Forum Home Forum Home > LT, Crafter & Sprinter Section > LT1 chat
  New Posts New Posts RSS Feed - LT fresh water tank
LT fresh water tank
 Post Reply Post Reply
Author
Message
rafollos View Drop Down
Not Quite Newbie
Not Quite Newbie
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote rafollos Quote  Post ReplyReply Direct Link To This Post Topic: LT fresh water tank
    Posted: 15 Jun 20 at 19:00
Hi everyone,
Since my camper LT is missing both it’s water tanks, and getting an original is close to impossible, i’m curious how you tackled mounting a water tank.
As far as I know, under the floor there is around 100x50x25 cm space. I don’t want the tank to be extending too much down, as i’m off-roading quite a lot. I found some tanks which might fit, but maybe it’s better to find someone who will weld one/create one from plastic, that would fit the LT underfloor?
There are metal enforcements on the floor, so the tank must be mounted under them, but if the tank would be moulded, it could hide higher.
Any recommendations on buying a proper tank?
So far I’ve narrowed it down to:
and
Would they fit? What’s your recommendations?
Thanks!
Back to Top
LTCamper89 View Drop Down
Vanorak
Vanorak
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote LTCamper89 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 20 at 15:24
CAK in the UK do two specific tanks.
VW OLD LT TO 96
022 VW LT FRESH – 68 lit (13) O/S BEHIND DRIVERS FRONT JACK POINT
021 VW LT WASTE – 54 lit (15) O/S FOLLOWS ON BEHIND FRESH
Fitting is usually by perforated straps, or square tubing with long bolts.
These tanks are rotamoulded or blowmoulded, which means there are no joints. Plastic welding is not really meant to be vibrated and shocked, so a fabricated one may not hold together for too long. I have been in plastic fabrication for thiry years or so.
Edited by LTCamper89 - 25 Jun 20 at 15:25
Back to Top
Forum Software by Web Wiz Forums® version 12.06
Copyright ©2001-2023 Web Wiz Ltd.
The WebThis site
