6 beeps on startup after flat battery. Why? |
jooliohoolio
Not Quite Newbie Joined: 09 Jul 10 Status: Offline Points: 17 |
Posted: 09 Jul 10 at 21:06 |
Hi, I flattened my battery recently and ever since then there have been about 6 beeps every time i start the engine. The battery light goes out on starting and it starts just fine every time. Can anyone tell me please why it's beeping and how to reset it? I spoke to VW and they said that i'd have to take it into them to get it reset = £££ i could really do without spending.
Thanks a lot
energysolutions
Vanorak Joined: 02 Dec 08 Location: Earth (For Now) Status: Offline Points: 3684 |
My guess is its stored a "low voltage" (or similar) fault code from the battery being run down, all it needs is a scan/reset via VAG COM/VCDS
Where you from?
!!Never Eat Yellow Snow!!
jooliohoolio
Thanks for your speedy response, I live in north devon but regularly travel to exeter, bristol and occasionaly down to bournemouth.
energysolutions
No worries, had you been local we could have sorted something but the small matter of a large puddle between us rules that out (I live in Northern Ireland)
Someone in your locality with VAG COM would be your best bet - its certainly not worth paying for your local VW dealers christmas party over!
jooliohoolio
Ok - thanks for the offer. Any ideas on how to track somebody down with a vag com?
The Loon
Yardie Joined: 06 Feb 08 Location: Skid Row Status: Offline Points: 912 |
My battery is shagged. So much so that it won't hold a charge for more than three days. No beeping from mine though...
Justified Ancient of Mu Mu.
jooliohoolio
sounds ominous, sure would be good to see what happens after resetting the codes with a vag com - I'm pretty new to the t5 world and new to this forum any ideas on how to hook up with someone with a vag com? Is there anyone on the forum in the devon or bristol area who has one?
Albal
Yardie Joined: 15 Nov 07 Location: French Alps Status: Offline Points: 398 |
Are you sure the flat battery hasn't reset the seatbelt chime? That is a lot of beeps after start up or something along those lines...
jooliohoolio
Not sure what the seat belt chime sounds like - it's never gone off before.
energysolutions
If the battery gets low on voltage then the ECU etc will too and this has been known to "confuse" the electrics and cause daft messages
My Golf run its battery down after my wife left the keys in it for a whole weekend(!) and it resulted in the remote fob no longer being able to unlock the boot, once the battery was fully charged I disconnected the battery and left it overnight - problem solved!
jooliohoolio
Yeah, I'm kind of thinking that part of my problem may be that in spite of a few long drives since flattening the battery it may still be a bit low - only problem is where i live it's not that easy to charge battery up as i can't get power to the vehicle where it's laid up. I suppose i could remove battery bring to house and charge up indoors - this is starting to get technical for me - any tips on do's and don'ts when removing battery to charge?
The Loon
Are there any orange lights showing. Mine used to beep for the brake pad sensor. I've also heard it beep for low oil level, low coolant level and for low fuel. A dud battery can cause all sorts of grief, and so can a dodgy earth. Might be worth checking out the earth strap between the gearbox and the chassis. |
jooliohoolio
Yeah, not convinced it'll be anything like the earth as the problem only started immediately after the battery went flat - it made this noise as soon as i started it
energysolutions
Disconnect the battery over night and that may "reset" the ECU (worked on my Golf), better still if you can charge its while its disconnected, if you have to remove it, its easy enough, remove the battery clamps (1 bolt each) and the clamp which secures the battery (1 more bolt)
jooliohoolio
nice one energysolutions - gonna give it a go
trenchfoot
Groupie Joined: 23 Jul 09 Location: Cornwall Status: Offline Points: 58 |
i have a vagcom based in northcornwall (tintagel) work in Hosworthy north devon!
jooliohoolio
hey trenchfoot,
nice one mate, would be great to hook up some time with you. wish i'd found this forum - and you - a little earlier as i must've virtually driven past your front door last week when i went down to mawgan porth camping! okey dokey, well i'm maybe off to dorset this week so maybe could hook up either on way there or back or next week - would be a good excuse for me to head off to bude for a bit of surfing as holsworthy isn't exactly round the corner as i live near woolacombe.
