Atiwe nuts/bolts? |
ELVIS
Moderator Group Silence is golden, gaffa tape is silver Joined: 04 Nov 06 Location: Promised Land Status: Offline Points: 9982 |
Posted: 11 Jun 14 at 17:35 |
Can standard steel wheel nuts and bolts be used on atiwe cheese hole wheels same as factory carat use them?
Www.justgiving.com/ELVIS-SUMMERS
JonnyAtlantic
Yardie Joined: 04 Aug 08 Location: Hove Status: Offline Points: 342 |
I have Atiwe Pepperpots on my Westy. They take the tapered seat nuts and bolts, same as the Carats. Not the radius ones the steels use. No other changes necessary. Just torqued up correctly.
1990 Westfalia Atlantic 1.6TD - Pop Top
ELVIS
Standard length rear studs then chap?
JonnyAtlantic
Yeah. Studs are standard.
jason k
Admin Group twinklerims Joined: 14 Jan 05 Location: Wales Status: Offline Points: 15934 |
Yup chap, we fitted some on piledrivers old bus!
Bcs shallowest surf award winner 2006
camperjam 2011 chug and tug team member aberdare. south wales newest member of karmann korner no longer the only moderator to manage to ban himself |
T3ADICT
Vanorak Joined: 21 Jul 05 Location: LeightonBuzzard Status: Offline Points: 4215 |
the caravelle/carat etc taper nuts end up screwing in more hence no need for longer studs. I have found that some aftermarket taper nuts/bolts don't seen to have the same effect as the oe nuts/bolts I would think its possibly a different angle to the taper. |
