no speedo, erratic fuel gauge |
jonk65
Not Quite Newbie Joined: 25 Apr 07 Location: United Kingdom Status: Offline Points: 36 |
Posted: 14 Feb 10 at 00:19 |
Hi i need help with my van. It started with an erratic speedo but now that's works intermittently. When its not working the fuel gauge is erratic.
I have another problem on the clocks that could be related and that's a flashing oil light. Iv been told this cold be down to high oil pressure but i had the oil pressure checked and that's fine. Jon |
ELVIS
Moderator Group Silence is golden, gaffa tape is silver Joined: 04 Nov 06 Location: Promised Land Status: Offline Points: 9982 |
you had fuse board out/dropped down?
they dont like it and pulled/loose plugs can cause mental shit.
my tacho stopped working and oil pressure light/warning kept going off. one big smelly log in pants later all sorted.(i dont know about speedo as never drove it until i got it sorted)
Www.justgiving.com/ELVIS-SUMMERS
Tommo
Not Quite Newbie Joined: 17 Jan 10 Location: Herts Status: Offline Points: 29 |
Had exactly the same thing with mine. It's happened twice now and both different faults.
The first was exactly as Elvis has suggested..
I'd been wiring in an alarm and disturbed the relay/fuse plate. Top right hand corner of the plate there are 2 plugs with 2 thinish wires in each,, both orange but one with a white stripe and the other with a brown, easily recognised as the pairs of wires are twisted. Been led to believe that they are data link wires for the ecu but dont quote me on that. I'd managed to dislodge one of these which brought up the oil light,bleeper & glow plug light.
Second time was a few months back,, i was driving along happily when the clock and trip display started doing erratic things (speedo and rpm worked fine tho & no other warnings). I was half expecting the van to jump into limp mode but it carried on and behaved normally.
I spent ages wriggling connectors, unplugging & plugging back in but no joy.
The fault finally turned out to be in the dash itself. There's a voltage regulator that sits on the circuit board which needed re soldering. It's on a silver heatsink and positioned top/central behind the fuel and temp guages. Mines a 2.5TDi caravelle by the way just incase yours is different..
Word of caution if you remove the dash though... It's very expensive to replace & full of electrickery!! Easily damaged by mishandling alone. That's even before you switch on the soldering iron!
Of course the first thing to do if you haven't already is get a copy of vag-com or such like and see what fault codes if any are stored. If it's probs with the data link like i had the first time you'll have a whole list of them. However given your symptoms i would be thinking along the lines of intermittant supply voltage either internally in the dash (poss voltage reg) or externally in the wiring harness, connector plugs etc.
That's my 10pence worth drawn from my own experience, hope yours is a simple fix
Happy Days
Andy
First time i hit it i missed it.. Second time i hit it i missed it in the same place!!
DanT4Syncro
Not Quite Newbie Joined: 07 Aug 08 Location: Cornwall Status: Offline Points: 18 |
I'll throw something else in the mix.
I had the same problem, went through a few packs of fuses finding the fault. In the end it was simple. Disconnected reversing light switch from the gearbox and gave it a little clean. That was a year or so ago been fine since. |
Dan T
parat4
Newbie Joined: 24 Mar 10 Status: Offline Points: 1 |
Had the very same problem on my T4, intermittent gauges, very easy fix. The solder on the back of the dash breaks down over time, £35 and 30 minutes at an auto electicians, brilliant now!
windysurfer
Yardie Joined: 13 Jun 07 Location: Lancashire Status: Offline Points: 970 |
Excellent instructions with idiot proof pictures( I managed to follow em!!) here,easy to do if you can solder http://www.vwbooks.co.uk/t4.htm |
