Forum Home Forum Home > T3 Section > South African T3s
  New Posts New Posts RSS Feed - CV joints done!
CV joints done!
 Post Reply Post Reply
Author
Message
silverbullet View Drop Down
Yardie
Yardie
Avatar
Ingenieur
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote silverbullet Quote  Post ReplyReply Direct Link To This Post Topic: CV joints done!
    Posted: 19 May 10 at 10:12
Well the nearside, anyway. What a pig of a job. Exhaust completely in the way...and that's on it's last legs. CV's are Audi 100/A6 up to about '95, 108mm.
It's still got a slight vibration over 60, so must be the n/s front wheel bearing (did the o/s) Must do tomorrow evening, the kit's no good on the shelf Embarrassed
Same as later german vans with sliding calipers, FAG kit 713 6114 10
Edited by silverbullet - 19 May 10 at 10:14
Have I missed anything?
Back to Top
Yardie
Yardie
Avatar
Ingenieur
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote silverbullet Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 10 at 22:51
Hmmm. Did the nsf wheel bearing too. Better, but there's still a cyclic shudder that passes through the bus about every 6 seconds at 60 mph. Worse on smoother roads or that crappy concrete bit of the M25 south of Chertsey. Wonder if it's got a bit of wheel flutter from a tired rear damper?
Hope it's not a rear wheel bearing...
Back to Top
Forum Software by Web Wiz Forums® version 12.06
Copyright ©2001-2023 Web Wiz Ltd.
The WebThis site
