How do you strip down a 2 button key fob |
Post Reply | Page 12> |
Mike Whitworth
Not Quite Newbie Joined: 07 Feb 10 Status: Offline Points: 19 |
Posted: 13 Feb 12 at 10:08 |
Hi Folks
I hve broken the hinge on my 2 button folding key for my 2010 T5 I have puchased from EBay a replacement blank key but it is very slightly different in that to dismantle the new one you remove a small screw under what woud have a VW badge. Now the origional has a smaller plastic badge and what looks like a pin holding it together which is situated in the reccessed area which the key folds back into. I have been told that all I have to do is push this pin inside and the fob comes apart is this correct . Obviously I do not want to damage the origional getting it apart. I am hoping to just put the hinge from the new one onto the old one as the van is a lease van, I do not want any problems when I return the van at the end of the contract this way it is completly origional . Thanks in advance for any help Mike
Onefut
Yardie I like pink Joined: 14 Jan 08 Location: North Devon Status: Offline Points: 994 |
Ive never stripped one so dunno
be good if you could put up some pics if you manage to do it ;) |
God whispers in our soul & speaks to our heart. When we don't have time to listen, He has to throw a brick.
It's our choice: Listen to the whisper or wait for the brick! 05 Shuttle SE 174 Auto LWB |
energysolutions
Vanorak Joined: 02 Dec 08 Location: Earth (For Now) Status: Offline Points: 3684 |
Never attempted this but its worth remembering that the transponder chip for the immobiliser is in the original too and will need chaging over (or reprogrammed if there is already one fitted) otherwise the immobiliser wont recognise the key and the van will refuse to run
Supposedly a delicate item, so be careful I believe Greg changed his fob (to a Bentley cover IIRC, more for aesthetic reasons) so he may be able to offer some guidance on the practicalities of doing so |
!!Never Eat Yellow Snow!!
Mike Whitworth
Re the transponder being delicat this is another reason for just swaping the hing and obviously the key blade , ie no reprograming or key cutting . BUT I really nead to know how to dismantle it before I attack it with a blow torch/ crow bar or other delicate watchmaker tools . as I stated I have been told that just pushing the pin ( in the recessed part where the blade folds into)into the fob should allow it to dismantle and then having done the swap and retrieved the pin put it back ?????? I am reluctant to prize the badge off to see if there is a screw under it as I am sure it would be destroyed in the process so am hoping someone on the list has done this before me and can advise me !!!!!!!!!!! PUT simply HELP Mike
energysolutions
Big hands has meant
small delicate devices have never been my friend
Greg is in a different time zone (Australia) but I`m pretty sure if/when he comes on he will be able to offer some guidance |
john the sparky
Yardie Joined: 26 Oct 10 Location: Bucks Status: Offline Points: 574 |
got an altea with 2 button remote, and the badge has fell off.... and there is a screw underneath the badge on that...
fairly sure it is the same with a different badge
Stormkayaker
Groupie Joined: 04 Jul 09 Location: South Devon Status: Offline Points: 49 |
This might help you! Never been brave enough or needed to undo the screw! Let us know how you get on!
Steve B
Vanorak Joined: 26 Apr 05 Location: Mong free zone Status: Offline Points: 13190 |
He's wanting to know how to take apart the original fob and not the replacement one with the screw.
There's quite a few "How to" videos on Youtube that may show exactly how ? |
john the sparky
mine is an original key, there used to be a badge with the Seat logo on, that fell off and there is a screw underneath......
well I always assumed it was a proper key, it was a 6month old vag management car when I got it
maybe the keys have changed recently, and the ebay ones are like the older ones? |
Mike Whitworth
Thanks for all your coments Guys I think it would help if I could put a couple of photos on here
but do not seem able to so how do I do it . and GREG are you out there YOU seem to be "THE MAN" Thanks again guys I really do appreciate the trouble you are going to Mike
Mike Whitworth
Hi Guys
Me again I have realised how to add photos but need to make them small file size to work I will have another in the morning Mike
Mike Whitworth
Hi Guys I hope you can see what I mean by the badge being small in the 1st Photo and the pin I have been told to push in is just to the right of the hinge between DE and Hella its about 1mm in dia. Hope this helps some to give me the necessary advice . Regards to All Mike
MP
Groupie Joined: 12 Apr 09 Location: Devon Status: Offline Points: 158 |
If it helps, one of my keys (to a 2010 van) is missing the VW badge and there are no screws beneath it but it has the pin as in your pic above. Looks like the pin is the only way in… be brave!
Past vans - 1989 Ex-Swedish 16" Syncro & 2010 T5 GP 102
gason
Vanorak Joined: 31 Mar 07 Location: United Kingdom Status: Offline Points: 1238 |
That screw had nothing to do with holding the fob together. All you do is pull it apart holding each side firmly where the split on the outside is . I have just pulled it apart twice now
Steve B
Is that on a 2010 T5 key without the screw? |
T5 TDI
Vanorak Joined: 05 Nov 05 Status: Offline Points: 3687 |
Looking at your pics it does look like a simple spring loaded plunger so I can't see why you would damage anything. Your new type fob is quite different and splits in a different way so I don't think you will be able to fit your ebay hinge part to the old fob.
2004 2.5 174
T5 TDI
Just seen Gason's post and his description is right for the older fobs, you can just yank them apart separating the half with the hinge (which is the half with the screw holding it together) from the chip bit which is the part with the buttons on it. But Mike's remote is clearly a newer type. If you look at the part where the pin and little numbers are on his pic there is no split, it's a continuous bit of plastic.
My guess is that if you press that little plunger in, the guts will release leaving the outer shell and hinge in place. Only a guess though Edited by T5 TDI - 14 Feb 12 at 21:29 |
2004 2.5 174
Steve B
This is for the new 3 button fob but it looks like the same problem...how?!?
T5 TDI
I wish I had one to experiment on..... Press pin Mike and see what happens. You know you want to!
2004 2.5 174
Mike Whitworth
Thanks Guys
I am away from home now untill thursday I will have a go at it then As Vanorak says I will press the pin he's wright I want to Mike Watch this space i will let you know what happens Mike
