having the tweaks done.
It drives like a Ferrari compared to mine which has a conversion in the back! ;)
I must say VW Cardiff are so much better since Sinclair VW  took them over. Polite, helpful staff. No complaints from me so far...
I've not got the van back yet though! LOL
Posted By: cherry evo2
Date Posted: 03 May 09 at 18:08
Sinclair VW Van Centre in Gorseinon (Swansea) are great. Jeremy Phillips who runs Sinclair commercials (both sites) is a top bloke. He will not tolerate any nonsense regading poor customer service, if you should experience any bad service he's the man you need to speak to.
Date Posted: 05 May 09 at 16:51
Good to know! Cardiff have already started to slide down in my estimations after a positive start.
My van came back with the same squeaky door it went in to have fixed and they also messed me around with a courtesy car.
I went down there and had to waiT3 mins for someone to speak to who'd gone to the bank..
When they then arrived, they informed me that the company who'd borrowed the van I was going to use hadn't returned it yet, so I'd have to come back another day. I was not impressed.
Posted By: jes*b
Date Posted: 26 Jul 09 at 15:47
hi, did you get the sqeak in the door sorted - my caravelle has a rally noticeable one - sounds like something large is loose inside
cheers
jes
Date Posted: 27 Jul 09 at 10:42
Yes I've taken it into VW twice now to be repaired whilst I'm still under warranty
I don't know what they do but it seems to make a difference - They prob just tighten up the screws and grease the door.
my most recent squeak is down to the carpeted door panels on the interior - the screws are coming undone so i keep tightening them and it seems to be okay.
hope you get your squeak sorted
Posted By: lwb174caravelle
Date Posted: 27 Oct 09 at 20:07
The rattling sliding doors (knocking sound) on the T5 is an easy fix:
Apply grease to where the cone shaped locating lugs fit inside the door frame.
And while you are there you may as well also do the roller guides, door catches and hinges, bonnet catch  etc.
2005 VW T5 174 Blue Caravelle Tiptronic E.Yorks
Date Posted: 15 Jan 10 at 23:56
all the bolts come loose on sliding doors too, check em
Posted By: wanakombi
Date Posted: 12 Aug 10 at 12:38
Please help... i am a litle confused here is why......
I have a VWT5 04 2.5.
the water is full of oil.
forums have suggested this may be a faulty oil pump.
can i now get the oild one recalled if mine has now failed ?
ill make some phone calls in the mean time
many thanks
Date Posted: 12 Aug 10 at 15:38
Based on my experience it is likely to be a failed oil cooler/seal (waterpump failure more often ends up with coolant in the engine oil).
There was a campaign for the particular engines that were "supposed" to be affected.  A VW dealer should be able to tell you whether your van is covered or not (and whether it has been "fixed" or not), they'll need your VIN.
Posted By: 4kings
Date Posted: 24 May 11 at 11:32
i was wondering what the recalls are for Pre 2006 and after, as i am looking to buy a T5 but the most problematic free?
Posted By: johnylpool
Date Posted: 04 Aug 12 at 22:30
I own 08 transportere my clocks some times go off put on pc got p0600 code has anyone had same or has there been a call back on this problem
Posted By: martycochrane
Date Posted: 17 Jan 13 at 19:06
I have just bought a 2006 transporter and I'm not sure if the previous owner got the recalls carried out, if not what is the time limit of these things. Im guessing its not possible for me to take it back now and get it done for free?
Posted By: sportline1
Date Posted: 02 Jul 19 at 21:39
HI IM A NEWBE    NEVER BEEN ON A FORUM BEFORE I OWN A T5 174 HAD LOTS OF PROBLEMS
Date Posted: 02 Jul 19 at 21:53
ANY ONE HAD OIL THROUGH WIRING LOOM TO ECU ON A T5 174 2007 2.5TDI ENGINE CODE BPC I HAD CODE FOR EXHAUST TEMP SENSOR 1 SHORT TO PLUS P0546 INTERMITTENT NOW
THERE ALL THE TIME INTO LIMP MODE ENGINE LIGHT ON AS WELL AS FLASHING HEATER PLUG
LIGHT .IVE FITTED NEW TEMP SENDER EVEN IF UNPLUGED STILL SAME CODE
IVE SENT ECU OFF TO BE CHECKED
