rear spline help T3 |
2020mad
Groupie Joined: 13 Sep 10 Location: coventry Status: Offline Points: 125 |
Posted: 24 Feb 12 at 15:45 |
Hi taken rear hub studs out to replace with new and noticed the spline marks on the rear hubs are nearly non exsistant, is this normal or are they badly worn and i may not be able to fully tighten wheels at some point, have no others to compare with or no knowledge of what they should look like????????
rowlesy
Vanorak murdered the murderwagen Joined: 09 Oct 05 Location: up unit! Status: Offline Points: 6466 |
pic would help? doubt you've worn them away?
UberFukz broke another! sucky sucky five dollah!
always out numbered never out gunned! RWS welding 07846 380 467 (worcs) |
