Long Wheelbase (Shorter Job) LT35 |
Post Reply | Page 123 11> |
BigAl68
Yardie Joined: 13 May 09 Location: Shildon Status: Offline Points: 255 |
Posted: 15 Apr 10 at 17:50 |
Thought I would start a new topic for the new van. It's a 1995 LT35 2.4 TDI.
I've started stripping the old camper and have got the overhead lockers out. Will finish removing the rest of the stuff as and when I get time. No timescale planned, it will be done when its done. It will need a little bit of panel work and the inside will be converted using what I already have. Edited by BigAl68 - 08 Sep 10 at 17:44 |
1995 LT 35 Self Built Camper 2.4 TDI
BigAl68
At long last I finally got round to making a start.
Changed the headlights (the adjusters were broke on both sides) Swapped the sliding doors over and the grill (it's now got a VW in the middle ) Changed 3 of the bushes on the anti roll bar (the other one was ok but I've got the other new one for when the time comes), fastened the battery in properly, changed the drivers and centre passengers seat belt buckles, changed the door handles so all the locks are the same (except the ignition) and changed the passenger side mirror arm (slightly bent) and the mirror (smashed). Also drained the petrol out of the old camper Weather permitting more next week Allan |
BigAl68
Had a good day today. Renewed the wheel bearings, the front spring and the brake pipe all on the passenger side, all of which were fails on the last MOT, the changed the last anti roll bar bush. Will change the pads and shoes at a later date and the rocker cover gasket.
New anti roll bar bush Old and new springs (the old one was actually in 3 bits) Spring out All Finished and a better pic of the sliding door Cheers Allan Edited by BigAl68 - 27 May 10 at 20:01 |
icky
Vanorak Joined: 01 Jun 06 Location: Windlesham Status: Offline Points: 1424 |
Progress! That's what we like to see!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
- 2000 MK4 Golf GT TDi - 1994 LT Panel Van - 1997 LT Minibus - 1984 Volvo/VanHool Alizee |
BigAl68
Me too Icky. Managed to do some more today.Took the brand new exhaust off the camper.
and the heater fan as mine isn't working. Also took the gear lever gaiter, spark plugs, leads, coil, air filter and electronic ignition (all brand new) off the camper and the weber carb, accelerator and choke cables off as it will be getting scrapped soon. Swapped the ignition barrel on the Van so all the locks now operate with one key and while I was on I got the washers to work (cleaned the contacts) also changed the rocker cover gasket as there was an advisory on the MOT of an oil leak More soon. Cheers Allan Edited by BigAl68 - 07 Jun 10 at 17:31 |
icky
Lots of useful spares on your old one! :D Hope you've got a big shed! |
BigAl68
I've got 2 large sheds, an LT 28 and an LT 35 . It's all stored in the camper at the moment. Still more to remove. Some going for the van and everything surplus (including the birds nest) will probably be flogged at a later date. Watch this space
Cheers Allan Edited by BigAl68 - 03 Jun 10 at 17:37 |
icky
I was gonna make that joke but I resisted, I didn't need to in the end
BigAl68
Did some more work on the campers. Stripped the old one and sent it off to the great scrapyard in the sky (well it's gone to Tindale) and brought all the bits to our house.
Started putting the side windows in. Inside I stripped off the ply lining and some of the insulation. Outside I cut out the holes with my trusty angle grinder and duck taped them in for now. Used the interior part of the frame as a template. 1st hole 2nd hole Taped in More next week Cheers Allan Edited by BigAl68 - 31 Jul 10 at 22:00 |
icky
Word of advice - make bloody sure that you seal up and rustproof the edges you've just cut REALLY well, because otherwise it'll rust in a few years - thats where a lot of minibuses have failed... :) |
BigAl68
Thanks for the advice Icky , would probably have realised shortly after the windows were sealed in .
Anyhoo today I changed the passenger side caliper for a nice shiny one (the bleed nipples were rotten on the old one and one snapped off when I tried to slacken it off) and have decided to do the drivers side one as well as that looks as if it will go the same way. Weather permitting will be fastening the windows in tomorrow. Cheers Allan Edited by BigAl68 - 08 Sep 10 at 17:45 |
BigAl68
Weather and other things got in the way the last couple of days but managed to change the other caliper and also put on a new brake hose. Zinc oxide spray applied round the window edges so hopefully no rust. Also managed to get hold of a caravan to donate its interior to a good cause .
Cheers Allan |
BigAl68
Side windows bonded in. They are as they were in the old camper. Plenty of sealant and screwed through into the wooden subframe.
Then bracing for the kitchen area and window surrounds were started. Also fitted a new dash as the old one had rather a large hole in one side (sorry for the poor pic ) and the fuel guage and water temp guage had a dodgy circuit board. Caravan stripped out and got rid of. (I was asked if I'm opening a timber yard ) Fitted new wiper blades and adjusted the washers (they were doing a canny job of washing the roof ). Started modifying the caravan interior to fit. Fitted fastening clamps for the front seat as there were none. Didn't look as if there had ever been any either . Changed the passenger side indicator lens (the old one was cracked) More soon Cheers Allan PS. If you watch BBC 1 at 10.35 on the next 6 Monday nights (Tears & Gears) you will see what I used to do before I started messing about with LT's. My camper will be at a few of the meetings next year. A preview of the programme is on http://www.bbc.co.uk/programmes/b00td9d7. |
MostlyMonki
Yardie Joined: 05 Sep 07 Location: Bristol Status: Offline Points: 335 |
Made me all teary eyed reading through this Allan... good to see my old van (formerly known as "Big-Bob" by the way) being treated so well! :)
"LT Massive"
BigAl68
Glad you are pleased Matt.
Checked the rear brakes today and adjusted the handbrake cable. Think thats it for the mechanicals. Also put silicon sealant round the indicators so hopefully no more water where it shouldn't be. Cheers Allan |
topsy
Groupie Joined: 04 Jul 10 Location: county durham Status: Offline Points: 56 |
Hi Allan,
Just wanted to say it great to meet you (and great to meet you again for Rog, small world!) and thanks for your help, advice, and the try of your battery - it's such a relief to know for sure it is just a bad battery! Bring the Mrs through any time if she wants to have a look at the interior... Cheers Zoe |
BigAl68
Cheers for that Zoe. Will pop round again soon to see how you are both doing.
Started on the fun stuff today. Cut a hole in the floor (also sealed and painted zinc oxide on the edges) Installed the heater Fitted the cupboard around it Fitted the blower to the back Started on the first seat Still to plumb the heater in and get it checked by my friendly plumber before using. More tomorrow Cheers Allan Edited by BigAl68 - 18 Aug 10 at 17:30 |
BigAl68
Finished bracing around windows. Started cutting panels to go over the top and the generator ran out of petrol so gave up for the day.
. Found a use for the seat More soon (work permitting) Cheers Allan |
BigAl68
Managed to squeeze a few hours in today. Started paneling around the windows. When it's done it will all come back off so I can put extra insulation and a water heater in.
Cheers Allan Edited by BigAl68 - 08 Sep 10 at 17:48 |
topsy
looking good :)
