Tips for fitting the B Pillar Decals |
Author | ||
diviy
Yardie Joined: 22 May 05 Location: Wales Status: Offline Points: 301 |
Posted: 16 Apr 12 at 23:39 |
Had a set of these is it the normal soapy water and squeege method to fit same as normal decals then hot air gun?
diviy
The tip is dont use a company calley Brown stickers received them tried to fit on wrong cut way to big dont stick in other words fecking shit plus tried ringing and sending email no fecking reply except for one saying have i cleaned the panel FFS £20.00 down the drain TOSSERS
jason k
Admin Group twinklerims Joined: 14 Jan 05 Location: Wales Status: Offline Points: 15934 |
i used dans stickers, they were fine.
i had my mate who signwrites to put em on.
Bcs shallowest surf award winner 2006
camperjam 2011 chug and tug team member aberdare. south wales newest member of karmann korner no longer the only moderator to manage to ban himself |
diviy
I can do window tinting been fitting decals for years a mate run a sign writers buisness and showed me. These are the first ones I have had any problem with more pissed off they wont answer phone or reply to email.
jason k
well dan is a member on here, look for dknight
DKnight
Vanorak Joined: 20 Mar 08 Location: Huddersfield Status: Offline Points: 1139 |
ha only just seen this post, we reply to all our emails and operate through emails as everything is logged then depending who pics up the emails.
So you fitted them wrong and you are a little angry? the first set i ever fitted was on the brickwerks van and years later they are still on and fit fine for reference we replied to every one of your emails, we even had communication so saying we did not reply is just a lie. You even opened a paypal dispute and we had communication there and it closed as you did not reply? |
BANANABUS
Vanorak More Like BanBus! Joined: 01 Jul 07 Location: W YORKS Status: Offline Points: 1987 |
As above fitted some from brownlickers on my previous van. No problems . |
Committed To Famine Relief. Last Week I Sucked Off An Ethiopian
I'm Not Arguing,I'm Explaining Why I Am Right |
BANANABUS
So your mate no longer has a vinyl decal fitting business ? Appen that's why , he showed you how to fuck them up.. Edited by BANANABUS - 29 Aug 12 at 18:45 |
steve padda
Yardie Joined: 06 Apr 09 Location: Wolverhampton Status: Offline Points: 267 |
used a set from Dan , no issues and it was the first set i had ever put on a van
do not understand the need for water ?? you just peel backing and stick
DKnight
yeah we never use water to fit them, it makes it easier so you can float vinyl into place. But in this instance with the b pillar decals it is a big no no as the water sits on the window rubbers and can pull dirt up from under the rubber and then gets under the vinyl.
The vinyl is hard wearing and very easy to work with, the key we find is locate them with masking tape and then reveal about 1cm of the top, by folding the backing on itself. Then locate and then with a soft edge apply the vinyl down, putting a slight bit of pressure on, always monitor the location of the bottom so you do not stretch too much, once near bottom (about 10cm away) if needed you can stretch it into place and it does not effect the vinyl. Saying they are not sticky, again is down to fitment. It is unfortunate but if they were not sticky then all of the stickers we produce on the vinyl would not be sticky. I checked back at this sale in particular and you just never replied or listened to anything we said to help the problems. What more can we really do?
diviy
I have just check all my emails only only ones on record are from paypal and the reason I did not continue paypal dispute was you did send me another set that were a different cut.I APOLOGISE for not replying and saying on the forum it has just been one of those years health wise apologies again.
Regards Gerry |
mrhutch
Moderator Group the ginger princess Joined: 21 Aug 07 Location: Herefordshire Status: Offline Points: 5147 |
can I blame Eric?
